Alex SC7000 Rims
- Shop Owner
Alex discontinued them because Mavic was going to sue them for the machined out center sections on the rim.
- Stolichnaya
If you want to avoid the Mavic options, you should check out the Ambrosio models. The Ambrosio Focus FCS28 is still around and can be found online for about $60 per rim. The tubuar version from Ambrosio is called the Thesis and is a little bit cheaper.
- Shop Owner
GoMax wrote:What's a good lightweight mid V clincher to check out, if the Alex isn't going to be around?
Alex makes a 28mm rim called the crostini R1.1 that is very nice, the weight is 475g. There is also the 450g 30mm niobium rim that is sold under quite a few names, IRD, speedcific, KinLin etc.
