Post new topic Reply to topic  [ 12 posts ]
PostPosted: Fri Jan 25, 2013 7:48 pm
It doesn't affect me, but it will affect quite a few users here:
http://www.bikeradar.com/news/article/s ... els-36271/
Specialized is recalling the forks on all iterations of the 2012 Tarmac SL4, 2013 Tarmac SL4, 2013 Crux and 2013 Secteur Disc bicycles and framesets. The forks are being recalled after a few instances of a carbon fiber steerer tube cracking or breaking. The recall affects approximately 12,200 bikes in the US.
Exp001
PostPosted: Fri Jan 25, 2013 8:00 pm
Maby they should have tested a bit more. Would have been cheaper in the long run.
It's online again:The Machinist
PostPosted: Fri Jan 25, 2013 8:37 pm
First as the previous owner of a '12 sl4 and current '13 venge(not mentioned in recall but uses same steer tube I thought, emailed specialized for clarification) the US consumer product safety report says there was 2 reported incidents of failure. Hopefully it stays at that number and if so I would hardly say .016% failure rate is a sign of a cheap product or poor testing protocols.
PostPosted: Fri Jan 25, 2013 8:54 pm
The failure rate is low (for now) and the recall keeps it low. Where it should be.
When they did the risk assessment, they would have dragged out all the testing and the specification sent to the builders of what exactly they ordered. Obviously, they didn't have enough confidence that these were isolated incidents and could not isolate the problem nor predict what might next happen.
Like bikes, performance sail-boats have to be strong, stiff and light, and designers and builders always fight over weight, cost and build materials/methods. The designer wants the boat to be perfect and to weight and the builder wants it to be simple and cheap to produce. So you get situations where the design states that x layers of T1000 carbon should be used with a special epoxy, and the builder uses y layers of fibreglass and polyester resin (ok that's a bit extreme to prove the point). The two structures are the not the same weight, stiffness, nor strength and that's when accidents occur...
PostPosted: Fri Jan 25, 2013 9:05 pm
I would think this should include the Allez Race as well since it has the Tarmac fork.
PostPosted: Fri Jan 25, 2013 9:19 pm
That's why I emailed for clarification. It seems a lot of models use the same tapered carbon fork steer beyond what is listed.
PostPosted: Fri Jan 25, 2013 9:49 pm
That's what I'm afraid of. I was hoping to start building the bike this weekend.
Sent from my iPad using Tapatalk HD
PostPosted: Sat Jan 26, 2013 3:23 pm
Interesting that they are repairing the forks by installing a carbon sleeve inside the tube. You won't be riding your bike for a couple of weeks. But you also get a $100 gift certificate. I'd rather get a loaner bike.
PostPosted: Sat Feb 16, 2013 11:00 pm
Well I cant moan - took my Tarmac SL4 fork in last Monday and theyd sent a brand new one as a replacement by Thursday along with my £100 voucher. :lol:
PostPosted: Sun Feb 17, 2013 1:16 am
Though I don't have an affected fork, I have recently dealt with Specialized warranty department.
They were at all times incredibly courteous and always the model of professionalism. I was really impressed.
Hopefully everyone affected by this gets their fork sorted soon and is out on the road as soon as possible.
PostPosted: Sun Feb 17, 2013 1:44 am
The new forks simply have another carbon tube glued inside the regular one. Such a chop job. Specialized's quality is really going downhill.
PostPosted: Sun Feb 17, 2013 4:50 pm
Please don't criticize Specialized's quality. Those skilled Taiwanese Artisans have feelings. Feelings and a passion for cycling.
Users browsing this forum: Bing [Bot], Google [Bot], kya, MichaelB and 41 guests
There are no new unread posts for this topic. Carbon road fork with fender eyelets
Kevin3182
Fri Mar 22, 2013 3:58 pm
Svetty View the latest post
There are no new unread posts for this topic. EE Brakes Safety Recall
x43x
9
1594
Thu Sep 20, 2012 3:02 pm
HammerTime2 View the latest post
There are no new unread posts for this topic. Fork expander för Colnago fork ?
PSM
Thu Nov 22, 2012 11:03 am
PSM View the latest post
There are no new unread posts for this topic. Attachment(s) Specialized OS BB
[ Go to page: 1, 2, 3, 4, 5 ]
rhyslewisdavies
60
6203
Wed Apr 24, 2013 7:10 pm
phorapples View the latest post
There are no new unread posts for this topic. Specialized Srm - BB compatibility
micky
Sat Apr 20, 2013 10:35 pm
Machinenoise View the latest post
It is currently Mon May 20, 2013 9:54 am
