Post new topic Reply to topic  [ 6 posts ]
PostPosted: Mon Jan 21, 2013 11:45 pm
Hey guys, I've been pretty happy with my speedneedle marathon for the last couple of years but over time its starting to go a bit funny on the exposed carbon section.
The fibres / weave is still there and looks ok but its like the resin or at least the top coat is wearing away, leaving the fibres dry and exposed. It's getting a white, chalky appearance to it, which is made worse if you scratch it with your finger nail.
I was thinking of applying some spray on clear coat to protect it and make it look better again. Does anyone have any other suggestions? The spray might not last that long but at least its easy to apply.
You can't be a real country unless you have a beer and an airline. It helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer.
-- Frank Zappa
PostPosted: Mon Jan 21, 2013 11:46 pm
Sorry for the rubbish photo, using my phone at the moment.
-- Frank Zappa
PostPosted: Tue Jan 22, 2013 12:34 am
Tubbie Guru
Hi,
Pretty normal after a couple of seasons of use IME. A fresh layer of clearcoat surely helps....for a while. :)
Ciao, ;)
PostPosted: Tue Jan 22, 2013 1:38 am
Cool, I assumed so, thanks for the confirmation. I'll spray it with clear coat and see how it goes.
-- Frank Zappa
PostPosted: Tue Jan 22, 2013 3:54 am
You might consider using a polyurethane clear coat specific to plastics. I personally don't use any clear coat on the Veloflyte items I produce. But I have experimented with using an acrylic clear coat. Acrylic is not durable enough for your application.
You could also apply a thin coat of epoxy. But I do not know if epoxy will provide a more or less durable finish than polyurethane.
PostPosted: Tue Jan 22, 2013 11:36 am
Thanks for the advice. I have some clear coat spray so will use that immediately while I look into the other options you mentioned. I'm sure the spray won't last long.
-- Frank Zappa
Users browsing this forum: Bing [Bot], Nismo4x4 and 54 guests
There are no new unread posts for this topic. 89 gram Tune Speedneedle?
CGT
Mon Oct 08, 2012 9:21 pm
CGT View the latest post
There are no new unread posts for this topic. Attachment(s) Tune Speedneedle owners out there!! Saddle Height? :) :)
Estuche
Mon Oct 08, 2012 5:37 pm
Estuche View the latest post
There are no new unread posts for this topic. Recommendations on 25c and 28c Tubeless tires?
thatdkid
10
594
Fri May 17, 2013 4:02 am
tinozee View the latest post
This topic is locked, you cannot edit posts or make further replies. Seat post recommendations
Penthousepete
Sat May 04, 2013 5:25 am
cyclistcong View the latest post
This topic is locked, you cannot edit posts or make further replies. New Pedal and Shoe Set-up - Recommendations???
dehugo75
Tue Mar 12, 2013 10:40 pm
BdaGhisallo View the latest post
It is currently Fri May 24, 2013 10:43 pm
