Post new topic Reply to topic  [ 8 posts ]
PostPosted: Mon Jan 07, 2013 7:41 pm
So, going to do one more round of lubing and checking bolts before I try the Loctite approach to fixing a creak I can't seem to get rid of, on a cadd10. Thought it may have been the skewers, so lubed and tightened those. Lubed the pedals again. Cleaned and lubed the seatpost (thomson masterpiece) after the last time out as I hear those can occasionally creak. Last time the creak happened out of the saddle too, so unlikely, but still possible from what I gather.
Question on Loctite-ing the bb bearings though. I've read in most places that one should let them cure 24 hours before installing the crankset. My little brain tells me that it would be more logical to install the crank and then let it cure for a day, as that would ensure the bearings aligned as they should be in their final resting place, so to speak. Is that plain wrong?
ps. This has been the most pain-in-neck to diagnose creak I've come across. Usually won't happen until a real hard effort, 30-40 miles into a ride. Then it happens under strong or moderate force, left crank downstroke. Then it will often disappear before I make it home, and then I can't recreate it unless I do another longer ride. It's like the damn thing has to get warmed up, and then disappears as it cools down.
PostPosted: Mon Jan 07, 2013 7:44 pm
Press in when locktite is still wet then let it cure when it is inside the bb shell.
PostPosted: Mon Jan 07, 2013 7:55 pm
My most recent creak like that was a very slightly loose screw on a cleat. Previous to that was a skewer.
Cure after install IMO.
PostPosted: Mon Jan 07, 2013 8:12 pm
Especially in this case, I would cure after installation. This is a metal frame, not requiring primer, so it won't set super-fast. So you will have time to install before it starts hardening...
What cranks? If it has a separate spider, check that, and of course chainring bolts.
PostPosted: Mon Jan 07, 2013 9:55 pm
Thanks for the input. I'm going to do a once over of on every last bolt before getting on the road again for a longer ride.
Crank is is SRAM Force.
PostPosted: Mon Jan 07, 2013 10:00 pm
cure with BB press installed
________________
My 2011 Cervelo R5
PostPosted: Tue Jan 08, 2013 1:11 am
+1
PostPosted: Tue Jan 08, 2013 3:04 am
Ahh...didn't think of that, but seems like it would work well.
Users browsing this forum: Bing [Bot], bratz and 38 guests
This topic is locked, you cannot edit posts or make further replies. cannondale si sl crank install
logy
Sat Mar 30, 2013 11:55 pm
There are no new unread posts for this topic. For the SRM Gurus.. offset change with new crank arm install
ParisCarbon
15
593
Mon Dec 31, 2012 5:48 pm
ms6073 View the latest post
There are no new unread posts for this topic. To install or not to install: Fenders on winter/commuter
LouisN
28
999
Tue Mar 05, 2013 9:19 pm
motorthings View the latest post
There are no new unread posts for this topic. Power2max bb30 crank (alternatives?)
tri
Mon Jul 23, 2012 10:45 pm
Beancouter View the latest post
There are no new unread posts for this topic. Recommend Crank-Based Powermeter for BB30 Ui2 Compact
415brian
Fri Nov 02, 2012 8:43 pm
415brian View the latest post
It is currently Fri May 24, 2013 10:26 am
