Post new topic Reply to topic  [ 3 posts ]
PostPosted: Fri Jan 18, 2013 10:23 am
Hi,
Just bought a TCR Advanced 2012 frame, and the LBS guy said he did not fitted inline barrel adjusters because they don't go too well in this frame, it seems the bend of the cable/housing is not appropriate for an OK shift.
What is your experience?
Regards
PostPosted: Fri Jan 18, 2013 2:17 pm
never used them....no need if set up well...
Sent from my GT-I8160 using Tapatalk 2
tcr's rule !
stefanpearce@rocketmail.com
PostPosted: Thu Jan 24, 2013 7:07 am
I just built up a 2012 tcr advanced frame and used both barrel adjusters.
The one for the rear really impacts the shifting negatively and I will be removing it. The one for the front is fine and is really necessary, unless you feel like using a 4th hand and wasting 20minutes setting up the cable tension for the front derailleur. You also already have a barrel adjuster on the rear derailleur so really no need for it anyway.
The impact of the inline barrel adjusters really depends on bar choice, stem choice, stack and the frame size but I would say in most cases it probably won't work well.
-EP
Users browsing this forum: Bing [Bot], Exabot [Bot], fa63, Fourthbook, Ghost234, Google Adsense [Bot], ipaul, nigel379, Sykes, woody55 and 43 guests
There are no new unread posts for this topic. inline barrel adjusters
addictR1
7
624
Fri Jan 18, 2013 7:15 am
condor View the latest post
There are no new unread posts for this topic. Paragon Machine Works barrel adjusters/Alternatives-UK?
iamalex
Mon Nov 26, 2012 3:47 pm
iamalex View the latest post
There are no new unread posts for this topic. Which stem should I use for my Giant 2012 TCR Advanced
Ams
10
1397
Wed Oct 03, 2012 4:18 pm
sawyer View the latest post
There are no new unread posts for this topic. Placement of the Quarq magnet on a TCR Advanced 2012
Roark
12
604
Sat Jan 19, 2013 12:30 am
djm View the latest post
There are no new unread posts for this topic. Stuck barrel adjuster
cloudnine
29
1224
Thu Sep 27, 2012 3:38 am
timzcat View the latest post
It is currently Wed Jun 19, 2013 12:27 am
