Post new topic Reply to topic  [ 23 posts ]
Go to page 1, 2  Next
PostPosted: Mon Feb 11, 2013 2:20 am
I´m currently using standard shimano brakepads, with very light Kinlin xr-200 clincher rims. In these rims the space for the brakepads is very narrow, and i guess the thickness of the rim walls is not wide enough for them too last many years before they need repalcement... I also ride 80% of winter in wet conditions.
I'd like to know if there are brakepads with a better performance in the wet that the standard shimano pads, and that may last as long or longer, and also do not eat too much aluminium from the rims? is there anything worthy on the market or I should stay with shimano pads? I´m using the latest shimano 105 dual pivot brakes. they brake ok, which is not a lot with rims covered on water.
thanks a lot!!!!!! :beerchug:
Happy Trails !!!
MTB / Giant Xtc '05 / 8.7Kg
ROAD / La Perla Negra - FM015 / 7.0Kg
PostPosted: Mon Feb 11, 2013 2:25 am
Online
Koolstop Salmon.....I have used them and they work very well in wet conditions. Have used there combination pads (black/salmon) and they are nice as well.
PostPosted: Mon Feb 11, 2013 3:21 am
Tried almost all shimano ones, salmons and a few other but dt swiss green is the longest lasing by far and the breaking is at least equal to the others. The price is not bad either as you get a whole set (4 pads) at once.
PostPosted: Mon Feb 11, 2013 6:30 am
Another vote for the Koolstop Salmons
PostPosted: Mon Feb 11, 2013 10:18 am
I've found the Salmons to perform rather disappointingly (on American Classic rims though). But they seem to work well for many others. Swissstop sure is a safe bet.
Bikes: Raceur, Beateur
PostPosted: Mon Feb 11, 2013 10:39 am
Administrator
I'll second or third the SwissStop green. Best pads I have ever used on alloy rims.
PostPosted: Mon Feb 11, 2013 12:30 pm
Braking is over rated :) but I like the green Swiss stop pads. They do seem to last the longest of the wet weather pads I have tried
TIME RXR
PostPosted: Mon Feb 11, 2013 1:19 pm
Trouble with swissstop greens is that they may last longer but they eat your rims!! I wouldnt put them anywhere near my bikes again after they ate my Shamals...!! You are better with a pad that wears fast and of course works well. I find the standard Dura Ace pad a good compromise or standard Kool stops. Havent tried the salmon variety ?!
Lig.
3kbikes.co.uk
For best - Parlee Z3
For training - Colnago EPS AKBL
For the pose - 1980'ish' Basso Steely
PostPosted: Mon Feb 11, 2013 6:54 pm
Lig.
Exactly, that was one of my concerns. I really don't want to eat my weak rims. Green pads are out. Can someone comment on the salmon pads in relation to how much they eat aluminium?
Happy Trails !!!
PostPosted: Mon Feb 11, 2013 7:28 pm
SwissStop blacks are a better bet for softer rims. I use them with my Campag wheels. The downside is they do wear quicker than the greens but it's cheaper to replace pads rather than rims or wheels.
PostPosted: Mon Feb 11, 2013 8:15 pm
Some people even use SwissStop yellows to prevent wearing the anodization off -- so they are easy on the metal. Not sure how well it works though, since you're mentioning wet conditions and all ...
PostPosted: Mon Feb 11, 2013 9:35 pm
At the moment I am trying out Aztec Road plus pads. Braking is good in the wet, I cannot atest as to how the pads wears or how it treats my rims. I will find out in due course. I do worry about my XR200's as well which is why that bike is a dry weather bike only. I currently have KCNC brakes on that bike, with the stock pads. No idea how they wear at all.
www.thecycleclinic.co.uk
PostPosted: Mon Feb 11, 2013 11:45 pm
SwissStop now has a new Alloy pad called the BXP...it's blue and exceeds the performance of the green pad.
Yellows can be used but they tend to be "grabby" since they are softer and don't last as long as other alloy specific pads.
www.royalbicycles.com
PostPosted: Tue Feb 12, 2013 11:07 am
According to Swisstop, their black pads are gentle with alloy rims, so I guess the other coloured pads are not.
Question now would be; are swisstop black pads better than standard shimano pads????
Happy Trails !!!
PostPosted: Wed Feb 13, 2013 7:21 pm
I just started testing a set of the Swiss Stop black on my race bike. So far they have slightly less stopping power but it's only been one ride. I aligned them square to the rim and then toed them in but there is still a bedding in period and also wearing away any mold release or oxidixed outer layer.
At this point I would guess that they are about the same as 7900 pads in the dry. The infrequent high frequency chatter disappeared but that may be due to putting greater toe in on the pads vs the 7900 ones.
Post new topic Reply to topic  [ 23 posts ]  Go to page 1, 2  Next
Users browsing this forum: Bing [Bot], HammerTime2, periodcorrect and 84 guests
There are no new unread posts for this topic. Shimano 35mm carbon tubular rims as rims only ?
LouisN
Fri Jun 29, 2012 2:24 pm
LouisN View the latest post
There are no new unread posts for this topic. +/- 4 deg alloy stem?
AllAboutTheEngine
Thu Dec 13, 2012 9:37 pm
NGMN View the latest post
There are no new unread posts for this topic. Alloy clincher rim review
madcow
30
2926
Tue Jan 29, 2013 12:22 pm
MajorMantra View the latest post
This topic is locked, you cannot edit posts or make further replies. Alloy Tubular Advice
mattydubs
Fri Mar 15, 2013 7:14 pm
rc32 View the latest post
There are no new unread posts for this topic. Attachment(s) best alloy road bike of 2012
[ Go to page: 1, 2, 3, 4 ]
RAFIUDEEN
45
4154
Tue Oct 09, 2012 12:50 am
53x12 View the latest post
It is currently Tue May 21, 2013 7:55 pm
