Post new topic Reply to topic  [ 7 posts ]
PostPosted: Tue Jan 15, 2013 7:54 pm
The Enve compression plug has a lip so that when it is placed in the steerer it does not slip down, but I can't track one of these down for sale in Europe. Are there any others to a similar design with a lip? Thanks.
PostPosted: Tue Jan 15, 2013 8:35 pm
the deda/columbus ones on this page...
http://www.chickencycles.co.uk/index.php?cat=4&sub=106" onclick="window.open(this.href);return false;
...i've got one, the lip is fairly thin, so it doesn't add much height at the top of the steerer, its long enough to give internal support over the whole length of a stem clamp
it's cheaper from wiggle...
http://www.wiggle.co.uk/deda-expander-bung/" onclick="window.open(this.href);return false;
you need to check the inside diameter of your steerer tube, i think the bung is 23.5mm minimum
PostPosted: Tue Jan 15, 2013 11:14 pm
I use the Deda as well and agree with the other comments re: adequate support (length) and uniform expansion over its length. The one by KCNC is also worth looking for if it's available in Europe. I bought the Deda direct from a shop in the States. The KCNC can be found on EBay.
The facts, while interesting, are not relevant.......
PostPosted: Tue Jan 15, 2013 11:34 pm
Valbrona, I have an Enve compression plug as described that I do not need, pm me your address and I'll drop you a jiffy bag with it in.
S
____________________________________________________________________________
Firefly FF050
Felt B2Pro
Trek Fuel EX9
PostPosted: Wed Jan 16, 2013 1:49 am
Tubbie Guru
Hi,
Is this just for convenience sake or?
Can't help but notice that all of these are actually bung/expanders (who needs a stack of expanders anyway?) which are bound not to be all that light, you see.
Just for info, I'm using a true bung (which effectively prevents you from crushing a fork's steerer tube) made of carbon which, although a little old fashioned (read heavy) by design, does a very good job when combined with a lightweight expander.
I assume that when you state "that does not slip down" you mean it does not fall to the bottom of the steerer tube whenever you try to manipulate it in its unexpanded state, correct?
There are a few solutions (none of them 100% foolproof but still) that make it more difficult for the expander to drop : use of carbon paste (a la Dynamis/Tacx and consorts) and even simpler, tilt the bike so it's at roughly 90 degrees to the floor whilst due the manipulation.
None of those tips prevent anyone from losing the expander in the dark abyss of the steerer tube but they do help somewhat.
Ciao, ;)
PostPosted: Wed Jan 16, 2013 3:25 am
The ones specialized uses are pretty light, I want to say about 15g. Also pretty tall for good support, and it just plain works. Or you could get the new Cannondale one, apparently finally available. it has the top cap built in so you have to be doing something quite wrong to lose the bottom part in the steerer. It is also only 16g complete with top cap.
PostPosted: Wed Jan 16, 2013 6:48 pm
S
That's very kind of you. However, I am not a person that can easily accept things for free, and instead of a lipped bung I have changed my mind and have just ordered a Hope Hed Doctor. I'll see how I get on with this rare piece of British engineering, but I am not that optimistic!
I have been using an FSA carbon compressor which works well - you can't really lose the bung in the steerer - but I have grown to dislike the big mushroom top cap.
Users browsing this forum: headwind816, Nismo4x4, rijndael, Rob1519 and 53 guests
There are no new unread posts for this topic. Velocity Velo plugs
kavitator
Tue Aug 21, 2012 8:32 am
kavitator View the latest post
There are no new unread posts for this topic. Help please - FSA compression plug
headwind816
Sun Mar 24, 2013 10:08 pm
DaveS View the latest post
There are no new unread posts for this topic. carbon-ti compression / expander
SDP
Wed Jan 16, 2013 9:48 pm
SDP View the latest post
There are no new unread posts for this topic. TT gear shifter expander plugs in carbon TT bars?
alanmclean
Mon Aug 20, 2012 12:31 am
There are no new unread posts for this topic. Attachment(s) cannondale sisl2 + new compression plug details
[ Go to page: 1 ... 4, 5, 6 ]
thisisatest
89
9634
Mon Feb 18, 2013 6:06 am
OwenJames View the latest post
It is currently Fri May 24, 2013 5:19 pm
