Post new topic Reply to topic  [ 7 posts ]
PostPosted: Tue Feb 05, 2013 8:23 am
My current rims are just about done in and was trying to work out what I might use as a replacement rim. I would use them for everyday riding on my training bike.
My slight concern is that the hubs are 16/20 and need something which will minimise wheel flex. Would consider shallow section (38?) carbon clincher or aluminium. Failing any ideas, I may just rebuild with RS80 rims which I believe are identical to the Dura Ace but bizarrely significantly cheaper.
PostPosted: Thu Feb 21, 2013 11:07 am
I have a broken C24 rim, so I would be interested in sourcing a new for the hub.
Are you sure the RS80 replacement rims are cheaper?
PostPosted: Thu Feb 21, 2013 1:39 pm
I've worn the dimples away on one set of 7850 C24's and am now running my second set. I would be interest in knowing where to buy replacement rims - or who can do this rebuild. These DA wheels are really good wheels and worth the rebuild unless it cost nearly as much as a new set.
PostPosted: Thu Feb 21, 2013 2:01 pm
You could try contacting your local distributor based on the parts list listed in these documents:
http://techdocs.shimano.com/media/techd ... 698498.pdf" onclick="window.open(this.href);return false;
http://techdocs.shimano.com/media/techd ... 698499.pdf" onclick="window.open(this.href);return false;
I'm assuming you're talking about the C24-CL and not the 'TL' tubeless version ???
These guys seem to have it but are charging and arm and leg for them though :unbelievable: :
http://www.petracycles.co.uk/shimano-sp ... 22112.html
http://images.fatbirds.co.uk/4521/produ ... -hole.aspx
PostPosted: Fri Feb 22, 2013 12:18 am
I am based in the UK and last time I looked I don't think there was much difference buying an rs80 wheelset (planet x currently £320) to strip the rims off and buying separate rims. When I looked a couple if months ago the rims seemed to have a standard shimano stock code - the joke is that the rs80 rims were about 140 each and the dura ace more than (200 each from memory). I think the only difference is the decals!!!
PostPosted: Fri Feb 22, 2013 11:27 am
Not many 16 hole rims around - Kinlin XR300s perhaps best option?
PostPosted: Fri Feb 22, 2013 8:18 pm
Will look for the Kinlins - not sure how good availability is in the UK for 16 holes. Has anyone on here any experience of 16/20 with the Kinlins.
Another option might be the carbon/aluminium farsports 38mm rims; again has anyone any thoughts on building these up in 16/20?
Users browsing this forum: Biff, Bing [Bot], Google Adsense [Bot], Majestic-12 [Bot] and 64 guests
There are no new unread posts for this topic. Dura ace c50 7850 wheels.... Which hubs??
dane476
Sun Jun 03, 2012 8:08 pm
dane476 View the latest post
There are no new unread posts for this topic. Buying used Dura Ace WH-7850-C24-CL
BTM
15
2238
Sat Sep 01, 2012 1:14 am
BTM View the latest post
There are no new unread posts for this topic. Dura Ace WH-7850 C24 wheel set losing true
PBJDTX
7
472
Fri Mar 08, 2013 6:12 pm
PBJDTX View the latest post
There are no new unread posts for this topic. Dura-Ace replacement jockey cages
liam7020
Mon Aug 06, 2012 9:54 pm
dereksmalls View the latest post
There are no new unread posts for this topic. Dura Ace Pedal bearing service/replacement
petromyzon
9
762
Fri Sep 14, 2012 7:10 pm
horse View the latest post
It is currently Tue May 21, 2013 2:41 am
