Post new topic Reply to topic  [ 50 posts ]
Go to page Previous  1, 2, 3, 4  Next
PostPosted: Tue Jan 22, 2013 10:30 pm
People worry about toe overlap when picking a frame? :lol:
PostPosted: Wed Jan 23, 2013 3:04 am
ultimobici wrote:
No different to the Venge he was riding in 2011
Good god that venge is hideous
PostPosted: Wed Jan 23, 2013 6:56 am
Location: somewere floating between here and the other side
[quote="kulivontot"]Because everyone rides their bike only at races 100% of the time. Get your head out of your asses, toe overlap is super annoying any time
+ 1
PostPosted: Wed Jan 23, 2013 6:01 pm
toe overlap is 100% annoying for that .1% when it happens.
track standing at light... put your foot down like a normal person then, if u are phazed by toe overlap.
PostPosted: Thu Jan 24, 2013 6:54 am
Move your cleats...problem solved! :thumbup:
"It never gets easier, you just go faster..." - Greg Lemond
"Because technology alone is a poor substitute for experience." - Richard Sachs
 Post subject: Toe Overlap on a Venge
PostPosted: Thu Jan 24, 2013 7:47 am
I was going to say shorter cranks. Problem isn't cleat placement, the shoe is just longer
PostPosted: Thu Jan 24, 2013 9:14 am
The reason is that today's world of mass manufacturing is based on volume, hence 650c frames seldom make economic sense except for a small number of manufacturers, let alone the lack of choices of rims and tires.
Plus, 650c is not the panacea as you only gain 25mm of extra clearance, which for 51+ should be fine but for sizes under 50 (unless you go with 71 deg head angle and 75 deg seat angle), overlap will remain.
Either that, or designers are just dumb. :smartass:
Fast falcons: http://www.youtube.com/watch?v=j3mTPEuFcWk" onclick="window.open(this.href);return false;
twitter: Falco_bike
Facebook: falco.bike
PostPosted: Fri Jan 25, 2013 2:02 am
One could make an argument for lengthening chainstays on the smallest bikes. Keep the front-center at the minimum for no toe overlap, only shorten the stem, and to keep the weight distribution proper, make the rear end longer. Yes, it'll have drawbacks, it's all a series of compromises. I wonder how it would do.
PostPosted: Fri Jan 25, 2013 4:57 am
A lot of discussion and thoughts here guys, but I think the obvious answer is that Cav has secretly amputated his toes and opted with custom shoes to avoid the toe overlap, save a few grams, and make himself more aerodynamic on the bike. Any self respecting pro rider would consider it.
PostPosted: Fri Jan 25, 2013 5:18 am
Blame your parents for needing to ride small frames with 700c wheels that lead to toe overlap :D :D :D
Or realize it's all a compromise for riders who need smaller frames vs do you want a slack head angle, do you want a size of wheels no one else rides, do you want to track stand a certain way or not at all..... :noidea:
Or best answer is just go fast and you don't need to turn sharpish :thumbup:
Hav'n sum fun with this - no harm intended :beerchug:
PS: I bet a lot of pro basketball players (meaning real tall) don't dictate the interiour size of standard cars just because they are rich and popular......so there are people that will fall out of the business model expectations......plus they always could go custom to get what they really want........and as we know, carbon can be done custom........ 8)
PostPosted: Fri Jan 25, 2013 1:46 pm
If I was to get a custom bike I'd add a cm or two to the top tube & drop 1-2 cm on the stem...eliminates toe overlap & allows a more stretched out bike which I like...
PostPosted: Fri Feb 01, 2013 7:10 pm
Anyone who thinks first of all that toe overlap is critical, especially for a sprinter doesnt know what theyre talking about. If you know the slightest basics aboud turning a bike, toe overlap will never be an issue. Also, shorter clearence results in a shorter total length, giving the bike much quicker responsiveness. Mclaren and specialized did something new , not perfect but it kind of led to alot more companies wanting to invest in aero research which I think is tremendously important in road racing.
PostPosted: Fri Feb 01, 2013 8:36 pm
Is it just me that thinks the head angle is ever so slightly on his two venges? not by much but enough that the OPQS wheel looks a bit more tucked?
PostPosted: Fri Feb 01, 2013 9:16 pm
Also reduces weight on the front wheel, which is an issue in fast cornering - you'll slide the front wheel. Shorter stem also makes handling a bit more "jittery."
Point being - it's all a set of compromises. You weigh them all and make the decision that suits the type of riding you do.
PostPosted: Sat Feb 02, 2013 1:08 pm
I personally have a longer upper body compared to my legs (179cm tall), currently ride a 54cm seat tube ctc & a 56cm top tube ctc...I once had an old custom steel frame with a 57cm top tube so don't really think an extra cm will be too detrimental to the handling... ;)
Post new topic Reply to topic  [ 50 posts ]  Go to page Previous  1, 2, 3, 4  Next
Users browsing this forum: bdzero1, BeeSeeBee, Exabot [Bot], Google Adsense [Bot], tharmor and 58 guests
This topic is locked, you cannot edit posts or make further replies. Specialized Venge or SL4 ?
ianeverton
Sun Jul 08, 2012 12:35 pm
Frankie - B View the latest post
There are no new unread posts for this topic. Specialized Venge and Campagnolo EPS
ted75
Wed May 23, 2012 6:13 am
veganeric View the latest post
There are no new unread posts for this topic. Attachment(s) Specialized Venge BB advice please
Dougan
12
1619
Thu Jun 28, 2012 2:53 pm
89daytona View the latest post
There are no new unread posts for this topic. Venge pro or Roval Rapide clx 60?
bmkd32
Mon Dec 31, 2012 2:41 pm
LouisN View the latest post
There are no new unread posts for this topic. Foil Team with DA 9000 or Venge with Red
brycerider
28
1762
Mon Apr 29, 2013 11:44 am
brycerider View the latest post
It is currently Mon May 20, 2013 4:16 am
