Post new topic Reply to topic  [ 22 posts ]
Go to page 1, 2  Next
PostPosted: Tue Jan 08, 2013 12:57 pm
Hi all.
My first post here after lurking some time, but i thought that this must be something for carbon experts like you.
I was out looking at a lovely Look 595 ultra, but the frame have been cut to fit the former user, so if I have to fit it, I'm missing 1-1,5 cm under the stop limit at the seatpost. I have uploaded pictures below to illustrate the seatpost (that have several cuts/lose elements)
I need to tighten the seatpost right under the red spacer ~1cm under the stop.
I weight 65kg (with clothes), so is there any risk that i can damage the frame or seatpost?
Is it a go or no-go?
Regards Lars
PostPosted: Tue Jan 08, 2013 7:22 pm
Perhaps you could find a saddle with a particularly extended rails to seat distance? I dont know how much variation is out there and whether 1 cm is feasible, but anything you could do to lower the seatpost would lower the risk you are worried about.
PostPosted: Tue Jan 08, 2013 7:28 pm
You could use lower the seat height by using shoes and pedals which give you a lower stack height.
PostPosted: Tue Jan 08, 2013 7:32 pm
I am not saying that this will necessarily be a good solution, but you can consider the Look "RePost"
http://www.lookcycle.com/en/us/route/accessoires/rsp.html
http://www.lookcycle.com/en/us/route/accessoires/rsp-r5.html .
I'll leave you to look into it further.
PostPosted: Tue Jan 08, 2013 9:41 pm
To add to what was said by ghisallo2003, I've found variations of up to 1.75 cm from rail to top of saddle between the various road saddles I have.
PostPosted: Tue Jan 08, 2013 9:54 pm
Okay that's a lot everybody!
Can anyone recommend a 'tall' saddle?
I have looked, but it's hard to see which ones that is 'tall' and which is not.
This eg.g look 'tall' but i honestly don't have any idea.
Selle italia x2 flow
PostPosted: Tue Jan 08, 2013 9:57 pm
Maybe related, maybe not. I have a carbon Orbea frame with a carbon Profile Designs seatpost. The post is about 1 cm above the minimum insertion line. The minimum insertion line is about 1 cm above the seatpost clamp and visible. Using it a couple years like this.
PostPosted: Tue Jan 08, 2013 10:41 pm
The lowest I've measured of the saddles I have is the Specilaized Romin. It measures a little over 4 cm from the bottom of the rail to the top of the saddle. The tallest I have is a Koobi Xenon which measures almost 6 cm. I have a couple MTB saddles which are even taller. Best bet is to use the saddle you made your initial measurement with as a baseline and head to your LBS and measure a few saddles.
PostPosted: Wed Jan 09, 2013 9:53 am
I think the result must be a little over the stop and a new saddle.
PostPosted: Thu Jan 10, 2013 5:24 am
It's an interesting question: if you weigh nothing and your saddle weighs nothing you only need enough seatpost in the frame for it to clamp. The heavier you are the more seatpost you need. At some point you have enough seatpost in there that it's no longer strength-limiting. But clearly 65 kg is less than the design limit of the post so being exactly at the line isn't a problem. But 1-1.5 cm is large.
My guess is the strength is proportional to the square of the amount of seatpost in the tube but a mechanical engineer would be able to answer that better.
http://djconnel.blogspot.com/
Fuji SL/1
PostPosted: Thu Jan 10, 2013 6:03 am
I would have thought "no problem at all".
I think most seatposts recommend about 2.5" of minimum insertion, and I have run them with only about 1" of insertion.
Going 1-1.5 cm below the manufacturer's line seems pretty safe to me because the manufacturer typically includes a very conservative safety factor.
But this is just my opinion, and like all deviations from manufacturer's specs, it is 'At your own risk."
I happen to be a mechanical engineer, but I have applied no analysis whatsoever to this. Only gut feel and experience. :)
PostPosted: Thu Jan 10, 2013 6:33 am
This baby will easily give you 3cm of extra height, but it's hideous (although it allows you to have children).
2.5" (6.25cm?) of grab is probably not enough. I have worked with quite a few bike engineers, and they mostly say 7-8 is required.
In fact, a manufacturer I know that uses internally butted seat tube with 2" of grab is having lots of warranty issues. Remember this is in Asia where 65kg dudes are pretty common.
Fast falcons: http://www.youtube.com/watch?v=j3mTPEuFcWk" onclick="window.open(this.href);return false;
twitter: Falco_bike
Facebook: falco.bike
PostPosted: Thu Jan 10, 2013 9:56 am
Probably closer to a log function I'd reckon, at some point the gain from more overlap diminishes.
Bikes: Raceur, Beateur
PostPosted: Thu Jan 10, 2013 2:55 pm
I have 2 friends with 695...
You can find a guy who works with carbon and he will make the seat-tube in height you need. It will be great if you have the piece which was cutted
It should not cost more then 50 euros and here our guy make it so good nobody can find where it was putted together
PostPosted: Thu Jan 10, 2013 4:42 pm
Typically you want the insertion to be a minimum of 2.5x the diameter. That does little for you, with a non-round post. On conventional frames, an additional rule is for the bottom of the post to pass the bottom of the top tube.
Post new topic Reply to topic  [ 22 posts ]  Go to page 1, 2  Next
Users browsing this forum: deltree, Google Adsense [Bot], mellowJohnny and 40 guests
There are no new unread posts for this topic. Hollowgram chain line
neverwasbeen
13
584
Wed Apr 03, 2013 8:59 pm
shoemakerpom2010 View the latest post
There are no new unread posts for this topic. Attachment(s) SWISS STOP for Ultegra 6700
project3
Tue Aug 14, 2012 6:59 am
project3 View the latest post
There are no new unread posts for this topic. Tubular sealant - Michelin Stop&Go?
E777L
9
821
Tue Dec 04, 2012 5:30 pm
fdegrove View the latest post
There are no new unread posts for this topic. zipp 404 stop alu clincher production
project3
Mon Mar 11, 2013 4:06 am
wpccrunner View the latest post
There are no new unread posts for this topic. Campagnolo/Swiss Stop brake pad compatibility
MajorMantra
15
422
Mon Apr 01, 2013 12:02 am
jmartpr View the latest post
It is currently Sun May 19, 2013 1:55 am
