Post new topic Reply to topic  [ 8 posts ]
 Post subject: inline barrel adjusters
PostPosted: Wed Jan 16, 2013 10:38 pm
when my lbs helped me install the shifter cables, they didn't install any inline barrel adjusters for the FD. now i'm thinking to add one into my Scott Addict R1.
can i still install one, like pretty easy to do?
PostPosted: Wed Jan 16, 2013 11:08 pm
Why do you need one? FD rarely goes out and if it does undo the pich bolt and pull the cable taught and re tighten.
www.thecycleclinic.co.uk
PostPosted: Wed Jan 16, 2013 11:30 pm
the reason is because i'm changing from 53/39 to 50/34, so will be moving the FD down lower
PostPosted: Thu Jan 17, 2013 4:03 am
Should be pretty straightforward -- would also look "balanced" if you have one on the other side of the down tube for the RD.
PostPosted: Thu Jan 17, 2013 6:20 am
yes you could add it but then you'd have to drill out your stem's faceplate bolts to counter the weight gain.
PostPosted: Thu Jan 17, 2013 8:11 am
Oh you still use those nasty things? I usually just omit the stem entirely and just expoy the handlebars right onto the steerer tube :)
PostPosted: Fri Jan 18, 2013 5:43 am
pics or it didnt happen!
PostPosted: Fri Jan 18, 2013 7:15 am
Very simple; you just have to pull the cable out, make a cut in the housing (maybe cut off a small amount to account for the added length of the adjuster), stick the barrel adjuster on, re-insert the cable, and you're done.
Users browsing this forum: Bing [Bot], Google [Bot], Google Adsense [Bot], rijndael, stax and 84 guests
There are no new unread posts for this topic. Using inline barrel adjusters on a TCR Advanced 2012
Roark
Thu Jan 24, 2013 7:07 am
prebsy View the latest post
There are no new unread posts for this topic. Paragon Machine Works barrel adjusters/Alternatives-UK?
iamalex
Mon Nov 26, 2012 3:47 pm
iamalex View the latest post
There are no new unread posts for this topic. Stuck barrel adjuster
cloudnine
29
1189
Thu Sep 27, 2012 3:38 am
timzcat View the latest post
There are no new unread posts for this topic. Aerolite pedal barrel bearing issue?
lo5707
Tue Jan 01, 2013 3:40 pm
GripShifter View the latest post
There are no new unread posts for this topic. Attachment(s) Front mech barrel adjuster scott s40 help please
blakemulder
Thu Jan 03, 2013 5:57 pm
It is currently Fri May 24, 2013 10:25 pm
