Post new topic Reply to topic  [ 7 posts ]
PostPosted: Wed Feb 06, 2013 8:54 pm
Anyone got an actual real life weight on a Super Record Ti crankset (53/39 175mm) ?
When I look at shops there are almost as many different weights claimed as there are shops.
Even camp's own site has same weight on all cranks, no matter if its 170mm or 175mm, compact or not - which hardly seems correct either.
PostPosted: Wed Feb 06, 2013 9:10 pm
Here you go, a comparison of the 2009/2010 Super Record Crank, the 2011 Ti Super Record Crank, and the Campy/SRM Crank
Weights (all cranks are 175mm with 53/39 chainrings):
Lightest to Heaviest:
2011 Super Record Ti: 596 grams
2009/2010 Super Record Steel (assume 2011 Steel Super Record is the same or very close): 658 grams
Campy/SRM Powermeter: 796 grams
My Colnago C59
My Special Colnago EPQ
PostPosted: Wed Feb 06, 2013 9:24 pm
* The nominal weight refers to the lighter specification among the available options.
The nominal weight does not take account of the sometimes considerable quantities of grease used in the assembly of the products.
Although this does seem to be saying that a 170 39-52 standard weighs the same as a 170 34-50 compact, which seems dubious.
PostPosted: Wed Feb 06, 2013 9:39 pm
Nice, thanks alot. Guess 2012/2013 is same ballpark as 2011 :)
PostPosted: Wed Feb 06, 2013 10:26 pm
Yes, as far as I know the weights should be pretty much the same. The only change I'm aware of is that they beefed up the rings on the Compact cranks a bit since 2011 to accommodate the greater force that the EPS front derailleur exerts on them.
My Colnago C59
PostPosted: Wed Feb 06, 2013 10:32 pm
For comparison's sake, my 2012 SR 53/39 172.5mm Ti cranks were 597grams.
PostPosted: Wed Feb 06, 2013 10:35 pm
I have this crank and can't imagine using any other. Super good looking, functions as you would expect and above all, it's been set and forget.
Users browsing this forum: 573, 604Yarks, caballero, eurperg, fitty4, Google [Bot], Google Adsense [Bot], Juanmoretime and 45 guests
There are no new unread posts for this topic. Campagnolo Super Record EPS Actual Weights
cwdzoot
12
1514
Wed Jun 06, 2012 6:54 pm
artray View the latest post
This topic is locked, you cannot edit posts or make further replies. 2010 super record 11 vs 2012 super record 11
Rumshcawheely
Sun Feb 24, 2013 2:21 am
milroy View the latest post
There are no new unread posts for this topic. Super Record EPS vs Record EPS, worth it?
Ufgators
10
1087
Thu Aug 30, 2012 10:58 pm
dereksmalls View the latest post
There are no new unread posts for this topic. Any changes for Record/Super Record EPS for 2013?
Ufgators
Sun Aug 26, 2012 9:14 pm
ultimobici View the latest post
There are no new unread posts for this topic. zipp sl short & shallow actual weight?
mdeth1313
10
477
Mon Apr 08, 2013 8:50 am
CarpetFibre View the latest post
It is currently Tue May 21, 2013 10:26 am
