Post new topic Reply to topic  [ 23 posts ]
Go to page Previous  1, 2
PostPosted: Mon Jan 21, 2013 5:53 pm
Anders wrote:
Elrey wrote:
Looks good, but how do you know if it needs any finishing clearcoat. I'm not talking looks here.
And how do you know when to stop and do go all the way to the carbon fiber.
It doesn't need the clear coat but it's very hard to get all clear coat off especially close to the aluminium flanges. So yes it was applied due to the look, it would look very bad without. You can see when you break through the clear coat, you get some black dust :-) Most important is to get the surface smooth before applying the clear coat, removing scratches by finishing with in my experience minimum corn 320.
I removed all clear coat on my Selle Italia C64 saddle and left it raw, but this turned out better as the surface was more even and therefore easier to get smooth all over.
very cool. what does the rest of the bike look like?
PostPosted: Mon Jan 21, 2013 9:10 pm
Have a look here viewtopic.php?f=10&t=59781&p=953229#p953229" onclick="window.open(this.href);return false;
It's online again:The Machinist
PostPosted: Tue Jan 22, 2013 4:04 am
Greenduck wrote:
Hi
I sanded my FSA SL-K Light crankset to remove the logo and graphics and gave it some clear coat. The result came out nice but I actually don't like the glossy look. So I want to sand it down again and keep the matte raw carbon look. However, I think the carbon should be treated with someone to protect it from sunlight, water etc.
Will a matte clear coat do it otherwise I've heard someone just using auto wax to give it a protective layer? Whats the best process?
Given the fact that most of us rub our feet up against the crankarms as we are pedaling, I think it would be best if you apply a tough clear coat. Polyurethane might be the best. In most instances, it proves to provide the most resilient finish.
PostPosted: Tue Jan 22, 2013 5:04 am
:roll:
My face when I read that people still use, and recommend, 303 to protect their raw carbon frames:
Why use a product that does not last, costs a lot, and needs to be re-applied?
OptiCoat 2.0, kids. It will last permanently. A "box" is one syringe and an applicator pad, enough to cover two cars... which is enough to cover more than a few frames and components.
Cleaning?
I use this after cleaning with an IPA mix.
Expand your minds!
Exp001
PostPosted: Tue Jan 22, 2013 8:38 am
Thanks for the advice... I will certainly look in that direction, when it is time to re-apply protection on my crankset.
PS. No need to do the :roll: ... if you (e.g. me) don't know better, you recommend whatever have worked for you in the past.
2012 Canyon Aeroad CF 8.0 Di2 (6.250 grams)
2010 Canyon Grand Canyon F6
2012 (2013?) Canyon Speedmax Evo (is ordered)
PostPosted: Tue Jan 22, 2013 8:43 am
The :roll: wasn't at you specifically!
But yes, you are correct, it was not necessary.
Exp001
PostPosted: Tue Jan 22, 2013 8:52 am
No pun taken... :)
Now back to the subject. In what part of the process do you use the Chemical Guys stuff? Before applying the OptiCoat, or for day-to-day cleaning after having applied the OptiCoat?
PostPosted: Tue Jan 22, 2013 9:26 am
I only applied the Opticoat once, that's all that is needed. I applied it to all of my carbon parts (all were sanded to matte with 3M 2601 pads) to ensure that they all had the same level of protection. You can hear it "squeak" a little bit when you rub it on with the applicator pad, then the super thin compound quickly dries to clear with hardly any noticable addition to the part's finish. I've found that if you use it on glossy finish, the result is glossy. If you use it on matte, the result is just barely between satin and matte (but more matte). Apply opticoat to clean parts, so you need to clean them very thoroughly first to ensure there is nothing held between the opticoat compound and the surface of the actual material.
Day-to-day cleaning... maybe a quick wipe with a rag and one of the spray bottle mixes I describe below if the dirt is enough to make me want to clean it off.
I'm a bit thorough on my bike cleaning (and have been requested to make a thread about how I go about it by several people, just haven't gotten around to it), so I clean the bike about once per week on average, at most three weeks between a good cleaning. While the drivetrain bits are sitting in the ultrasonic cleaner, I clean the everything else. I use a simple IPA solution (approximately 50/50 mix of clean/distilled/filtered water and rubbing alcohol) sprayed onto the bike & parts, wiped down with a rag. This will dry clean without any trails and pretty quickly, too. It's also cheap and I can attack clumps of dirt fairly easily with it. Grease spots are very rare, but in case I also have a spray bottle of diluted dish washing soap and distilled water. Then I spray & rub on a coat of the Matte Detailer. It helps, in my experience, to minimize dirt as matte finishes tend to show dirtiness quicker. It also makes the next quick wipe easier to clean. And I think it smells pleasant.
That's about it, really. The drivetrain on the other hand... that's some obsessive territory. :lol:
[ If you live in an area where the city's infrastructure provides good water, then using distilled water isn't necessary. Unfortunately Los Angeles has fairly bad water coming from the tap compared to most modern cities, so I use the water from my filters. ]
Exp001
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
Users browsing this forum: anniversary, Bing [Bot], Butcher, Google Adsense [Bot], jarnos, n8davies, wassertreter and 59 guests
There are no new unread posts for this topic. WoundUp Carbon Fork, Matte Finish, Looking for Pics?
Snicks
Mon Oct 08, 2012 3:51 pm
Snicks View the latest post
There are no new unread posts for this topic. Repairing clear-coat on carbon parts
Master-Ti
Wed Oct 17, 2012 2:19 am
fdegrove View the latest post
There are no new unread posts for this topic. Attachment(s) Whisky Parts Co. No.7 carbon front fork
SWijland
Sun Aug 05, 2012 2:08 pm
Wingnut View the latest post
There are no new unread posts for this topic. Matte color ???
Naturel
Thu Jun 14, 2012 11:11 pm
rico View the latest post
There are no new unread posts for this topic. Attachment(s) New THM matte brakes
coppercook62
14
2037
Mon Jul 30, 2012 3:17 am
thatdkid View the latest post
It is currently Fri May 24, 2013 1:40 pm
