Post new topic Reply to topic  [ 5 posts ]
PostPosted: Sat Jan 26, 2013 9:26 pm
Hi,
Maybe a weird question but I'm building a road bike with discs. I wanted to use the standard steel fork that came with my frame but my disc is just touching the fork ever so slightly. One option would be to try and dent the fork in this particular area, but it is risky and after that I would need to weld disc tabs on the fork.
As an alternative I could by a new CX disc ready fork. Only problem is I also want to run some electronic gizmo's on the bike that requires a cable to enter through the steerer tube. So is it possible to enter the steerer tube through the brake mounting holes on the crown of this particular fork?
Thanks
    2011 Cannondale Flash F1
      2010 Cannondale Caad9
        2000 Cannondale Caad 4 aero
          1999 Cannondale Caad1
            ???? Concorde SS
PostPosted: Sat Jan 26, 2013 10:34 pm
if the fork steerer tube has an exit hole at the bottom then you should be able to route the electronic cables down and out, minding clearance for the tyre, I have done this and it is a neat looking improvement. As for the brake lines, I would avoid and stay safe, plus the cable would have to bend in ways that would make the inner wire keep sticking with the friction.
Because they are brakes, I would leave as is.
No, I am not trying to sell you something.
PostPosted: Sat Jan 26, 2013 10:39 pm
I meant electronic cables, yes.
This fork is not open on the bridge in between the legs. That's why I want to know if it's possible to run a cable through the mounting holes for a road brake or mudguards.
            ???? Concorde SS
PostPosted: Sun Jan 27, 2013 2:51 am
If the end of the steerer is closed, then the brake mounting hole is not open to the steerer tube.
You could drill a small hole from inside the steerer to break into the brake hole, but that would require a long drill extension and the likelyhood of being able to drill an accurate and straight hole like that is low. I would not be comfortable drilling a big hole in it, especially when I can't see what's going on down there.
PostPosted: Sun Jan 27, 2013 3:04 am
Shop Owner / Manufacturer
You could drill a hole through the bottom of the bridge into the steerer tube and then block the external hole with a Velo Plug or even a piece of PU (like the clear pieces that are used to protect your HT from wear caused by the shift cables).
Having the hole there might even help you while you are routing the electric cable(s). Covering it over would be the last step.
BDop Cycling Co., Ltd.
www.bdopcycling.com
Users browsing this forum: coppercook62, fa63, KWalker, psbot [Picsearch] and 64 guests
There are no new unread posts for this topic. Cervelo steerer tube insert ?
jtsoderman
Mon Mar 11, 2013 9:01 pm
Permon View the latest post
There are no new unread posts for this topic. Gap inside stem to fork, steerer tube
tri
Wed Sep 26, 2012 10:05 am
ttts2 View the latest post
There are no new unread posts for this topic. Talk to me about stiffening up a flexy steerer tube
FastforaSlowGuy
24
960
Sat Mar 23, 2013 5:25 pm
Privateer View the latest post
There are no new unread posts for this topic. Fork Question: 1.125 Steerer in Tapered Head Tube ?
ldamelio
Wed Dec 19, 2012 1:54 pm
btompkins0112 View the latest post
There are no new unread posts for this topic. Super 6 evo,steerer top cap
logy
11
1608
Mon Sep 17, 2012 1:10 pm
leosantos View the latest post
It is currently Sun May 19, 2013 10:53 pm
