Post new topic Reply to topic  [ 5 posts ]
 Post subject: THM BB30 BB
PostPosted: Wed Jan 16, 2013 12:32 pm
Hi,
I have a BB30 frame with Specialized BB30 crankset. As i do not want to press in BB30 bearings so as to fit the crank, i came upon this product:
http://fairwheelbikes.com/thm-bottom-br ... -5189.html" onclick="window.open(this.href);return false;
The THM BB30 bottom bracket seems to fit BB30 frame via screwed-in external bearing cups. Will doing so allows the Specialized BB30 crankset be installed?
Anyone knows? Thanks!
 Post subject: Re: THM BB30 BB
PostPosted: Wed Jan 16, 2013 3:11 pm
That BB is too wide for a BB30 crank.
PostPosted: Wed Jan 16, 2013 3:17 pm
I think the THM BB30 BB will only work for THM Crankset.
PostPosted: Wed Jan 16, 2013 3:23 pm
Firetrail wrote:
Hi,
Is it a true bb30 frame? I'm only asking because if it is a Specialized frame, then it probably has a Spceialized OSBB, which use a 46mm ID instead of 42mm ID.
PostPosted: Wed Jan 16, 2013 3:53 pm
There's some cranks with 30mm spindles that are longer than BB30. Lightning and Rotor are a couple I know of. The BB looks like it'd work with Lightning, assuming those are 6803 bearings.
Users browsing this forum: fezi, Google Adsense [Bot] and 33 guests
This topic is locked, you cannot edit posts or make further replies. BB30 or BSA?
eric
Thu Dec 20, 2012 8:24 am
elviento View the latest post
There are no new unread posts for this topic. BSA or BB30 for Campy?
BobSantini
10
561
Sun Oct 28, 2012 10:56 am
Kastrup View the latest post
There are no new unread posts for this topic. BB30 Reccomendation
miskur505
Tue Jul 03, 2012 4:53 pm
NWSAlpine View the latest post
There are no new unread posts for this topic. bb30 play
tinchy
7
520
Thu Apr 11, 2013 1:29 am
There are no new unread posts for this topic. HELP. BB30 on Time NXR is driving me mad
wakadaka
Fri Nov 02, 2012 4:24 pm
styrrell View the latest post
It is currently Sun May 26, 2013 9:35 am
