Post new topic Reply to topic  [ 9 posts ]
PostPosted: Thu Jan 03, 2013 3:32 am
when sprinting, my radius hits and bumps my bars causing bruising, and is especially painful during repetitive sprint intervals. my bars a currently so that the drop are basically parallel with the ground. during my sprints I am shifting through multiple gears. so my hands have to be close to the curved part of the bar. the shifters are adjusted for the smallest reach possible
if i tilt them further down will that alleviate the issue? would rather ask first so i dont have to re-warp my bars multiple times
PostPosted: Thu Jan 03, 2013 4:53 am
Yes - start by adjusting them so the drop "flat" portion points downward something around 10 degrees.......as a starting point.
But why would you be concerned about rewrapping the bars??????
PostPosted: Thu Jan 03, 2013 4:57 am
appreciate it, because i would have been moving them the wrong way and have to re wrap a few times. just a pain in the ass :thumbup:
PostPosted: Thu Jan 03, 2013 5:51 am
Yes, rotating the bars will change wrist position. I am curious though, although I am by no means a sprint specialist. How many gears are you shifting through? For me, I shift maybe once and then power through. What is the width of your bars? If they are super narrow, that could be compounding the issue (although I never hit wrists on even my 40 cm bars)
PostPosted: Thu Jan 03, 2013 5:56 am
Another thing to do is get your head and body lower. If your body is lower, your hands approach the shifters from behind instead of from above. Can't get low enough? Then (gasp!) raise your bars.
PostPosted: Thu Jan 03, 2013 6:09 am
cool. actually i think i may be using bad form. its during standing starts mainly and im leaning over the front hub. im pretty low but could probably sit back more
PostPosted: Thu Jan 03, 2013 8:54 am
I have a feeling your top tube + stem might be too short. It's not about getting low but more about getting stretched out a bit more. Try getting a stem with 2CM more length and see if you still bump the wrist. Frame could be too short as well.
Fast falcons: http://www.youtube.com/watch?v=j3mTPEuFcWk" onclick="window.open(this.href);return false;
twitter: Falco_bike
Facebook: falco.bike
PostPosted: Thu Jan 03, 2013 2:19 pm
I would be inclined to be thinking along the same lines as @Elventio that maybe the whole setup is too short, and possibly your bars are too wide as well. You shouldn't have to "sit back" further to accommodate a too small frame or setup. The frame should accomodate you and not the other way around.
My Colnago C59
My Special Colnago EPQ
PostPosted: Thu Jan 03, 2013 3:56 pm
Formerly known as PezTech
Changes do tend to change the things they change.
charles@pezcyclingnews.com
Users browsing this forum: audiophilitis, giant man, Google Adsense [Bot], jeffbong, Mario Jr., Wookieopolis and 53 guests
There are no new unread posts for this topic. Light Clip-On Bars for 3T Ergonova Bars.
CerveloBert
Mon Aug 13, 2012 4:24 pm
prendrefeu View the latest post
There are no new unread posts for this topic. Saddle width for aggressive position
digitalnorbs
Wed Aug 22, 2012 4:26 am
digitalnorbs View the latest post
There are no new unread posts for this topic. Success when switching to a more aero position on the bike
Roark
19
1712
Mon Feb 04, 2013 7:08 pm
11.4 View the latest post
There are no new unread posts for this topic. Help calculating saddle position between two bikes with diff
Ufgators
Thu Oct 18, 2012 7:53 pm
kulivontot View the latest post
There are no new unread posts for this topic. can some one tell me what bars are those
digitalnorbs
Thu Sep 13, 2012 8:01 pm
bricky21 View the latest post
It is currently Mon May 20, 2013 5:48 pm
