Post new topic Reply to topic  [ 37 posts ]
Go to page Previous  1, 2, 3  Next
PostPosted: Thu Jan 24, 2013 6:21 pm
Both English frames/bikes are great.
PostPosted: Thu Jan 24, 2013 6:22 pm
CharlesM- Any idea on the weight difference? A few hundred grammes?
PostPosted: Thu Jan 24, 2013 7:22 pm
Seeing this bike, one thought immediately came to mind... if Hugh Heffner and one of his Playmate wives were bicycles, this is what the offspring would look like. A mix of very old and very new. Frankly, I like it... except the fork. I prefer a straight-blade fork.
Now back to the topic...
CharlesM wrote:
TED ESSENFELD
Schoorl, Noord-Holland, Nederland
Bike Pics
English Custom Steel Internal di2
Litespeed Ghisallo
PostPosted: Thu Jan 24, 2013 8:09 pm
Formerly known as PezTech
No... I've held a cut piece of tubing and the diffs for a given length of high end steel tubing is not double the weight of the appropriate length carbon...
Remember that an ISP doesn't have a big overlap of materials like a standard seat post that gets pushed into a frame will have. And most carbon seat posts are built with fairly thick walls to fight being crushed.
So an ISP will be the weight of the tube length and the mast topper. Fairwheel have mast toppers at and below 100 grams. The steel seat tube for the ISP will depend a lot on the geometry, but a full length tube that is 25 inches of ms2 straight gauge steel tubing (28.6mm) weighs 340 grams. That's only 13.4 grams per inch and most folks will only have what, 5-6-7 inches? 80 grams for a 6 inch ISP... Thats an ISP weight some place near 180 grams plus or minus...
For a traditional seat post you'll have the seat post it's self, including the saddle mounting hardware and that will likely be near 200 grams. You'll also have the seat post clamp and bolt that for steel is going to weigh 10-20 grams...
This is just generally speaking and people can tune both things, but I would bet the seat post versus ISP difference would be damn near nothing for most folks. Certainly not a couple of hundred grams.
charles@pezcyclingnews.com
PostPosted: Thu Jan 24, 2013 8:15 pm
Could you be a bit more specific?
PostPosted: Thu Jan 24, 2013 8:16 pm
Just kidding!
Thanks very much for that. Very informative. Food for thought.
PostPosted: Fri Jan 25, 2013 1:36 am
I had this same debate with myself. I have a custom frame built from Columbus Spirit and my builder thought it would be better to just cut a seatpost short given my other desires: I wanted a pretty traditional style "parallel to the ground" top tube and the ability to adjust up and down a few MM for different saddles, etc. You can do this with a mast, but a Thomson cut down for the same frame is pretty light (I'll have to weigh it... but FWIW Im using an Elite at the moment cut with just enough in to be safe, debating on setback or 0 setback Masterpiece). It's half an aesthetic thing, which makes it hard.
If in doubt, go with a seatpost. If your frame is going to be more compact (and you need more post as a result) then a mast will probably be lighter.
As for carbon vs ti vs alu... it depends on your cockpit, I guess. With steel I think you don't need as much deflection (though I am debating a setback post) and Thomson (and a few others) make alu posts that are just as light (or lighter). I ended up with a Thomson stem and using the old rule of stem matches bars made it a no-brainer. If you're hellbent on the lightest setup, ignore that rule.
If you get a mast, see if your builder will do an integrated stem/bar... that would be very pretty and rather light.
PostPosted: Fri Jan 25, 2013 4:29 am
When you can use Smud Carbon in-line seat-post at claimed 95g for a 300x27.2mm (or New Ultimate alloy in-line <150g), std seat-post is the ww way (not discussing ride quality or aesthetics).
I have a cut-down Thomson Elite in-line weighing 134g, to compare.
PostPosted: Fri Jan 25, 2013 6:07 am
That doesn't read very clearly: I'll expound.
I played out the exact same scenario of to-ISP-or-not, so I cut down my Thomson Elite to about 100mm in anticipation of having an extended seat-tube with normal brazed bolt arrangement. The cut-down seat-post weighs 134g.
Compare these:
carbon seat-post (Smud Carbon) - 95g
steel ISP - +100g & length of extended seat-tube
cut-down Thomson Elite - 134g + extended seat-tube
I've chosen to go standard seat-post and not ISP.
PostPosted: Fri Jan 25, 2013 8:51 am
Mine too will be traditional geometry. At 61cm and not throwing my cheque book at the build, it's not going to be super WW. Though both eyes are on the grames.
I prefer the aesthetics of an internal 'post' in a mast vs a cap. But for me, if it's boiling down to purely aesthetics with an ISP then I'm erring towards going with a post. It's seeming like a lot of unnecessary work joining two tubes to make one. Especially given that the likely hood is there'll be a weight penalty.
PostPosted: Fri Jan 25, 2013 8:59 am
mattydubs- Any photos of your frame?
PostPosted: Fri Jan 25, 2013 9:27 am
shimmeD- Is yours built? Any photos.
PostPosted: Fri Jan 25, 2013 12:16 pm
What about the comfort of ISP vs. seatpost?
PostPosted: Fri Jan 25, 2013 3:21 pm
Any answer would be a generalization that wont apply to all things...
different seat post types and different tubes used for ISP mean that the answer would need a more detailed question.
PostPosted: Fri Jan 25, 2013 4:28 pm
Just spoke to the builder. Think I'm going to ditch the ISP idea.
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2, 3  Next
Users browsing this forum: Bing [Bot], BmanX, Exabot [Bot], genesis692, Google Adsense [Bot], tommasini and 61 guests
There are no new unread posts for this topic. Replacing Carbon Frame with Custom Steel
photocycler
40
2353
Sun Mar 10, 2013 10:46 pm
Ride-Fly View the latest post
There are no new unread posts for this topic. Shorten seat post...?
Juggler
Thu Nov 01, 2012 4:28 pm
Juggler View the latest post
This topic is locked, you cannot edit posts or make further replies. Seat post recommendations
Penthousepete
Sat May 04, 2013 5:25 am
cyclistcong View the latest post
There are no new unread posts for this topic. Attachment(s) Trek 4.7 Seat Post Clamp
darth
Sat Nov 03, 2012 2:32 pm
darth View the latest post
There are no new unread posts for this topic. light seat post collar?
ninjanoir78
Fri Jun 08, 2012 6:23 pm
bm0p700f View the latest post
It is currently Wed May 22, 2013 4:47 am
