Time xpresso pedals
SkippyMcJimmelstein
by SkippyMcJimmelstein
Watch for cracks in the blade, after noticing it mine eventually fell off the right pedal mid ride but was easy to replace after prompt shipping from Time USA :)
limniki
by limniki
I am using Time Expresso Carbon 8 Pro. They seem to work. I have used time for years, starting with the white/red equipe. So far the new carbon pedals have performed as advertised with no sign of cracking. I like the floating and lightweight of the pedals.Plus, they look good on my stealth black colnago.
are
by are
I made the switch from old Look Keo's to xpresso 10s ... really like them, no issues so far at about 1k miles. I hope they continue to work well.
are
by are
Where are people buying cleat covers? I've done some searching online and haven't round anything.
fdegrove
Tubbie Guru
by fdegrove
Hi,
AFAIK none exist since there's no need for any.
Ciao, ;)
Grill
by Grill
fdegrove wrote:Hi,
Ciao, ;)
Except they do...
http://www.ribblecycles.co.uk/sp/road-track-bike/pedals-pedal-shoe-cleats-spares-accs-cleatskins-grips-pedal-cleat-covers/cleapedz200
jackie
by jackie
i had time xpresson carbon 8 on all my road bikes..
i have to admit that the cleats worn off too fast.. but it light and much easier to cleat in and the others.
the floats helps too.
latman
by latman
does anyone know the difference between 8s and 10 s? ....... 2s, 4s, 6s and 12s are clear
brighenne
by brighenne
The 10s have a carbon rather than composite body, which saves a claimed 5 grams.
Also, there's a 15 model, which adds ceramic bearings over the 12 model: http://www.time-sport.com/pedales/xpresso_17_m27.aspx
PLuKE
by PLuKE
Interesting post. I was looking at buying the Xpresso 2 replacing my Shimano R540 to save some weight (110g)
Cleat wear is alarming and pedals snapping!
Luke
vtspot
by vtspot
For the similar price range of DA pedal, i actually opted for time xpress 10. Light weight is my consideration. I didn't go for time xpresso 12 because it is more expensive, and pedal will be easily damaged if crash.
naylor343
by naylor343
I have been using time road pedals since the mid 80's and have sang there praises on this site. After all this time, last month I decided to move onto shimano SL's as I have just become so fed up with the problem of cleat wear. Even after investing in some very effective cleat covers and having a policy of never walking anywhere without them, I still found the newer time cleats to wear out unacceptably quickly.
It was a very hard decision to make as I was worried I would not cope with the more limited float, but have to say I wish I had changed them years ago. I must add, that if I felt I still needed the extra float I would have gone back to them and if people need that extra movement then they are perfect. But if you do not need the float then I would not recommend them with the current cleats as they are.
russianbear
by russianbear
Just want to follow up, it wasn't actually the pedals making the clicking sound. I'm having some UT bearing issue on the non drive side. For once the "bb creak" is coming from the bb!
latman
by latman
deleted
brighenne
by brighenne
brighenne wrote:The 10s have a carbon rather than composite body, which saves a claimed 5 grams.
I was the next post after the last time you asked.
