Post new topic Reply to topic  [ 25 posts ]
Go to page Previous  1, 2
PostPosted: Thu Jan 17, 2013 1:17 am
Tubbie Guru
Hi,
Oops.....Silly me. I just didn't look at the right spot. On top of that the correct part states 10S in brackets right behind the part #.
@Bikerjulio: I can confirm that Campa did indeed edit their original 09 Sparepart list as they changed their policy on the availability of single spare part items. Someone must have seen big $$ signs in Vicenza.... :lol:
In fact, as I hinted at in my previous post, they must have realised that the mere availability of 10S Ultrashifters (full range or merely CE/VE or not) would potentially harm the market penetration of the new 11S line. Hence, etc. .etc....
Ciao, ;)
PostPosted: Thu Jan 17, 2013 1:28 am
yep, you reminded me. over on another forum me and C40 talked about how the online drawings suddenly changed in 2009.
dangerous curves ahead
PostPosted: Thu Jan 17, 2013 5:00 pm
You are overthinking it:
viewtopic.php?f=3&t=105602
Jtek is foolproof, almost certainly cheaper and easier to go back to 11 speed when needed.
PostPosted: Thu Jan 17, 2013 5:33 pm
I have a copy of the early '09 Campy spare parts PDF that lists all of the individual parts numbers for the ultrashift levers. It didn't stay on the website for very long.
PostPosted: Thu Jan 17, 2013 6:43 pm
Tubbie Guru
Hi,
viewtopic.php?f=3&t=105602" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Thanks, Franklin.
The only problem is that by the time it arrives In Europe it will probably cost me as much as the Centaur body though. :(
Ciao, ;)
PostPosted: Thu Jan 17, 2013 7:20 pm
Ordering direct from http://jtekengineering.com/shiftmate.php and sending to Belgium will cost USD47.50 (39.50 for the shiftmate plus 8.00 shipping and handling to Belgium) via PayPal plus any fees/VAT/whatever you might get charged on your end.
Belgium Liedekerke TS-Bikes +32(0)536828 34 http://www.ts-bikes.be
I don't know how that compares to price of a Centaur body.
PostPosted: Thu Jan 17, 2013 8:08 pm
Tubbie Guru
Hi,
The J-tek solution is cheaper: 46 Euro versus 59 for the Centaur body.
Moreover I had completely forgotten about Stefan from TS Bikes importing these magical thingies.....
Anyway, thanks for all the suggestions.
Ciao, ;)
PostPosted: Thu Jan 17, 2013 11:43 pm
Of course, by the time you have worn out all your 10-speed cassettes etc, you may have worn out your nice 11-spd shifter :lol:
Although on a serious note, I haven't seen any comments yet on how well the current generation of shifters last, so maybe you'll be OK.
PostPosted: Thu Jan 17, 2013 11:53 pm
Tubbie Guru
Hi,
On paper they should last longer than the old Ergo-Power. Still it seems that Campa has an easy solution which only requires a miniscule amount of skill : buy a new body, put the levers and hood on and off you go. :o :wink:
By the time I run out of 10S cassettes and chains, Campa and the rest of the world will have moved on to 12S anyway... :mrgreen:
O, I'll be wearing out the RH Centaur 10S shifter anyhow, not that super bling SR one. :lol:
Ciao, ;)
PostPosted: Fri Jan 18, 2013 1:23 am
Tubbie Guru
Hi,
Quote:
An 11 speed RD has a slightly larger actuation ratio and will overshift just a bit, using the 10 speed shifter, but it shouldn't be a problem.
As far as I can tell the Centaur/Veloce rear derailleurs that belong the Powershift range of components are no other than 11S ready rear derries like the rest of 11S range.
At least going by the parts lists it would suggest that say a new style Centaur 10S rear derrie would function equally well in either a 10S or 11S configuration.
Am I missing something here?
Ciao, ;)
Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2
Users browsing this forum: Bing [Bot], jdott and 58 guests
There are no new unread posts for this topic. Campagnolo back to zero bar end shifters
audiojan
10
864
Mon Aug 06, 2012 11:50 am
leon2982 View the latest post
There are no new unread posts for this topic. Rocket 7 shoes are back in business!
pritchet74
Thu Apr 11, 2013 9:57 pm
winky View the latest post
There are no new unread posts for this topic. Saddle farther back and sprinting
digitalnorbs
Wed Aug 01, 2012 5:34 am
2011 View the latest post
There are no new unread posts for this topic. Bike fit question - saddle set back and stem length
Tubby531
10
652
Mon Jan 28, 2013 12:10 am
neeb View the latest post
There are no new unread posts for this topic. I heard a whisper that Scott is bringing back the Addict
dmoneysworks
Fri Jan 18, 2013 11:21 pm
rowdysluggins View the latest post
It is currently Sat May 18, 2013 8:56 pm
