Post new topic Reply to topic  [ 9 posts ]
PostPosted: Sat Feb 02, 2013 5:06 pm
Any idea how to fit a. clavicula crank into this frame?
As shown at picture. Bb seems to be shorter.
Parlee Z3sl - 5 kg
Passoni Xxti- 6.2 kg
PostPosted: Sat Feb 02, 2013 7:54 pm
Is the Clavicula a regular BSA crank? If so, you need different bearings that press into the BB and a little plastic spacer/collars that go between the crank axle and the bearings. You can get the spacers from a Wilier dealer. The bearings are size 6805. If the crank is not a standard BSA, I don't think it will work.
PostPosted: Sun Feb 03, 2013 2:31 am
Yes, its the standard bsa bb. The other photo shows 6806 bearing.
Now i concern about the length of the bb, it seems shorter then expected. the end part that the arm goes in are shorter.
Did you have any photo shows after installation? anyone done before?
Parlee Z3sl - 5 kg
PostPosted: Sun Feb 03, 2013 5:14 am
It will not fit.
PostPosted: Sun Feb 03, 2013 9:31 pm
Wilier Cento Uno
Colnago Master X-light
Wilier 18carati
PostPosted: Mon Feb 04, 2013 7:06 am
too bad :evil:
Parlee Z3sl - 5 kg
PostPosted: Tue Feb 05, 2013 1:46 am
Hit up the guys @ twohubs.com; they managed to install the Clavicula on Wilier frames (Zero 7 & Cento Uno).
http://twohubs.com/news.aspx?showarticle=169
PostPosted: Tue Feb 05, 2013 2:48 am
the Cento1 at Twohubs is the SR version. That, and the Zero7, have 386evo bb dimensions, for a 30mm spindle 86mm long. The original Cento1 is basically bb86/bb90, which is for a 24mm spindle. there's just not enough room on this one.
PostPosted: Fri Feb 08, 2013 4:19 am
Our one is too short.. we already give up.
Parlee Z3sl - 5 kg
Users browsing this forum: Bing [Bot], ewwhite, Exabot [Bot], Google [Bot], Google Adsense [Bot], petal666, rijndael, tharmor and 64 guests
There are no new unread posts for this topic. Attachment(s) New Willier 101..
[ Go to page: 1, 2, 3, 4, 5 ]
Berk
70
8947
Sat Oct 06, 2012 10:26 pm
Zakalwe View the latest post
There are no new unread posts for this topic. BH G6 or Cento Uno SR
brycerider
7
1010
Thu Dec 06, 2012 6:48 pm
jmilliron View the latest post
There are no new unread posts for this topic. Cento Uno Frame Crash
dbecks7
12
876
Sun Mar 10, 2013 5:20 pm
Jere View the latest post
There are no new unread posts for this topic. Upgrade wheels on Seven or go Wilier Cento 1
9x12man
27
1735
Wed Sep 12, 2012 11:29 pm
airwise View the latest post
There are no new unread posts for this topic. Wilier Cento Uno VS. Giant TCR Advanced SL
WasFab
16
1774
Wed Jun 20, 2012 12:01 pm
Wcl4 View the latest post
It is currently Mon May 20, 2013 12:25 am
