Post new topic Reply to topic  [ 4 posts ]
PostPosted: Tue Feb 05, 2013 4:43 am
I have some very hilly riding coming up and was wondering if the 12-30t cassette will work with Ultegra Di2? I think I read somewhere that the maximum was 28 teeth but is that Shimano being conservative?
Thanks
PostPosted: Tue Feb 05, 2013 5:48 am
I've used the Ultegra Di2 rear derailleur with a 12-32 before, with zero issues...
PostPosted: Tue Feb 05, 2013 7:29 am
I've also setup Ultegra Di2 with an 11-32 cassette without an issue. It depends on the precise geometry of your dropout and the chain length, but with a 30-tooth cog it will probably work fine on most bikes, and on some you'll get away with a 32. Also remember that you can switch the inner ring on a compact for a 33-tooth (not available from Shimano, but is available from Stronglight or TA).
PostPosted: Tue Feb 05, 2013 5:13 pm
Thanks for the replies. I have one of these:
http://www.bmc-racing.com/int-en/bikes/2012/road/model/roadracer/sl01/sl01_ultegra_di2.html
I noticed that the '13 plain Ultegra model has the 12-30t cassette:
http://www.bmc-racing.com/int-en/bikes/2013/road/model/roadracer/sl01/ultegra_.html
I don't believe the frames have changed from the '12 to '13 model. Presumably that will work then?
Users browsing this forum: Bing [Bot], Google Adsense [Bot] and 34 guests
There are no new unread posts for this topic. 11-32 cassette only new Ultegra??
FHKJ
10
842
Thu May 02, 2013 7:26 am
maxxevv View the latest post
There are no new unread posts for this topic. Ultegra Di2 with 9-speed cassette
freeloader
Thu May 16, 2013 1:16 pm
There are no new unread posts for this topic. Ultegra 10speed 11-21 cassette
Gregorio
Mon May 28, 2012 9:52 pm
breezerboy View the latest post
There are no new unread posts for this topic. Shimano Ultegra 11 speed
[ Go to page: 1, 2, 3, 4, 5 ]
jujin
64
7529
Sun May 05, 2013 7:14 pm
Liggero View the latest post
There are no new unread posts for this topic. Tuning Shimano Ultegra 6700
verycreativeusername
Fri Aug 03, 2012 2:18 pm
Rush View the latest post
It is currently Sat May 25, 2013 9:03 am
Shimano Ultegra CS-6800 cassette
