Post new topic Reply to topic  [ 11 posts ]
PostPosted: Sun Jan 06, 2013 7:22 pm
I am thinking about getting a new Cervelo R5, anything on the list looks like it needs to be switched? Going to a Red cassette would knock off 70 grams for $200. Anything low hanging fruit below that wouldn't cost too much?
Bottom BracketRotor PressFit 30 ForkCervélo FK33
HeadsetFSA IS3 Tapered - 6mm TC
Seatpost3T Palladio Team
Rear DerailleurSRAM Red
Front DerailleurSRAM Red
ShiftersSRAM Red
Brake CalipersSRAM Red
CranksetRotor 3DF BBright 110BCD 52/36
Handlebar3T Ergonova Team
Stem3T ARX Team
CassetteSRAM PG1070 11-26T
ChainSRAM PC1091
PostPosted: Sun Jan 06, 2013 7:27 pm
ditch the brakes and go planet X. save you money, weight and give better braking
Swap the chain for KMC SL to save weight
Cervelo S3 2011. Blinged 6.718 Kg
PostPosted: Sun Jan 06, 2013 9:49 pm
I would also buy lighter brakes. Ciamillo would be my choice.
I also wonder, if it is possible to use any "standard" crank with Cervelo. Isn't Rotor one of the heaviest cranks available?
Theese are two components, I would switch on my bike.
PostPosted: Sun Jan 06, 2013 9:57 pm
Hollowgrams or new red crank
PostPosted: Mon Jan 07, 2013 12:58 am
check out brake calipers here
http://www.eecycleworks.com/VNJune%20BrakeTest.pdf
PostPosted: Mon Jan 07, 2013 1:43 am
I don't think the rotor 3DF is one of the heaviest cranks out there. I use the 3D+ and I love it. If you're also looking for a cheap SRM alternative to install eventually, the power2max meter will fit on your rotor crank.
Cervélo S2 2012 Red
Great minds think alike... sadly, so do the mediocre ones.
PostPosted: Mon Jan 07, 2013 2:41 am
The palladio team isn't the lightest seatpost in the world. The Dorico LTD is >30g lighter width for width length for length for $25 based on the 3T website vs the palladio team. Or you could get a ricthey superlogic and swap the steel bolt to ti and have a sub 150g seatpost for a little more. Agree on the crank. If no future plans for powermeter I would grab a new SRAM GXP + lighter rings (praxis?) and save 100g over the rotor. Will need some adapters though for the crank. Changing the expander and topcap to extralite will save about 30-40g dependant on the expander/top cap set up for about 80 dollars. Should be a nice build.
Evo 5.63kg SL3 7.045kg viewtopic.php?f=10&t=110579" onclick="window.open(this.href);return false;
PostPosted: Mon Jan 07, 2013 4:07 pm
Thanks for the replies! Also great brake test.
does the cassette swap make sense? I may swap the stem and seat post to dorico ( if thats the grey one) anyway to get some red color highlights off the bike.
PostPosted: Mon Jan 07, 2013 4:20 pm
Stock 2013 R5 RED $5900
They weighed one with wheels and everything and I think it was 14.7 with the stock heavy wheels. Mines will be a 58 but with my C24s it should be under 14
PostPosted: Mon Jan 07, 2013 4:42 pm
I say keep the red cassette. Can pick them up almost new for $100 or so. I got one with a couple hundred miles on it for 89 shipped. Planet x brakes.
PostPosted: Tue Jan 08, 2013 12:38 am
It doesn't come with red - that's what I'm upgrading to for $200
Users browsing this forum: Bing [Bot], oreoboreo, woz9683 and 46 guests
There are no new unread posts for this topic. Attachment(s) Best way to start bar tape?
alanmclean
28
1740
Wed Dec 19, 2012 2:23 am
fdegrove View the latest post
There are no new unread posts for this topic. Best way to start with Rotor Q Rings
BoerLowie
36
3528
Mon Nov 19, 2012 12:12 am
1415chris View the latest post
There are no new unread posts for this topic. New bike. But which
Elrey
18
1336
Mon Oct 01, 2012 9:04 pm
Elrey View the latest post
There are no new unread posts for this topic. If you could only have one bike...
SteveFromNY
41
2507
Tue Apr 16, 2013 1:40 pm
alexh View the latest post
There are no new unread posts for this topic. New Bike Help
stockman22293
Wed Jun 20, 2012 8:37 pm
russianbear View the latest post
It is currently Sat May 25, 2013 3:47 pm
