Post new topic Reply to topic  [ 5 posts ]
PostPosted: Mon Jan 07, 2013 2:41 pm
Just bought one of these to pair with a Reynolds Assault rim. Looks like it gets rid of the bad flange spacing of the 240S hub. Does anyone have the dimensions for this hub so that I can order the right spoke lengths?
It's online again:The Machinist
PostPosted: Wed Apr 17, 2013 2:19 pm
Hi!
I saw you found dimensions for this hub. How do you calculate your spokes finally?
PostPosted: Wed Apr 17, 2013 7:07 pm
iboc23 wrote:
Hi!
Here is an answer from another thread.
Now I can answer my own question, as I went by one of the local S dealers today who had a lot of the Roval wheels on display. I measured a pair of SL45 wheels and as the name indicates this rim is 45mm. On the rear DS i measured the spoke to 249mm from spoke end to the rim. The NDS was 264mm. The rim and nipples take up about 12mm and adjusting for the difference in rim height I decided on 260mm for the DS and 274mm for the NDS. I'll be sure to post the result, so the information is available to others.
PostPosted: Wed Apr 17, 2013 7:36 pm
Thanks! .. just bought one LF07 from Chain Reaction, pretty cheap now.
Kind of hard to calculate when you don't have wheel build with the same... it's way easier if you have one!
I did the same with an Neutron hub, but having some tension problem because the original rim is asymetric.
PostPosted: Wed Apr 17, 2013 8:00 pm
I actually did it with the DT calculator. NDS is easy as it'a straight pull. The DS you type in 2 cross and 32 spokes and ads a few milimeters due to the 2:1 lacing pattern. I got the same spoke length as I found measuring the Specialized wheel.
Users browsing this forum: Bing [Bot], Exabot [Bot], Google [Bot], headwind816, oreoboreo, shoemakerpom2010 and 60 guests
This topic is locked, you cannot edit posts or make further replies. dt swiss 240s freehub
ColnagoJohn
Tue Mar 05, 2013 1:59 pm
maverick_1 View the latest post
There are no new unread posts for this topic. Cracked flange on DT Swiss 240S hub?
Anders
Sat Dec 29, 2012 7:43 am
Franklin View the latest post
There are no new unread posts for this topic. Who has some Specialized Roval wheels?
Anders
Tue Feb 05, 2013 9:49 pm
Anders View the latest post
There are no new unread posts for this topic. Quickstep Roval Bora's?
r_mutt
Sat Jan 12, 2013 12:22 am
r_mutt View the latest post
There are no new unread posts for this topic. Venge pro or Roval Rapide clx 60?
bmkd32
Mon Dec 31, 2012 2:41 pm
LouisN View the latest post
It is currently Wed May 22, 2013 1:44 am
