It is currently Wed Jan 17, 2018 12:22 pm
Post new topic  Reply to topic  [ 628 posts ]  Go to page Previous 114 15 16 17 1842 Next
 Post subject: Time xpresso pedals
PostPosted: Thu Jun 19, 2014 5:31 pm
One other question, just making sure: are the old rxs cleats incompatible with xpresso's?
Would be dandy if you could use the old cleats on the new platform.
EDIT: I see now they are not compatible.
 Post subject: Re: Time xpresso pedals
PostPosted: Thu Jun 19, 2014 6:52 pm
natiedean24 wrote:
I keep getting sucked into looking at the new xpresso 8. For those that have experienced fast cleat wear with this model, what is the symptom? Noise, hard to clip in or out? Where does the clear wear?
Thanks.
I have used time for 20+ years. In the last year I have moved from RXS to expresso. I personally have not found too much difference in the amount of wear between the two different cleats, If anything the I found the RXS red cleat lasted the longest and the expresso is better than the RXS blue. What has made a huge difference is using the café cleat covers. I use them religiously when going to the garage to get my bike and re-fit them the second I get home before walking more than two steps. Now I find that I am only getting a small amount of wear on my left, the foot I disengage first and will put down if I stop at a junction.
I had been using the RXS Ti/carbons and was gonna go for the same in the expresso, but first purchased the expresso 6 to try them out. I never bothered with the more expensive pedals after that, the 6's have been superb, they are super light compared to the equivalent RXS model at the same level and cost a fraction of the price of the Ti or carbon models.
PostPosted: Thu Jun 19, 2014 10:45 pm
I agree with the previous post, I have Xpresso 6's and can't see much reason to buy the more expensive options...other than some sharp pedal edges I like them a lot...
"It's not the destination...it's the ride!"
PostPosted: Fri Jun 20, 2014 12:22 am
Their fine. Cleat wear isn't really an issue unless you're doing it wrong.
Sent from my Galaxy Nexus using Tapatalk
PostPosted: Fri Jun 20, 2014 8:45 pm
Not sure if it's been mentioned, but you can now buy cleat covers for Time/Mavic.
PostPosted: Sun Jul 06, 2014 9:51 pm
dcaspira wrote:
dgasmd wrote:
One thing to mention for the life of me I can comprehend why is even there is the very sharp corner in the middle outside edge of the pedal. I can see someone cutting their leg pretty good with this thing
Yep - I've cut my leg up. Then got a file out, and filed the outside corners down to a 5mm rad - I recommend this as the first thing you do when you buy a set.
How do you go about filing the pedal? Just a straight file along the edge?
What kind of file?
You would think I would learn my lesson but I currently have 5 cuts on my left calf, 3 of which will probably scar :oops: :shock:
Think it was because I was so used to my RXS' and I don't move my foot out far enough when unclipping!
Cheers
 Post subject: cleat wear
PostPosted: Fri Jul 11, 2014 5:58 pm
I found an interesting review with pictures by bikeradar. (pictures below linked from that article)
New cleats:
Cleats after (what they say is) 3 months:
No idea if this is excessive, or how many miles in that period, or if this is representative. All I know is that I have 4,000+ miles on my current RSX cleats with barely any wear. I clipped in my shoes and tested for wobble at the platform - none.
It's such a good design. So abnormal for me to pass up the latest, but I just got in a new set of RSX pedals in leiu of the xPresso. hope they last me as long as my previous set.
PostPosted: Sat Jul 12, 2014 10:56 am
^ None of the worn surfaces on these cleats are contact points with the pedal. There would not be slop on the pedal from this. They just wear when you walk on them. Not an issue.
Cheers
MAMIL? Never. O.F.I.L. yeh! (Old F**ker in Lycra)
PostPosted: Sat Jul 12, 2014 11:14 am
Administrator
@ natiedean24
I ride in multiple sets of shoes but my oldest cleats which go back 14 months look nothing like that. When on the bike I do very little walking since you should be riding your bike. Those look like cleats that someone took a long walk home after a mechanical.
IMHO
RESIDENT GRUMPY OLD MAN.
PostPosted: Sat Jul 12, 2014 1:39 pm
Man, that's ridiculous. Is dude like hiking down a gravel road before and after each ride? Get some mountain bike shoes and pedals dude. :idea:
PostPosted: Sun Jul 13, 2014 10:36 am
Yeah cyclocross on road pedals is a bit silly.
My cleats last at least 1 season then are replaced preventatively. But then I have no gravel on my drive and almost never drag or slide my foot on the ground. Key is to stop the bike then unclip. Simple.
PostPosted: Mon Jul 14, 2014 2:28 am
i have zero issues with over 1500 km on mavic slr ti. the pedals last as long a my old keos :(. loving the float/release mechanism
btw next year they go to 15... 133gm a pair f*** light. ceramicspeed bearing hollow ti axles
Current Rides:
2017 Giant TCR Advanced SL 0 DI2 9150
PostPosted: Mon Jul 14, 2014 7:33 am
Probably a lower weight limit too :(
PostPosted: Thu Aug 21, 2014 8:59 am
Bumping an old thread. My pedals started making a clicking noise, just the right pedal. Pretty bummed since I really like the pedal system.
PostPosted: Thu Aug 21, 2014 10:42 am
Administrator
Is there play in the bearings? If so contact TimeUSA and they will replace the bearings. Turn around time will be about a week.
There are no new unread posts for this topic. TIME XPresso 12 Pedal Modification (by EZO bearings)
mortirolo
16
785
Mon Jan 08, 2018 6:11 pm
Hawkwood View the latest post
There are no new unread posts for this topic. Time XPro pedals - any details?
BdaGhisallo
34
3348
Wed Jan 03, 2018 11:10 pm
AJS914 View the latest post
There are no new unread posts for this topic. Powertap P1 Pedals
mattCSUK
Fri Feb 24, 2017 5:41 pm
Butcher View the latest post
There are no new unread posts for this topic. pedals advice?
Musiker
10
1521
Sun Jan 07, 2018 9:01 pm
IrrelevantD View the latest post
There are no new unread posts for this topic. Power2max vs powertap pedals? Help!!
TurboTommy
7
1134
Fri Mar 17, 2017 7:55 pm
TurboTommy View the latest post
Users browsing this forum: benzebub, Bing [Bot], Broady, coriordan, Ettore, Greatestalltime and 50 guests
cron
