It is currently Sun Dec 17, 2017 9:17 am
Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 220 posts ]  Go to page Previous 15 6 7 8 915 Next
What are the 2 most important things for you on a crank ?
-Design + stiffness 9%  9%  [ 15 ]
-Design + weight 15%  15%  [ 24 ]
-Design + price 5%  5%  [ 8 ]
-Stiffness + weight 44%  44%  [ 70 ]
-Stiffness + price 9%  9%  [ 14 ]
-Weight + price 18%  18%  [ 28 ]
Total votes: 159
PostPosted: Tue Apr 30, 2013 2:50 pm
Sorry, the cranks broke at the spider. His story was that he got up to sprint on a group ride, felt something really soft and heard a creak and pulled over where he noticed a big crack. They were on the bike for a week.
I just don't see the point of these. All the customization stuff is really unnecessary and you can get wider/narrower q factor by using different length axles, shims, washers, etc. Length is pretty easy to fix, they're not much lighter than the top end cranks yet cost almost as much. Just don't seem to have a purposeful niche in the market.
Gramz
Failed Custom Bike
PostPosted: Thu May 23, 2013 6:59 pm
Look what the post office had waiting for me!!
172.5 110 BCD
Complete with spacers and washers sized for PF30 BB along with Praxis rings 50/34 and Extralite Chainring bolts:
First impressions: Very solid and not as massive looking in person. Visually a work of art and finished like jewelry.
PostPosted: Thu May 23, 2013 8:26 pm
I have a friend that bought a pair and received them two weeks ago, he has already bent one of the arms. He is about 190 lbs and is known to be tough on bike parts. He is going with a different crankset. I saw them when he first received them, they looked good.
PostPosted: Fri May 24, 2013 12:40 am
Mine was delayed several weeks and believe the reason was due to that issue mentioned which has been addressed according to Ted. I'm in the 170lbs range and no Cavendish. I'll get a few short local rides in to sort this new crank out.
I might add that Ted's been very forthcoming about the status and issues with me in the last several months in spite of how busy he's been. He's a perfectionist to fault and patients was key in this process. I'm confident in the design and that Ted will be all ears "if" I find a gremlin or two down the road.
Damned this crank looks so cool in person. :thumbup: Definitely has a unique character all its own.
PostPosted: Sun May 26, 2013 2:07 pm
The design is really where it needs to be now. With the changes to the pinning of the carbon tubes, the cranks really perform. We've put a significant amount of effort behind it with mating a power meter as well to it. This was reviewed in bike rumor about 2-3 weeks ago and have done a few road races and criteriums on the crank in an effort to see where we could find fault. Each issue we encountered, Ted has addressed with changes to the design. What you're seeing now in the latest release is a crank, non-power meter and power meter versions, is one where there has been a lot of input placed into it by a lot of knowing people. Delays are to be expected, if you look at the earlier post from someone else, they cited that Ted works all flaws out and sometimes it is to his detriment in delivery.
Another thing is to really look beyond the weight of the crank. The weight is awesome, however, the crank itself is more impressive to us in terms of stiffness and power transfer when compared to a Sram, THM, or Rotor. The crank is clearly superior on even the tactile feel of it and we're seeing much less flex within the 130 and 110 bcd spiders (base line was use of Praxis chain rings and Rotor chain rings each).
PostPosted: Sun May 26, 2013 3:02 pm
Hard to look too far past the weight of the crank when he was touting it so hard pre-release. I just don't think they're the most efficient way of designing a crank, or brake for that matter. I'd call it all a styling exercise. They definitely have a distinctive look.
PostPosted: Sun May 26, 2013 3:43 pm
Echoing what Thisisatest said, I have a friend with a compact Exogram 175, praxis rings and sanded arms, that comes in at JUST below 500g (497g to be exact, on his scale). He bought the crank new on eBay for $350 and the rings $170~.
PostPosted: Sun May 26, 2013 4:09 pm
runner999 wrote:
172.5 110 BCD
*cough*
172.5mm, 110BCD, possibly among the stiffest available (pending FWB's next Cranksetshootout)... oh, and available under $400USD shipped, including the chainrings which you can either keep or sell off. Below is the GXP version, the BB30 is even lighter. GXP is also one of the easiest systems to use for standard BSA (or 86/92) setups.
PostPosted: Sun May 26, 2013 8:43 pm
I'm sorry but as much as I admire the design of this chain set surely all these issues should have been resolved before it's release to the public, "The design is really where it needs to be now" is where it should have been on its release, you don't hear of changes being made after the release of a product from the likes of Shimano and Campagnolo, yes I know Ted is an artisan but if he is to be respected I think his product needs to be 100% before it gets into the hands of the consumer. The vibe I get is a product that has been rushed out.
Ti or dye!
PostPosted: Mon May 27, 2013 11:05 am
*Double cough*
MichaelB wrote:
Here are my cranks - 175mm, BB30 with std rings (compact)
It ends up at 364g w/out chainrings, but includes the 5 chainring bolts.
All up (w/o BB30 bearings) and with Praxis works chainrings, my crank setup is 491g (391 for crank and 150 for rings). Bearings add another 70g
QED
PostPosted: Mon May 27, 2013 11:25 pm
Is that spider arm or crank arm?
I'd be curious to see how this crankset does in Fairwheel bikes next crank shoot out, assuming that there will be one. I still think that the Clavicula is the bench mark, in appearance, stiffness vs weight and the fact that it's now effectively an old design. The new Sram Red is a nice crankset and very light, but at the end of the day it's just another mass produced crankset, just with a manufacturer that's starting to exploit the abilities of carbon fibre that THM have been doing for some time. I'm still reserving judgement on the Ciamillo crankset, there just seems to be a lot still going on.
As long as all customers are aware of that it's fine. I get the impression from a few people that they've been expecting a flawless crankset from day one.
Interesting. So are you saying that the crankset is stiffer than the three mentioned and is that just a personal impression or is that tested? Saying that a crank is 'clearly superior' to a THM crankset has got my attention. I've yet to see a better engineered crankset than what they do.
PostPosted: Tue May 28, 2013 2:07 am
It was the crank arm, and you could see the arm twist when standing on a pedal.
This would not have been a big surprise if this was a crankset that was just released a few weeks ago. My friend waited and thought that all was clear and that everything had been worked out. It was deliver May 13th 2013.
I agree that the THM Clavicula is the standard which all other cranks need to be measured against. The only other crankset that I use other than the THM Clavicula is the Ax Lightness crank which ranks close (0.268 vs 0.242) to the THM in stiffness and I prefer the way it installs.
It is hard for me to imagine that the Gravitas crank is stiffer than the THM and I would be surprised if it was stiffer than the Ax Lightness crankset, I would like to see an independent measurement. Talk is cheap.
PostPosted: Tue May 28, 2013 3:31 pm
A couple times these cranks were mentioned in conjunction with our next test. Unfortunately we have not yet tested them. We've requested and been told that we'd be getting a set for testing but so far have not. We have finished the latest round of testing and will be releasing it hopefully later this week. (Thm M3, Tune Smartfoot, DuraAce 9000 and a new Kcnc crank.) Hopefully we'll have the Gravitas to go into our next round which will have the Sram 22 as well as the new upcoming Campag and production EE.
Fair Wheel Bikes
Fair Wheel Blog
Instagram
PostPosted: Tue May 28, 2013 3:38 pm
madcow, what is the new upcoming Campag (crank)?
PostPosted: Tue May 28, 2013 3:39 pm
Madcow,
You are the third person to bring up this "new upcoming Campag " crank... Can please you share more info, and if not can you at least let us know the PR embargo data?
Thanks
C
There are no new unread posts for this topic. Attachment(s) Poll on disk brakes
Lewn777
27
1501
Sun Nov 12, 2017 11:48 am
sharkman View the latest post
There are no new unread posts for this topic. Ciamillo OG-05 Ti with Zipp 303s?
nvroadie
Mon Dec 26, 2016 6:58 pm
nvroadie View the latest post
There are no new unread posts for this topic. Ciamillo GSL Micro clearance with 25mm tubular
TheBlackPath
Sat Nov 11, 2017 11:49 am
TheBlackPath View the latest post
There are no new unread posts for this topic. Ciamillo rear brake servicing - removing excess play
Slimtim
7
1007
Wed Dec 21, 2016 4:08 pm
Slimtim View the latest post
There are no new unread posts for this topic. Crank Bearing Puller for SRM Campagnolo Crank
mrgray
14
1152
Tue Apr 04, 2017 9:37 am
mrgray View the latest post
Users browsing this forum: alistaird, bobones and 36 guests
