Post new topic Reply to topic  [ 94 posts ]
Go to page 1, 2, 3, 4, 5 ... 7  Next
What are the 2 most important things for you on a crank ?
-Design + stiffness 12%  12%  [ 14 ]
-Design + weight 13%  13%  [ 15 ]
-Design + price 6%  6%  [ 7 ]
-Stiffness + weight 42%  42%  [ 50 ]
-Stiffness + price 9%  9%  [ 11 ]
-Weight + price 18%  18%  [ 22 ]
Total votes : 119
PostPosted: Wed Jan 30, 2013 10:25 pm
Hello everybody,
I'm proud to say that I have ridden for the first time in Europe the Ciamillo Gravitas crank prototype today !
I have completed a road ride with my cycle cross bicycle: 2 hours alone at 32km/h AVS.
No issue has been recorded during the ride, which is a good thing for a prototype.
But I would like to share with you the impressions of the elite level cyclist that I am, rather than any other commercial opinion or advertising. I know, that's really hard to be objective ! But I'll try...
The prototype arrived yesterday. This is the blue that all of you have already seen.
I was very excited to receive it, because all I had seen was the base and the carbon tubes (during my last visit in Atlanta in November).
And I have been really impressed when I opened the box: the quality of this stuff, the incredible weight and the stiffness. The weight is correct: 390g !
Then, I tried to set it up on my bike, a BSA30 bearing was installed, exactly the same that is on Ted's bike in Atlanta.
But it seemed impossible to work, the spindle was too short. Since it was the morning in France I couldn't call Ted for a help (OK, never mind it would take 5 days to get a reply :wink: ). So, I found the solution by myself with removing the bearings seals, and it worked like a LEGO !
Since it was a very rainy day, I have decided to wait for the next day to test the crank...
So, this morning I went out for a 2 hours ride. The tools in the pockets just in case... An I rode. After just 1 acceleration I had to say: "where's the crank ?". That's a strange feeling, there is like no weight left, or just on the chain rings ! On a second bigger acceleration I realized that the crank was not only light, it was also simply the stiffest I had ever tested (definitely stiffer than the Rotor 3D that I had until monday on my bike with the same chain rings).
Then, the rest of the ride has only been a pleasure.
I had not a power meter on me, but I know me quite well and I pedaled at 500-600W during 1-2 minutes several times in order to pedal at very high speed with a strong rear wind (my speed during theses efforts was between 60 and 70km/h).
Now, I know what a stiff crank is, and I want absolutely keeping that stiffness on my racing bike.
Stiffness is avoiding loosing power in material deformation, lightness is avoiding loosing power in the rotation of the crank arms.
The last time I felt a such improvement has been when I changed my Cosmic carbon wheels by an ENVE wheelset. The improvement was probably better with the wheel change, but this is to illustrate that I felt a real gap with the existing cranks available on the market !
After the end of the ride, I checked the crank and everything was perfect. The bearings are now in place so that I have been able to tighten more the bolt that is maintaining the 2 half spindles.
So, I called Ted today to share my opinion as a cyclist. And, as a cyclist we want something reliable. So, I'll continue to test it before placing orders for my customers. As a cyclist, we want something easy to setup. So, I'm waiting for an adjustable bolt that will preserve the bearings and avoid the crank to have any play. That should be solved very easily with just a little longer spindle.
A last thing that I loved was the interchangeable spider. When you remove the crank, the spindle is going out by itself. What a good improvement !
On my Rotor cranks I hate changing all the time my chain rings. With a such crank, it's very easy to change your chain rings: I'll have 2 spiders: one with a 54/42 for flat rides, and the other one in 110 will be 53/38 for the mountain. That will be changed in 2 minutes.
It recalls me that a good product is often simple.
So, what's the next step ?
I'll continue to ride this crank. I feel very confident in the product, despite it's a prototype.
Ted has launched the production and he's going to make stiffness and reliability tests with machines.
The colors of the blue pins should be replaced by black or red anodized, and make the crank for many people (not all of course !) the most beautiful available on the market. I'm sure that you'll prefer the crank with aero chain rings.
We cannot be sure at 100% that there will not have any problem on the product, but as a cyclist, I felt very confident all the time during the ride, and if there's a drawback to signal, this is how we are going to be able to supply the crank with the exact spindle lengths and shims widths... Ted will make it possible, he just needs time.
Tonight, I'm sure about one thing... if Ted has been dreaming for a long time swimming across the oceans with the dolphins, since January 2013, Ted is back with us !
PostPosted: Wed Jan 30, 2013 10:57 pm
Thanks for the honest review! They look awesome and that weight is impressive.
Please continue with the feedback as your experience with the cranks continue.
:cheers:
PostPosted: Wed Jan 30, 2013 11:37 pm
That's extremely cool. I hadn't realized he had air gaps between the cylinders. It's by breaking pre-conceived aesthetic constraints that you break-free of previous limits on mass-versus-stiffness. If I didn't place a priority on $/gram saved I'd definitely go for this one.
http://djconnel.blogspot.com/
Fuji SL/1
PostPosted: Thu Jan 31, 2013 8:23 am
I forgot to mention that despite the end of the tubes are not covered, the wind is not making noise during the ride. I can say that because I rode in each position from the wind, and yesterday was very windy !
On the feelings on the weight, I would say that there's the about same gap between a Shimano 105 crank and a Sram Red crank, than on a Sram red crank and this Ciamillo Gravitas crank.
I can explain that because if we cut the arms of a conventional crank and compare with the Ciamillo crank arms, the weight gain is located mainly on the arms, not on the spindle.
And engineers know very well that the arms of an heavy crank require a lot of energy to be turned at 100 RPM. I mean that the overweight is not only in translation (climbing and acceleration) but it's also about accelerating the rotation of a mass at 60-100 RPM.
So, the riders who want to improve the efficiency of their bikes should not only consider that this crank will allow only a 90g gain and they can save these 90g on cable housing or quick release change... That's actually wrong ! A good crank makes energy savings with a better stiffness and lightweight.
That's the case of this prototype.
PostPosted: Thu Jan 31, 2013 11:02 am
Tinker, Taylor, Tart
Hmmm... Can you really feel the difference in stiffness from one crankset to another?? I mean, *really?? I never have, and I've gone from Rotor to DA7900 to an apparently 'flexy' Tune SmartFoot to carbon Dura-Ace, all on the same bike.
Sorry but I'm afraid I just do not believe there's noticeable wattages increases to be had (especially WITHOUT a power meter) from a change of cranks.
PostPosted: Thu Jan 31, 2013 12:50 pm
Since I'm riding about 20000km each year, I ride enough to feel very narrow changes on my bike, especially when I ride everyday or even twice a day.
But that's true that if I ride once a week, my feelings are not precise at all and I would not be able to see any difference between for example a Rotor 3D steel and a Rotor 3D Flow whereas the stiffness is different.
On the Ciamillo crank the stiffness is really noticeable. It's like if the arms are on rails, perfectly guided in the axle.
Of course the difference of wattage will not make me a champion but it's reasonable to imagine 0.5 to 3 watts saved at 40km/h thanks to that stiffness, and a few other watts thanks to the lightness of the arms.
PostPosted: Thu Jan 31, 2013 2:02 pm
ah, too bad I cant answer this, the powermeter option isnt in the poll!
2013 rocky mountain vertex 29er
­Twitter
www.cyclingtrainingnuts.blogspot.ca
PostPosted: Thu Jan 31, 2013 2:08 pm
here is more details:
http://www.veloptimal.com/forum/viewtop ... &start=180
PostPosted: Thu Jan 31, 2013 2:10 pm
Is there an aero wattage loss on the Ciamillo Gravitas crank without aero-covered arms?
PostPosted: Thu Jan 31, 2013 6:46 pm
My guess would be the cylinders are drafting each other fairly effectively but you could always add weight and fill the gaps with epoxy if you wanted.
On stiffness my view is "just need enough" and any further is a matter of feel, not efficiency. Crank flex is mostly elastic and lossless.
Fuji SL/1
PostPosted: Sun Feb 03, 2013 10:58 am
that sounds really good - is there weight for crankset with chainrings and beraings?
I like the look - dont need aerocovers (it is WW forum) :mrgreen:
http://kavitec.blogspot.com/
click this! http://www.youtube.com/watch?v=jqfFdCWAH5I&list=UUEtgd6K9EDGmoSE2YYipQgQ&index=20
PostPosted: Mon Feb 04, 2013 11:03 pm
I have seen two versions of the Ciamillo crank. One has carbon-blade arms, which looks way cool to me. The other has arms made of three carbon tubes, which looks a bit strange. Which one did you ride? Do you know which one will go into production?
PostPosted: Tue Feb 05, 2013 7:02 am
I think bladed cranks will not be offered just newer version with 3 carbon tubes. On photo of test rider are those - so review is for crank with carbone tubes
PostPosted: Tue Feb 05, 2013 8:27 am
The version with the 3 tubes is being tested.
Since last tuesday, in 7 days I have already ridden 460 kilometers (on flat roads and hard hills) with it and it appears as an excellent product.
The first deliveries should start early now !
Please find the pictures on my Cervelo S5. It doesn't looks strange with an aero chain ring sets on an aero frame !
For me, the PTS technology (locking carbon tubes) is allowing great improvements in terms of weight and stiffness.
My prototype is in 175mm (392g) and I suppose that a very stiff version under 350g (170mm) can be designed within the next few months.
What I like also is the interchangeable spider. That way we'll be able to ride both flat roads and mountains with a minimum of maintenance.
In the future, a lighter spider (in carbon fiber) may also be designed to save a few grams again ! This one is already light (39g).
PostPosted: Tue Feb 05, 2013 2:18 pm
Just to be sure: is the 392 grams for crankarms, spindle and spider?
Post new topic Reply to topic  [ 94 posts ]  Go to page 1, 2, 3, 4, 5 ... 7  Next
Users browsing this forum: Bing [Bot], Google [Bot], Google Adsense [Bot], justkeepedaling, ProfessorChaos, rmerka and 48 guests
There are no new unread posts for this topic. New Ciamillo Gravitas SL
MOTOMATT
32
3991
Sat Jan 05, 2013 10:52 am
theremery View the latest post
There are no new unread posts for this topic. Ciamillo Gravitas SL First Impressions
RyanH
11
1369
Sun Apr 21, 2013 9:49 pm
RyanH View the latest post
There are no new unread posts for this topic. Ciamillo Gravitas cranks w/Quarq Spiders
jmocallaghan
Wed Jan 16, 2013 6:02 pm
jmocallaghan View the latest post
There are no new unread posts for this topic. Ciamillo Gravitas Cranks with a Power Meter Option
jmocallaghan
Sun Apr 28, 2013 5:53 pm
This topic is locked, you cannot edit posts or make further replies. Attachment(s) Ciamillo Crank V2
[ Go to page: 1 ... 6, 7, 8 ]
elfuinha
111
6781
Thu Dec 27, 2012 3:07 am
Tinea Pedis View the latest post
It is currently Sat May 25, 2013 2:18 am
