Post new topic Reply to topic  [ 9 posts ]
PostPosted: Tue Jan 01, 2013 3:39 pm
I've considered moving from my current setup to Campy someday. However, I've typically used an 11-28 cassette on my Shimano and Sram drivetrains.
Can you alter Campy cassettes? I'd love to have something like: 11,12,13,14,15,17,19,21,23,26,29 (a morph of the 11-23 and 12-29).
Here's a snapshot of Record cassette cogs:
The 11-23 includes- 11,12,13,14,15,16,17,18,19,21,23
The 11-25 includes- 11,12,13,14,15,16,17,19,21,23,25
The 12-25 includes- 12,13,14,15,16,17,18,19,21,23,25
The 12-27 includes- 12,13,14,15,16,17,19,21,23,25,27
The 12-29 includes- 12,13,14,15,16,17,19,21,23,26,29
Thanks, Scott
PostPosted: Tue Jan 01, 2013 3:46 pm
No problem. Just take a 12-29 cassette & replace the loose sprockets with those from any 11-23. VoilĂ !
PostPosted: Tue Jan 01, 2013 3:57 pm
Awesome. Thanks! 8)
I wondered if it was easy ... so the only issue is the cost.
Scott
PostPosted: Tue Jan 01, 2013 4:01 pm
You'll need the first two cogs from an 11- up cassette and toss the 16T from the 12-29. Fortunately, that 16T is a loose cog.
I expect that you'll find the 15-17 shift to work poorly, since the teeth won't be properly timed for a 15-17 shift.
http://www.campagnolo.com/repository/do ... PART_B.pdf"
PostPosted: Tue Jan 01, 2013 4:20 pm
note that every one of the stock cassettes has the 15-16-17 sprockets. and 16t might be the most heavily used. personally, I'd much rather have that than an 11t. I'm using a 12-29 and very happy with it.
dangerous curves ahead
PostPosted: Tue Jan 01, 2013 4:33 pm
Worked flawlessly when riding in the Var region & up the Bonnette. The 11 in itself isn't the reason I prefer it to a 12 up cassette. It's the fact that the 13 is in a useable position, that is third not second sprocket. Makes it possible to use 34 x 13, which is almost identical to 42 x 16. Perfect cruising gear fir me.
I generally run 50/39 with an 11/23 or 11/25. Only when it's mountainous does the 34 and then the 29 come out to play!
PostPosted: Tue Jan 01, 2013 6:15 pm
Again, thanks for the feedback.
Along the same lines, I suppose: is any 11 speed Campy rear derailleur compatible with a 29 tooth cassette? I have a buddy who heard that you need a "pre 2010" RD for it to work?
Scott
PostPosted: Tue Jan 01, 2013 6:32 pm
Buy a veloce 13-29T and a 11-something tooth. All the sprockets are seperate with veloce so you can have anything you want so long as the cogs exist.
www.thecycleclinic.co.uk
PostPosted: Tue Jan 01, 2013 7:06 pm
Actually, it's late 2009 and newer shifters that will work with a 29T large cog. Only the early 2009 models had the different "B" screw mechanism, that won't allow the upper jocky pulley to clear a 29T cog.
Veloce cassettes are not a solution for an 11 speed, 11-29.
Users browsing this forum: cyclistcong, Exabot [Bot] and 51 guests
There are no new unread posts for this topic. Campagnolo compatible 10 spd 11-28 cassette
freemyheel
Sun Jun 03, 2012 9:42 pm
numbers505 View the latest post
There are no new unread posts for this topic. Campagnolo chain with shimano cassette?
Boss93
Fri Mar 22, 2013 12:03 pm
mikipov View the latest post
There are no new unread posts for this topic. campagnolo hyperons & recon cassette - problems
robleach71
Sat Feb 23, 2013 2:00 pm
robleach71 View the latest post
There are no new unread posts for this topic. Campagnolo SR Cassette: is this amount of wear normal?
incognitus
30
2267
Fri Oct 19, 2012 2:48 pm
DaveS View the latest post
There are no new unread posts for this topic. Shimano 10 speed + Campagnolo 10 speed cassette
rhyslewisdavies
Tue Jan 15, 2013 12:10 am
bm0p700f View the latest post
It is currently Mon May 20, 2013 2:51 am
