Post new topic Reply to topic  [ 20 posts ]
Go to page 1, 2  Next
PostPosted: Fri Feb 01, 2013 10:24 am
Hi there,
I am going to begin to race this season, and I want to change a bit my position to a more aero one, lowering the handlebar 2 cm (drop from 8 to 10 cm). I am 33, 187 cm and reasonably flexible (if I bend forward I can touch the ground with my knuckles). Has any of you succesfully gone this way? What exercises can I do in order to get there? Maybe some core work would help? Emphasising the stretching after training? Any tips?
Regards
PostPosted: Fri Feb 01, 2013 10:44 am
Yes it s a good idea but you should mainly improoved the length of the top tub that will make you even more aero , normally when your hands are on the botom of the handlbar , your elbow at 90° Your knee should just touch the back of your elbow.
It s another story if you are using a clip on bar.
Good luck
PostPosted: Fri Feb 01, 2013 11:09 am
Check your saddle setback too. I've found a bit more setback helped me greatly when going lower in the front. Regular stretching should not be missed anyway.
Bikes: Raceur, Beateur
PostPosted: Fri Feb 01, 2013 4:55 pm
It is easy to lower the bars. Try it and see. Do 1cm at a time and spend a couple months getting used to it. You should still be able to use the drops effectively. I see some guys with bikes set up so they can not ride in the drops. Yes, they have super low bars, but they're not actually using them.
In the last 4 years I have lowered my bars 2cm, from 10cm drop to 12cm. I do hamstring stretches in the evenings. I can bend over and put my palms on the floor now. Not bad for 53.
PostPosted: Fri Feb 01, 2013 11:52 pm
+1 eric
I'm going through the same process right now and find the turbo trainer a great tool for experimenting with different positions. I dropped the bar 10mm last month and I'm about to try another 5mm drop this month.
Fear is healthy, panic can be deadly
PostPosted: Sat Feb 02, 2013 12:39 am
I have recently started trying to stretch my hamstrings more but I doubt I will ever be Mr. Flexible. That being said I ride in the drops 100 of the time. The tops and hoods now feel awkward if I grasp them when I set off. When I first started riding 100% in the drops I had some minor discomfort on longer rides but eventually I acclimatized. However, I think the key to my success has been my SMP as it allows me to rotate forward and for someone lacking flexibility that helps a lot.
PostPosted: Sat Feb 02, 2013 5:11 am
Pratice the way you intend to play......
I've never taken on an additional stretching program - rather you work gradually to the lower position.
Since you want to give it a try, I'd suggest you go ahead and drop the bars - maybe 10 cm first - then be sure you are riding in the drops a sufficient % of the time - over time the added flexibility, strength in the lower position, and tolerance for it all will come. Then repeat again dropping things once again.
Eventually you should naturally want to be low - versus having to make a conscious decision that you must give it a try.
PostPosted: Sat Feb 02, 2013 7:18 am
You don't need to stretch or do core work. You *do* need to focus on your posture and relax your core. Your muscle engagement as you pedal will also change.
formerly rruff...
PostPosted: Sat Feb 02, 2013 4:33 pm
And don't listen to any so-called cyclist that can touch their toes.
PostPosted: Sat Feb 02, 2013 8:02 pm
WMW wrote:
You don't need to stretch [...]
Of course you don't need to, but it's very advisable to complement just about any sports with some stretching ...
PostPosted: Sat Feb 02, 2013 10:24 pm
Cancellara is probably one of the most flexible riders in the peleton, easily able to touch his toes, and I would trust him 100%.
Likewise, in my own experience, I was able to more comfortably ride in a much more agressive position after doing lots of core and stretching. I was entirely unflexible beforhand though, so I would guess there is a point of diminishing returns on comfort when increasing flexibility.
PostPosted: Sun Feb 03, 2013 12:11 am
Tubbie Guru
Hi,
And..........Bingo. :thumbup:
IOW words you need to find a position that works for you.
If you are by nature a flexible person then that may help but every person has a position that maximizes both efficiency and aero.
Doing gymnastic excercise to maintain or improve flexibity may well prevent muscular injuries or inflamations but there's no scientific indication whatsoever that it takes flexibility to perform better as an athlete.
Ciao, ;)
PostPosted: Sun Feb 03, 2013 7:08 pm
As you're wanting to be aero, are you wearing a skinsuit when you race and have you covered the vents up in your helmet?
PostPosted: Sun Feb 03, 2013 7:13 pm
Sorry if I'm going off topic here, but does 'flexibility' really affect how low of a position you can take?
I can barely get the palms of my hands past my knees when I bend over and try and touch the floor, yet I have a very aggressive position on my bike. Do I just have short arms?
PostPosted: Sun Feb 03, 2013 7:40 pm
It does for me, and I know some people who aren't flexible and who can't get their back down, or even use the drops in some cases.
Perhaps your saddle position is forward of typical for road riders. If you simply rotate the rider position forward using the BB as the axis, like triathletes often do but not to that extreme, you can run lower bars without changing the hip angle.
Since I have long thighs and do a lot of climbing I have the saddle back fairly far (to engage the glutes on climbs). Getting a low position from there means bending more from the hips. To ride comfortably and make power like that you need sufficiently flexible hamstrings.
Post new topic Reply to topic  [ 20 posts ]  Go to page 1, 2  Next
Users browsing this forum: Bing [Bot], caballero, Google Adsense [Bot], HammerTime2, Kurt, planB, xjbaylor and 65 guests
There are no new unread posts for this topic. Aero or Nero (not aero) ? (New bike frame)
stang1
29
1639
Thu Apr 18, 2013 6:36 pm
Kayrehn View the latest post
There are no new unread posts for this topic. New Storck Aero Bike
morrisond
Thu Aug 30, 2012 3:42 pm
Discoverspeed View the latest post
There are no new unread posts for this topic. Best Aero Bike Choice ?
[ Go to page: 1, 2, 3, 4, 5 ]
theloper
65
5112
Fri May 10, 2013 5:19 am
thatdkid View the latest post
There are no new unread posts for this topic. Avanti aero bike
Ravenstrife
25
3425
Tue Dec 04, 2012 12:34 pm
Jono L. View the latest post
There are no new unread posts for this topic. Storck Aero TT bike advice please
Mitchapalooza
Sat Feb 09, 2013 10:34 pm
Mitchapalooza View the latest post
It is currently Wed May 22, 2013 5:24 pm
