Post new topic Reply to topic  [ 21 posts ]
Go to page 1, 2  Next
PostPosted: Wed Jan 30, 2013 6:24 pm
I have a 1 year old BMC Roadracer frame, and for the last few months bubbles are appearing under the clear coat. Slowly, the number and size of the bubbles is increasing, and at some places the bubbles push through the cleat coat, and can be easily felt. At first I though it was grime or sweat or something, but the bubbles sit under the clear coat.
click here for image
They can be a bit tricky to spot, but they can be found all over the frame.
I returned my frame to the dealer, and they sent pictures to BMC to hear what they have to say. According to BMC, the bubbles are formed within the carbon glue / epoxy in a reaction to UV rays. They say it's purely cosmetically and is harmless. They don't see this as a warranty case. The best my dealer could do is a extension of the warranty on the paint / clear coat to 5 years.
I can't say I'm satisfied by this. UV rays damaging the epoxy doesn't exactly reassure me, and can't be conducive for the structural integrity of the frame. Furthermore, shouldn't the clear coat protect the epoxy from UV?
Should I demand a replacement frame? I don't feel that these bubbles are 'normal' and 'nothing to worry about'.
PostPosted: Wed Jan 30, 2013 7:11 pm
I wouldn't worry about it. It looks purely cosmetic and tbh I can hardly even see them in the photos.
PostPosted: Wed Jan 30, 2013 7:51 pm
I wouldn't accept this period! You payed good money and have the wright to a product who is without cosmetic defects. It is a defect and needs to be fixed one way or another. It's time for manufacturer to stand behind their products. I would take it as far as possible.
Pfeiffer's Rennrad Camp and Cycling Coach
Independent HED Wheels/Powertap Dealer
PostPosted: Wed Jan 30, 2013 8:36 pm
maybe they are bubbles in the clear itself and u could wetsand them with like 1500 grit paper
PostPosted: Thu Jan 31, 2013 2:01 am
Specialized frames, stems and seatposts used to have the same problem. Maybe they still do.
PostPosted: Thu Jan 31, 2013 2:59 am
Well i dont think their explaination is right, as this is a commom problem with many manufcaturers. Its caused by residual mold release agent left on the frame when it is cleared. It eventually causes the clear to seperate from the carbon, and so you get little air pockets in between.
You'll find them to some degree on any molded frame. Some are worse than others, but it is purely cosmetic in any case.
PostPosted: Thu Jan 31, 2013 3:38 am
I've got only one that's visible, 5mm oval shaped one on the side of the top tube. BMC told me the same thing, got the local dealer to assist me. The dealer offered to cover for a cosmetic job by a service centre locally, to buff away the clear coat layer and then redo it. I was somewhat concerned that the result might look worse, (and the wait for the job to start/finish should be quite long too), and decided to let things stay as it is. That was 3 years ago...
PostPosted: Thu Jan 31, 2013 3:44 am
There is the answer. I wouldn't fuss over it but that's just me. All they would do is sand and clear. Mold release or dust is the cause. My Ridley helium has some imperfections in the clear from dust.
PostPosted: Thu Jan 31, 2013 6:36 am
Sand the whole frame! Gotta be a couple of free grams to save!
PostPosted: Thu Jan 31, 2013 7:19 am
this is a high end bike, would you accept this happening to your high end car? if yes, ignore. if no, make some noise.
PostPosted: Thu Jan 31, 2013 8:11 am
I have seen this on two of my frames and one seatpost and have gotten every piece waranted. Was told it was only a finish problem though.
Technical editor at Cykelmagasinet Denmark
My Simplon Pavo II
PostPosted: Thu Jan 31, 2013 2:57 pm
+1
*f##k* the company's who don't stand behind their products!
PostPosted: Thu Jan 31, 2013 5:52 pm
Just checked out bmc. Yep a huge bubble smack middle of top tube. I was able to crack the bubble apart. It seems this is a problem of bmcs.
PostPosted: Thu Jan 31, 2013 6:08 pm
The minute I started to demand a proper solution for this problem, the dealer offered to return my money. I'm happy with the outcome, but I will not be buying BMC again!
PostPosted: Thu Jan 31, 2013 7:33 pm
BMC has a great warrenty.
Storck Fenomalist 6.3kg.
BMC Teammachine SLR01
Post new topic Reply to topic  [ 21 posts ]  Go to page 1, 2  Next
Users browsing this forum: Bing [Bot], em3, ferrarista, shimmeD, tommasini and 46 guests
There are no new unread posts for this topic. Fading clear coat on frame?
NAKaveli
Thu Jul 05, 2012 2:32 pm
Valbrona View the latest post
There are no new unread posts for this topic. Repairing clear-coat on carbon parts
Master-Ti
Wed Oct 17, 2012 2:19 am
fdegrove View the latest post
There are no new unread posts for this topic. Acrylic Urethane or Acrylic Lacquer Clear Coat
rgamble
Sun Dec 23, 2012 7:05 pm
bicicleta View the latest post
There are no new unread posts for this topic. tiny bubbles on my carbon bike please advise !!!
RAFIUDEEN
Fri Oct 05, 2012 10:28 pm
artray View the latest post
There are no new unread posts for this topic. powder coat vs enamel.
simonanks69
Mon Jun 11, 2012 9:56 am
simonanks69 View the latest post
It is currently Fri May 24, 2013 5:07 am
