Post new topic Reply to topic  [ 127 posts ]
Go to page Previous  1, 2, 3, 4, 5 ... 9  Next
PostPosted: Mon Mar 12, 2012 7:36 pm
VNTech wrote:
sovereign wrote:
I won't believe any info regarding compatibility until someone actually TRIES it.
We just (finally) got the stuff in-house, I'll be trying old shifters/new FD, new shifters/old FD combos today. Already tried new shifters, new FD and old crankset/rings, which works better than old FD/old rings, but not as good as going with the whole New Red system. Probably 80-90% as well. Without trim and with the slightly different ring spacing, you get slight chain rub in 39/11. But who rides around in their 39/11?
Any luck with old shifters/new FD?
PostPosted: Mon Mar 12, 2012 8:40 pm
See my post above. They work, but the old shifters have "unused" trim stops. Extraneous, but not a big deal...
Just match the new FD to the new rings and all is good.
PostPosted: Mon Mar 12, 2012 9:31 pm
ah sorry, the post was a little confusing at first read. In your opinion is it a worthwhile upgrade if I'm not upgrading the cranks just yet?
PostPosted: Mon Mar 12, 2012 9:37 pm
I personally haven't tried that yet...then again, I never seem to have any issues with the FD on my 1st Gen Force stuff anyway :wink:
PostPosted: Mon Mar 12, 2012 10:29 pm
Same question, but with new shifters and old model front derailleur?
PostPosted: Mon Mar 12, 2012 10:45 pm
Which chainrings? With old chainrings, it should work (since the cable pull is the same) but you won't have any trim function. It's up to you if that's a problem or not.
With the new chainrings I can't imagine it would work very well because of the wider spacing between rings at the teeth. That's why it's important to match the FD to the rings.
PostPosted: Tue Mar 13, 2012 12:16 am
Just filed the compatibility story, should be up tomorrow morning (U.S. time).
Tanhalt, you are basically correct. Everything is backwards compatible, the only tricky bit is the lack of trim on the new shifters. However, you are incorrect about the new chainrings, they won't go on old cranks without modification (even if you didn't mind the pin being in the wrong place). They're still 130bcd, but the mount point behind the crankarm requires a different shape.
If you want the new shifters, you need to get the new crankset unless you don't mind a bit of small/small chain rub. With old shifters, the trim takes care of that. Shifting with new Yaw FD + old rings is about 80% as good as with the new crankset, but still much better than the old group.
VeloNews Magazine/VeloNews.com tech
Contact always welcome - http://velonews.competitor.com/author/cfretz / cfretz at competitorgroup dot com.
Twitter: @CaleyFretz
PostPosted: Tue Mar 13, 2012 12:28 am
Hmmm...doesn't the Red S975 Quarq crank use the new rings too? I'm fairly positive that the rings attach to that spider on that in the "normal" fashion. It's just that the one bolt is "hidden" behind the crank arm (i.e. it doesn't screw into the arm itself). In other words, one can run "old" rings with the pin 180 out of phase on the Red S975 Quarq.
Are there 2 versions of the 2012 Red rings perhaps? :noidea:
PostPosted: Tue Mar 13, 2012 12:43 am
yes.
sram will have red rings that are clocked for conventional 5arm cranks later.
PostPosted: Tue Mar 13, 2012 12:48 am
Are you saying that the tab on the big ring isn't shaped like other 4 tabs?
The small ring in this pic looks fairly "normal"...but, it's hard to see any detail on the big ring tab.
Is there a separate spacer that goes between the rings, or is that a part of the big ring? If it's integral with the ring, that would imply there are 2 versions of the big ring since that feature wouldn't "fly" with the S975 spider.
PostPosted: Tue Mar 13, 2012 3:10 am
Sorry i might be reading this wrong.
But are you saying is that i could buy a new Sram 2013 FD use it with the old Shifters with better feeling then the Newer ones?
So i could be running a old(as in last year) Sram Red and have the 2013 FD with little to no issues?
PostPosted: Tue Mar 13, 2012 1:21 pm
Tanhalt — Yes, that tab is shaped differently. Not much, but a bit. Like I said, won't work without modification.
Chadwick — story will be up shortly that does a better job explaining it all (I hope), but in short: yes, new FD will work great with old shifters. In fact, if you buy the new FD and DON'T buy the new crankset, the old shifters are probably better because you still have the trim function. New FD + new crankset = no need for trim. New FD + old/non-SRAM crankset = trim needed to prevent chain rub in small/small crosschain combo.
PostPosted: Tue Mar 13, 2012 1:41 pm
"New FD + old/non-SRAM crankset = trim needed to prevent chain rub in small/small crosschain combo."
Casey: I am very much looking forward to your article as I am interested in using the new Yaw front derailleur with my old Red shifters and Vumaquad crankset. I currently use a Shimano FD-7800 mechanism with "good" but not "great" results.
Here is where you are confusing me: My Red shifters allow trim when in the large chainring only. The small/small combo would require a trim function while in the small chainring. Am I missing something?
PostPosted: Tue Mar 13, 2012 2:14 pm
Are you sure? The only reason I'm being insistent is that I've actually seen an S975 with "old" rings on it...and that wouldn't be possible if the 2012 Red Rings had some sort different feature requirement on that one tab. Obviously, it would be "counterproductive" to have that tab mount to the crankarm on the Quarq version of the crankset, so the S975 spider mounts the rings normally, i.e. with a spider tab sandwiched between the rings.
So...I'm thinking that maybe your set is some sort of pre-production version? Maybe it would be worth it to check with SRAM on what rings are used on the S975 cranks? Just trying to help make your article "complete" 8)
BTW, when you say "modification", are we talking about just filing off a bit off material or something more "major"? :)
PostPosted: Tue Mar 13, 2012 2:35 pm
Yep, just minor modification. Perhaps mine are pre-production, I'll double check. Regardless, that isn't in my story, left this one to shifter/derailleur compatibility.
mca56 — you are correct, I tested with old Rival (with trim in the small ring) and old Red (with trim in the big ring) shifters. For some reason I got the two switched around here, apologies. SRAM moved the trim function from inner to outer a few years ago, oddly enough the old inner trim shifters work better with the new stuff (getting rid of that small/small chain rub that I mentioned).
Post new topic Reply to topic  [ 127 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 9  Next
Users browsing this forum: Exabot [Bot], Google [Bot], project3 and 50 guests
There are no new unread posts for this topic. Scott Foil Questions - General Thread
Vallron
Wed May 08, 2013 7:16 pm
dha View the latest post
There are no new unread posts for this topic. Another which frame for me thread..
Colin
Sat Jan 05, 2013 10:30 pm
Colin View the latest post
There are no new unread posts for this topic. aluminum or aluminium bike thread???
tigoose
Tue Aug 14, 2012 4:58 am
tigoose View the latest post
There are no new unread posts for this topic. Kinlin - Halo - IRD the definitive thread....
TimF
Sun May 27, 2012 1:34 pm
TimF View the latest post
This topic is locked, you cannot edit posts or make further replies. ANOTHER light tire thread. Sell to me
Bianchi10
7
570
Tue Jan 01, 2013 11:23 pm
fdegrove View the latest post
It is currently Wed May 22, 2013 10:58 am
SRAM Red bike components at cheap prices - SRAM Red groupset
