Post new topic Reply to topic  [ 45 posts ]
Go to page 1, 2, 3  Next
PostPosted: Sat Jan 19, 2013 5:09 pm
Are some of the aero benefits from the latest wide profile wheels negated - Claims of improve grip / larger tire contact area must result in more rolling resistance?
PostPosted: Sat Jan 19, 2013 5:23 pm
I don't think there is much of a change in surface area when going from a standard to a wide rim (assuming you use the same tire/size). The wide rims simply allow the tire to sit in a less bulbous shape which will make cornering feel slightly more predictable and stable.
http://www.zencyclery.com
http://www.wheelbuilder.org
PostPosted: Sat Jan 19, 2013 6:01 pm
Less sidewall deformation from wider rims reduces, rather than increases, rolling resistance.
In theory wider tires should have less rolling resistance at the same tire pressure (to a limit) but typically increased sidewall deformation cancels that advantage. Going to wider rims restores it. The theoretical contact patch of least resistance is a circle.
http://djconnel.blogspot.com/
Fuji SL/1
PostPosted: Sat Jan 19, 2013 7:27 pm
Tubbie Guru
Hi,
Further to what djconnel says: you'll find the best narrow tyres to have the highest tpi count and a thin(-ish) thread. Up to 350 tpi using the best quality cotton or silk fiber tissue.
Studies have shown that on average a 23mm wide tyre is a better choice for road use since it exhibits the smallest set of compromises all factors considered.
To further optimise this you'd also need a rim that's a bit wider than the typical 19 to 21mm wide rim bed or else it would be an aerodynamic misfit.
The only tyres that can approach a circular shape contact area are latex track tyres. A decent road tyre will have an oval shape contact patch where ideally the edges are orientated lateraly across the tyre.
When the tyre is overinflated and/or has too low tpi count the edges of the oval shape will be found along the radius of the tyre.
This situation is unwanted as the thread (+ anti-puncture belt) of the tyre is much less flexible than the sidewalls hence increasing its rolling resistance.
Ciao, ;)
PostPosted: Sat Jan 19, 2013 10:14 pm
The only data I've seen shows wider rims being rolling resistance neutral. The main theory is that by widening the contact patch, the RR should go down.
I've never heard speculation or seen data showing a RR increase.
PostPosted: Sun Jan 20, 2013 4:00 am
Improved side wall stiffness makes sense.
Not so sure on that.
PostPosted: Sun Jan 20, 2013 4:25 am
Well, I'm not sure if you're saying you disagree with the hypothesis or with that being what manufacturers point at.
The general jist of things is explained by this graphic from Conti:
http://velonews.competitor.com/files/20 ... 46x421.jpg
Hed has claimed this as a benefit from about 2009 but as I said, the only data that I've seen is very neutral. Al Morrison showed that the same tire on a traditional 20mm and a 23mm rim, back to back on rollers, had the same resistance within margin of error.
And from an article by Greg Kopecky over at ST:
"Does that automatically mean that the Crr is lower? Some manufacturers suggest that this is the case, but nobody is producing hard numbers to prove it – or at least showing them to any of us. Zipp Technical Director, Josh Poertner, challenges the idea. He suggests that there may be a very, very small improvement – but neither their testing, nor any independent testing they’ve seen can prove it outside of the margin of error of the test (on the order of .0000125 Crr improvement). My suggestion is that saying that the wide rim itself improves Crr, is like claiming that the chicken came first, when it’s really the egg. Yes, a wide rim allows you to run a wider tire and lower pressure – which lead to lower Crr. But it isn’t the rim itself that lends to this improvement; or at least not enough that we can actually measure it. I’ll go ahead and insert the voice of reason for you: Go worry about something else! Sleep more! Eat less Twinkies!"
PostPosted: Sun Jan 20, 2013 5:01 am
Now what would make sense to me is that a wider and shorter contact patch will have less scrub loss when turning in a corner.(without getting extreme)It could also be said like "The closer one gets to a circular contact patch shape the less friction in the corner) As far as running in a straight line it won't make a hill of beans IMO
[img]<iframe%20height='160'%20width='300'%20frameborder='0'%20allowtransparency='true'%20scrolling='no'%20src='http://app.strava.com/athletes/1677950/activity-summary/ddf436fc1ca509b20d4637cfa80c928da771d2c6'></iframe>[/img]
PostPosted: Sun Jan 20, 2013 9:46 pm
according to this laboratory, wider is better/faster:
http://www.bikeradar.com/gear/article/bicycle-tires-puncturing-the-myths-29245/
PostPosted: Sun Jan 20, 2013 10:29 pm
Good page from Flo... but I thought I saw one where they measured the actual difference in contact patch shape and it was very small. And if you reduce the pressure like they always tell you to with a wide rim, you can kiss that Crr benefit goodbye and then some.
http://flocycling.blogspot.com/2011/08/ ... 4-flo.html
formerly rruff...
PostPosted: Mon Jan 21, 2013 9:54 am
WMW, how do you figure? Aren'r we thought that the lower pressure is what gives us the lower crr? Not the wider rim in itself, as that really only gives än aero benefit?
Lower pressure - lower crr? To a certain point ofcourse...
Roadbike
Kinesis RaceLight T2
Mountainbike
Van Nicholas Zion Ti
PostPosted: Mon Jan 21, 2013 5:54 pm
Easy way to find an answer - what are the pros riding?
PostPosted: Mon Jan 21, 2013 5:59 pm
Whatever sponsor pays them to ride
PostPosted: Mon Jan 21, 2013 7:10 pm
DMF wrote:
Lower pressure - lower crr? To a certain point of course...
Where is that point? Tom Anhalt did some measurements and found that point at ~120 psi... but it wasn't a really accurate test and would be specific to his tires and road.
On a smooth surface higher pressure always *reduces* Crr. But there is an optimal point on roads where the combination of resistance due to roughness and the resistance due to tire flex is minimized.
Plus, wide rims make the sidewalls more vertical, which inherently makes the ride more harsh. I believe that is why manufacturers tell you to reduce pressure. If your narrow rims feel right with 100 psi, and your wide ones feel right with 90 psi, I'm pretty sure you'll have higher resistance with the wide ones.
formerly rruff...
PostPosted: Mon Jan 21, 2013 7:29 pm
All magazine tests I've seen in recent years put that number way closer to the 75-80psi range (23mm clincher) for a mid-weight rider (65-70kg) most likely lower than most of us are willing to go in fear of puncture and some very scary cornering, at least on 19mm rims.
120psi may rule on track, but on asphalt it's just insane unless you're a real lardo... Rolling resistance has very little to do with road friction, it's all in the movement of the casing. The more supple the lower the crr. No tire is supple at 120psi.
Roadbike
Mountainbike
Post new topic Reply to topic  [ 45 posts ]  Go to page 1, 2, 3  Next
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 56 guests
There are no new unread posts for this topic. New tire rolling resistance data.
[ Go to page: 1, 2, 3, 4 ]
Juanmoretime
47
2561
Sun Feb 10, 2013 12:28 am
fdegrove View the latest post
There are no new unread posts for this topic. Bicycle Quarterly rolling resistance tests: Spring 2013
djconnel
37
3515
Mon May 20, 2013 11:02 pm
There are no new unread posts for this topic. FLO 30: New wide clincher wheels
olebole
48
6316
Mon Apr 29, 2013 5:55 pm
Canadian View the latest post
There are no new unread posts for this topic. Deep Profile Wheels
Colnago68
Sun Oct 28, 2012 4:41 am
Bianchi10 View the latest post
There are no new unread posts for this topic. New Wide Rimmed Reynolds Wheels Coming
geedawg
11
1838
Sun May 27, 2012 5:55 am
lancejohnson View the latest post
It is currently Thu May 23, 2013 1:14 am
