Post new topic Reply to topic  [ 13 posts ]
PostPosted: Tue Jan 29, 2013 10:14 pm
I'm looking at getting some Zipp super short bars to replace my short-shallow bars as they're a little long for me. Struggling to find many pics of them so I can how short they really do look. I don't want them to look like a childs bar! Can anyone confirm if this the bar on Peter Velits bike is the CSL like it says? 'looks' a bit longer than a 70mm reach
http://velonews.competitor.com/2012/05/ ... mac_219921
PostPosted: Tue Jan 29, 2013 11:29 pm
Those look like the SSR bars. I had the CSL SSR (slight oval tops) on my bike but recently replaced them. I needed a little more reach and got a hell of a deal on the Zipp SL carbon bar so swapped it out instead of buying a new stem. Otherwise they would still be on there. If you are interested mine are sitting now and they are like new that I could sell (SC CSL SSR 44o-o).
My bike is a 58cm
PostPosted: Tue Jan 29, 2013 11:47 pm
That is not a csl- look for a picture of Boonen's bike.
PostPosted: Wed Jan 30, 2013 12:35 am
These are the Service Course CSL SSR
www.ergottwheels.com
PostPosted: Wed Jan 30, 2013 3:57 am
pss ergott, dont mean to thread hijack but what are you using to mount your garmin between the bars?
PostPosted: Wed Jan 30, 2013 4:09 am
This, but mine has no graphics on it. I don't know what seller I got it from since it was a while ago. There's even enough room for my headlight since I commute in the dark.
http://www.ebay.com/itm/ACOR-Carbon-Com ... 53f41db90c" onclick="window.open(this.href);return false;
PostPosted: Wed Jan 30, 2013 6:05 am
I've got the CSL Super Short Reach. I switched from an FSA Omega Compact and it is a little shorter reach. I like the ovalized tops as well as more space for your hands when you are on the tops. I'm using a K-Edge mount for my Garmin. Compared to the FSA, it's a bit harder to get the shifters in the right position. The FSA bars had a smoother transition.
PostPosted: Wed Jan 30, 2013 8:28 am
Thanks guys for the feedback and pics!
NWSalpine, unfortunately I'm in the uk so postage costs wouldn't be worth it!
The size of the bar doesn't look that much different from a deda rhm, I loved my zero100 setup but for the life of me I couldn't get them to stop creaking (even with a different zero100 stem) and they were flexy.
I'm also using SRAM, and based on your pics I might get a pair of bars ordered. Velits bike looks to have a smoother transition to the hoods but his bars are slightly rotated up.
PostPosted: Wed Jan 30, 2013 1:59 pm
Here is a side by side comparing the Zipp to the Deda RHM shape. I didn't like the RHM because I need a long flat on the drops. I like that wrist angle better. The levers are indeed a little closer so reach is decreased if you keep the stem the same. The lever height is about the same.
PostPosted: Wed Jan 30, 2013 8:09 pm
ergott-perfect thanks!
I have ordered some Service Course CSL bars which should arrive tomorrow. Hope they work! I need to reduce the reach to the hoods by 10-15mm over the short/shallow version so hopefully they will work. I do like the RHM but find they can be positioned perfectly for the hoods or drops and not both at the same time!
PostPosted: Thu Jan 31, 2013 1:07 am
I took a shot of my computer/headlight mount today so I thought I'd share.
PostPosted: Thu Jan 31, 2013 1:48 am
it's the aspirevelotech mount
i have one too. and i put my light directly under my garmin. really good mount. the best imho
PostPosted: Sat Feb 02, 2013 4:48 pm
My new bars arrived and I'm really pleased with them. The shape is great especially how my hands hook into the drops. I also have one of those mounts from the far east. Tip-go for the plastic version as opposed to the carbon one-they're 20 grams lighter! (i have both)
Users browsing this forum: DaleRider, dgran, Exabot [Bot], Google Adsense [Bot], konky and 72 guests
There are no new unread posts for this topic. zipp sl short & shallow actual weight?
mdeth1313
10
495
Mon Apr 08, 2013 8:50 am
CarpetFibre View the latest post
This topic is locked, you cannot edit posts or make further replies. 2010 super record 11 vs 2012 super record 11
Rumshcawheely
Sun Feb 24, 2013 2:21 am
milroy View the latest post
There are no new unread posts for this topic. Assos bib short sizing - Really???
afie
44
3731
Mon May 20, 2013 3:13 am
bricky21 View the latest post
There are no new unread posts for this topic. anyone know if a short cage sram force will fit a 12-30?
davidalone
Wed May 08, 2013 1:18 pm
djconnel View the latest post
There are no new unread posts for this topic. Long Legs Short Torso - what Giant TCR Advanced SL
Hillman
7
1052
Mon Feb 11, 2013 1:22 am
yeagermeister View the latest post
It is currently Wed Jun 19, 2013 3:52 pm
