Post new topic Reply to topic  [ 25 posts ]
Go to page 1, 2  Next
PostPosted: Thu Jan 24, 2013 1:48 am
I purchased a used SHIV TT from the disbanded Highroad team in January 2012. It was the bike that Tejay VanGarderen rode in domestic races. Awesome bike. Super custom features and details: battery mount on saddle, custom stem with port for Di2 control box and more. Perfectly UCI legal (acknowledged with a hi5 from the tech at US Masters Nationals). Love this bike. But hated the color scheme.
I had my team shop, Adventure Cycle in Aurora Colorado, tear it down. Then took it to my Audi dealer, Prestige Imports. This is official Audi Brilliant Black across the frame, stem, seat post, bar and extensions. I found a guy in Luxembourg to execute custom size die-cut decals. I'm super happy with the new look. Every cable is hidden. The cable holes in the top tube have been filled in and now present a seamless top tube to stem profile.
A couple of updates from Tejay's setup: New 2012 Fizik Ares (more padding in the nose), SRM DA 7900 177.5, replaced the rear brake V-pipe with Nokon cable (much better brake modulation).
Scott
File comment: Original SHIV TT
File comment: New SHIV TT with Stinger 9
File comment: With H3D
File comment: Updated PRO Missle EVO cockpit
File comment: Custom stem and updated top tube
File comment: Custom Di2 Battery Mount
File comment: Jagwire for rear brake
File comment: Frame Only
PostPosted: Thu Jan 24, 2013 1:58 am
Nice!!!! How did they strip the existing paint?
http://djconnel.blogspot.com/
Fuji SL/1
PostPosted: Thu Jan 24, 2013 3:04 am
Hand sanded every inch of the frame, fork, bar and extensions. Stem is painted CNC'd aluminum and the seat post was nude carbon with a gloss clearcoat.
PostPosted: Thu Jan 24, 2013 12:19 pm
Nice bike! Are you sure UCI compliant? Angle of the extensions plus your forearms when you are on the bike?
http://www.uci.ch/Modules/BUILTIN/getOb ... Y&LangId=1
PostPosted: Thu Jan 24, 2013 1:55 pm
Legal like Phinney? :wink:
http://www.cyclingnews.com/races/uci-ro ... tos/239097
PostPosted: Thu Jan 24, 2013 4:33 pm
Yes, I've had my bike measured three separate times on this very sophisticated UCI developed tool:
PostPosted: Thu Jan 24, 2013 6:42 pm
Scott
Gorgeous bike. How much did the audi dealer charge you for the paint job?
-EP
PostPosted: Fri Jan 25, 2013 4:39 pm
Looks nice, but what a shame to mutilate a Pro bike...
PostPosted: Fri Jan 25, 2013 4:48 pm
Looks bad i black. You should change the chainring to something black.
IMHO i liked it better in the pro colors. But hey, it's your bike and it looks killer either way!
Storck Fenomalist 6.3kg.
BMC Teammachine SLR01
PostPosted: Fri Jan 25, 2013 5:02 pm
Nice work!
How long did sanding the frame take you? Did you go all the way down to bare carbon, or just the top layer of paint?
Sent from my iPad using Tapatalk HD
PostPosted: Fri Jan 25, 2013 5:32 pm
To all.
The sad reality of the original bike, even though it was claimed to have less than 5 race days on it, was that the paint was hammered. The lo-res web images make the original bike look super cool, but the bike up close was less than stellar. It's such an amazing machine but it looked horrible.
The yellow and green highlights were a rough combination. The wheel graphics were just stickers and they easily peeled off. The rear disc stickers (both sides) must have weighed 150g total. They were super thick and ran from braking surface to hub.
My decision was also based on the optic of our team kit which is blue and black. And I have a Venge and Tarmac SL4 both in Matte Black, so I wanted all to match.
The original SHIV frame set and PRO Missle EVO was painted as noted previously. The paint was applied over nude carbon then sprayed with a matte clear coat. The Audi team sanded down to the carbon base in order to eliminate any ridges from the original layers.
They then sprayed one thin layer of Brilliant Black over the entire frameset including post, stem, bars, extension and pad cups. Total time for the process was 4 days.
Net change in weight was +34g over the original, before decals. If you add the wheels in (post sticker removal) I'm down around -100g overall.
Total costs for bike disassembly, paint, rebuild : $810US
Hope that helps.
SM
PostPosted: Fri Jan 25, 2013 7:29 pm
How did you get your extensions to pop up like that? From here it looks like a little shim of sorts?
Also, you should be able to get the rear brake cable run much cleaner. It took some finagling, but I was able to get my Shiv cabled very tightly in this area with supplied parts. Cool bike!
PostPosted: Sat Jan 26, 2013 8:12 am
scottmellin wrote:
nice.
angled shim on top of the base bar and below the extensions? how do you like it with the pads angled back? i would think you'd want another angled shim (facing the opposite way) atop the extension and below the pad to correct the angle of the pads.
the selective enforcement of rules at nationals is a bit silly to me (e.g., forearms not flat). my opinion is to enforce them all or enforce none of them.
how do you like the h3d on the front? it would probably be a handful for me.
PostPosted: Sat Jan 26, 2013 4:45 pm
oh god, why? :cry:
PostPosted: Sat Jan 26, 2013 5:07 pm
Great work, looks stunning!! I know there is a lot of hate toward black stealth bikes but I think this is great!! Lets be honest, the horrific Highroad team color scheme was never going to be a classic...
Post new topic Reply to topic  [ 25 posts ]  Go to page 1, 2  Next
Users browsing this forum: Exabot [Bot], giant man, Google Adsense [Bot], LinasR, spOOn1965 and 44 guests
There are no new unread posts for this topic. Specialized Shiv
TriRig
11
1467
Sun May 05, 2013 8:03 am
verycreativeusername View the latest post
There are no new unread posts for this topic. Red Bull Specialized Shiv Tri...
mile2424
Wed Feb 27, 2013 7:04 pm
prendrefeu View the latest post
There are no new unread posts for this topic. Specialized S-WORKS Shiv Tri...
mile2424
Wed Apr 10, 2013 9:27 pm
mile2424 View the latest post
There are no new unread posts for this topic. Red Bull Racing Specialized Shiv Tri
mile2424
7
964
Fri Jun 01, 2012 5:12 pm
speks22 View the latest post
There are no new unread posts for this topic. Specialized Shiv XL frame module for sale 3200
itsacarr
Tue Apr 30, 2013 4:06 am
itsacarr View the latest post
It is currently Mon May 20, 2013 8:23 pm
