Post new topic Reply to topic  [ 45 posts ]
Go to page 1, 2, 3  Next
PostPosted: Wed Jan 30, 2013 12:36 pm
So I am 196cm (6'5") tall, 82kgs (180lbs) and normally ride in medium De Soto bibs.
With a 32" waist, 39" hips and 22" upper thigh, Assos expects me to ignore all these measurements but height and go with XLG???
I have spent several hours reading reviews and comments of Assos bibs, trying to find anyone of a similar shape, but it seems everyone close to my height is much heavier. Some comparisons have people riding roughly one size larger in Assos, but they are all five foot something with average builds.
I ignore the height guide on the De Soto's and they fit great:
Can I do the same with Assos?
Size Height
XS 150 - 159 cm
S 160 - 169 cm
M 170 - 179 cm
L 180 - 185 cm
XL 186 - 190 cm
XLG 191 - 195 + cm
TIR = XLG but wider
Riccò "Of the 10 controls taken, only two were positive. In theory all the tests should have been positive, therefore the method needs to be checked," he said.
PostPosted: Wed Jan 30, 2013 1:08 pm
I wouldn't read too much into the Assos size guide
I'm 186cm, 30" waist and wear small Assos bibs
PostPosted: Wed Jan 30, 2013 1:26 pm
bibshorts stretch alot in the vertical exspecially above the waistline. i'd use your waist measurment as the prime sizing metric.
I'm 30-32" waist, 6 foot 1 and always size med for any bibshorts and skinsuits. Some (and not many) bibtights I'm a large but this tends to be italian stuff though. having raced in Italy before I can see why :shock: :?
Dance you cares away, worries for another day, dance your cares away, down at fragglerock.
PostPosted: Wed Jan 30, 2013 1:55 pm
:roll:
I am 183 cm/74 kg. W31. I use XL...
PostPosted: Wed Jan 30, 2013 2:00 pm
I wear a LG at 5'8" and 170lbs and the fit like a second skin....
Gary Solomons
SL4 Roubaix Di2
Surly Cross Check
Surly Necromancer
PostPosted: Wed Jan 30, 2013 2:15 pm
Wow, how do you fit in a small?
I'm 5.8, 29-30 waist and around 134lbs in full training mode and wear assos medium bibs.
I did try small and it worked but I felt it was pulling a lot at my shoulders.
Pfeiffer's Rennrad Camp and Cycling Coach
Independent HED Wheels/Powertap Dealer
PostPosted: Wed Jan 30, 2013 2:19 pm
I am 1.94. Waist34-36 and 100kg.
I wear a XL from Assos.
I think you will fit a XL very well.
PostPosted: Wed Jan 30, 2013 2:23 pm
I am 6'3" and 195 lbs at race weight (won't tell you where I am now) and find the XL perfect. I think even 10-15 lbs lighter they would be tight enough. I find though the straps are okay in a tuck, they are quite short when standing and you are two inches taller than me and I have a very short torso for my height. You may find them a little short if you size down.
PostPosted: Wed Jan 30, 2013 4:07 pm
I wouldn't change sizes for only the bib strap length. Especially tall riders around here take their bibs to a tailor and get the straps extended. I know, it kinda blows to have to do that with brand new, expensive stuff, but you'd do it for a suit too.
PostPosted: Wed Jan 30, 2013 4:56 pm
IMHO the short straps that Assos uses makes perfect sense once your on the bike. The bibs do fit odd when standing around though.
Gary Solomons
SL4 Roubaix Di2
Surly Cross Check
Surly Necromancer
PostPosted: Wed Jan 30, 2013 5:49 pm
yup keep in mind the shoulder straps pull a lot when you stand upright.
If it helps, im 177cm, 68kg and wear medium assos bibs, and I could go with small ones
2013 rocky mountain vertex 29er
­Twitter
www.cyclingtrainingnuts.blogspot.ca
PostPosted: Wed Jan 30, 2013 5:55 pm
Top quality cycle clothing is by nature smaller than normal, like the stuff from Etxe-Ondo and Assos. It has always been that way. Welcome to the world of high quality cycle clothing ...
PostPosted: Thu Jan 31, 2013 3:55 am
I ordered a set of XL's based on waist measurement. We will see how they go.
Thanks for the contributions.
PostPosted: Thu Jan 31, 2013 4:04 am
My opinon is that it is wrong to buy their bibs based on waist unless your body type is at one extreme (which the OP is not). Buy Assos bibs based on your height....as per their charts
I am 181 cm and 165 - 170 lbs.....DEFINITY a size large.
PostPosted: Thu Jan 31, 2013 4:39 am
You are definitely a size L or XL.
I'm 176cm
29 waist
I have FI uno in S and S13 in M. Both fit very similar. The straps on the M pull on my shoulders pretty tight, if I were any taller I would have to go with a large.
Post new topic Reply to topic  [ 45 posts ]  Go to page 1, 2, 3  Next
Users browsing this forum: 6mt, Google Adsense [Bot], robertg and 60 guests
There are no new unread posts for this topic. Need advice on Assos Sizing
poppiholla
Thu Oct 25, 2012 1:52 pm
mattyb95 View the latest post
There are no new unread posts for this topic. Assos Winter Booties S7 - Sizing
Lafolie
Sun Nov 25, 2012 8:39 pm
Lafolie View the latest post
There are no new unread posts for this topic. Assos Bonka jacket vs. Assos Habu jacket
poppiholla
13
1298
Sat Dec 01, 2012 7:49 am
poppiholla View the latest post
There are no new unread posts for this topic. Assos Orange/S2--any stock, anywhere
xrs2
Sat Jun 09, 2012 2:43 am
bluesea View the latest post
There are no new unread posts for this topic. Assos Zegho Sunglasses
xrs2
44
3166
Fri May 17, 2013 11:12 am
Rush View the latest post
It is currently Tue May 21, 2013 3:22 am
