Post new topic Reply to topic  [ 3 posts ]
 Post subject: Fizik Kurve Chameleon
PostPosted: Fri Jan 11, 2013 5:27 am
Not a ton of reviews out there. Anyone have any experience? Do the kurve saddles distribute saddle pressure that much better compared to the standard or versus version saddles? I can no longer ride specialized saddles as they are causing numbness. Are these any good for tri bikes?
PostPosted: Fri Jan 11, 2013 7:16 am
I've been on the Antares and Aliante Versus (briefly, mind) and feel that the relieve channel is partially defeated by how squishy the padding is. At times, it feels as if you are close to bottoming out in the channel; although if you are having issues this is still better than having no channel at all.
The overall construction seemed quite good, in my opinion, and the finish is quite stylish. Most Fizik dealers also have a very solid demo program so I'd recommend you try them out. I may give the Antares another go around here soon.
PostPosted: Fri Jan 11, 2013 8:25 am
I ride an Antares and tried the Curve version and can't really say I found it much different, certainly not a really noticeable improvement to warrant spending the money. From what I remember, the benefit in the curve is from the rails and how it supports the saddle and absorbs the road buzz. If it's that which causes problems on a ride then it may be great for you but if it's the shape of the Fizik saddles in the first place then perhaps it's not right. Have a look around, you may be able to find test models somewhere or ask nicely at your LBS and they may let you borrow a display model.
Users browsing this forum: jdott, Omiar, phlip, rijndael, sedluk, WeightySteve, woz9683 and 74 guests
There are no new unread posts for this topic. Fizik Saddles: Kurve vs 00
tdudzik
Thu Nov 08, 2012 12:30 am
CippoForLife View the latest post
There are no new unread posts for this topic. ENVE Seatpost + Fizik Kurve
ppplachkov
Fri Sep 28, 2012 6:44 am
billysan View the latest post
There are no new unread posts for this topic. Fizik Arione set up
digitalnorbs
12
1216
Mon Oct 08, 2012 6:10 pm
roadytracky View the latest post
There are no new unread posts for this topic. Fizik Antares 00
ckc527
Tue Jan 29, 2013 9:27 am
ckc527 View the latest post
There are no new unread posts for this topic. Are Fizik about to offer saddles with a cut out?
Lemond75
19
1413
Wed Feb 27, 2013 3:57 am
tommasini View the latest post
It is currently Wed May 22, 2013 7:36 pm
Fizik Kurve Chameleon Wing Flex saddle black
