Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 5 posts ]
PostPosted: Sat Feb 09, 2013 4:53 pm
Heya guys, I am in a predicament in which bike to choose :noidea:, the S-WORKS Venge or S-WORKS Tarmac SL4.
I am around 86KG in weight and am around 5'11 - 6ft. I do put down a lot of power (1300W) on short sprints (I am only a amateur) :D .
In the summer I'm going to the Dolomite range to cycle.
My initial thought is to get the venge but looking online more people say "Get The Tarmac", I want to know why?
The S-WORKS shop near me explained that the Venge has a stiffer rear but the Tarmac has a stiffer front, also the bottom bracket of the Venge is thicker and stiffer.
Now I know the immediate response of people will be to get the Tarmac. But uphill riding is not the only thing I do. I also love flats and downhill riding so the Venge is faster as you have the aero advantage, and next January I'm going to Hawaii to do flats so the Venge will do better there.
What I really want to know is if the Venge will climb well/be good as the tarmac on climbs.
I know the weight difference between the frames are like 150g. But I'm not at a good enough standard to notice the difference, also there is the comfort factor, the tarmac is apparently more comfortable but I have a good saddle and I have researched that the wheels and tires play a huge factor in "comfortness".
Also does anyone know the difference (if any) between the 2013 and 2012 framesets, The guys in the S-Works shop say that its only a few decals, the carbon and frames are identical, and the 2012 frame is £100 cheaper.
Many Thanks in advance :D .
Please, use Search. There are topics already on this.
PostPosted: Sun Feb 10, 2013 3:30 pm
From the sounds of it, you're more of a flat-terrain kind of rider (I'm allergic to hills myself). I say get the Venge.
Specialized BG Fit Technician
2012 Specialized S Works Venge Project Black Dura Ace 9000 - 14.875 lbs.
2012 Spooky HavocStaff SRAM Red - 15.5 lbs.
PostPosted: Sun Feb 10, 2013 3:36 pm
I say get both.
Correct on the 2012 being the same as 2013 so no need to spend the extra cash.
I really think for an amateur like you and me it more about getting the bike that personally speaks to you. The one that makes you happy and makes you want to go ride you bike more and makes you feel faster. At the end of the day that is the bike that will make you faster not the small difference between the Venge and the Tarmac.
PostPosted: Sun Feb 10, 2013 3:55 pm
If you are 86kg and going to the Dolomiti, worry more about gearing and a comfortable climbing position.
Road surfaces there aren't the best in Italy so I would avoid something like the Venge which will give you no benefits whatsoever that I can see.
Enjoy. It's a great place to ride - if hellish at times. :)
PostPosted: Wed Feb 13, 2013 4:38 pm
Many thanks guys. I couldn't resist the Venge it just looks amazing. So I got it!! Here it is with my Mavic Open Pro's (Training wheel) the two bags behind contain my zipp 404's.
Will put up a pic with them on =)
File comment: My S-Works Venge Project Black
Users browsing this forum: fitty4 and 58 guests
There are no new unread posts for this topic. Specialized S-Works Venge Di2 Battery Mount
Lionlin
12
1875
Wed Apr 17, 2013 3:57 pm
Lionlin View the latest post
There are no new unread posts for this topic. Next step up from S-Works Tarmac?
qeaou
Sun Oct 28, 2012 12:53 pm
Spindoctor View the latest post
There are no new unread posts for this topic. Stepping down from a S-Works
aserota
11
1387
Thu Sep 13, 2012 5:02 pm
NWSAlpine View the latest post
There are no new unread posts for this topic. s works crankset
cymans
9
1057
Thu Apr 04, 2013 3:25 am
Gearhead65 View the latest post
There are no new unread posts for this topic. S-Works SL3 to C59 (Bike Fit)
jeffbong
Fri Jan 04, 2013 4:43 am
jeffbong View the latest post
It is currently Wed May 22, 2013 11:18 am
