Post new topic Reply to topic  [ 4 posts ]
PostPosted: Tue Jan 01, 2013 3:09 pm
I have done a search but cant find the answer to this question or a better thread to put it in......
Aerolite pedals......Is the black (or red) plastic barrel bearing meant to rotate fairly easily around the pedal spindle or does the rotation movement come from the the barrel rotating (with the pedal) inside the cleat housing?
Hope this makes sense.
The reason i ask is that i have just got a set of second hand aerolites and the black barrel only rotates on the spindle with a MASSIVE amount of force if any movement at all when i try and do it with my hands........This didn't seem right to me????
Just need to know before i attempt to strip these down to see what is going wrong
Thanks
PostPosted: Tue Jan 01, 2013 3:35 pm
Aerolite pedals come in 4 pieces.The spindle the delrin(Black or red)barrel the bolt stopper and the cleats.The Delrin plastic should be easy to rotate.If not just remove the bolt stopper and clean the inside of the Delrin barrel.
Cervelo R2.5
Cervelo P2c
Cervelo R3
Parlee Z3
Parlee TT
PostPosted: Tue Jan 01, 2013 3:39 pm
Issue sorted now thanks. Previous owner had done the pedal bolts (bolt stoppers) up so tightly it had siezed the Delrin barrels. Thanks for the response. Stripped and cleaned out.
PostPosted: Tue Jan 01, 2013 3:40 pm
I had the black TT version with the drilled out sleeve which rotated easily by hand with minimal effort. I would be concerned if a " massive " amount of force were needed to rotate the sleeve.
Users browsing this forum: eric, KLabs, Yahoo [Bot] and 40 guests
There are no new unread posts for this topic. Time RXS pedal issue.
Juanmoretime
7
634
Tue Jul 17, 2012 2:31 am
fdegrove View the latest post
There are no new unread posts for this topic. Dura Ace Pedal bearing service/replacement
petromyzon
9
772
Fri Sep 14, 2012 7:10 pm
horse View the latest post
There are no new unread posts for this topic. inline barrel adjusters
addictR1
7
606
Fri Jan 18, 2013 7:15 am
condor View the latest post
There are no new unread posts for this topic. Stuck barrel adjuster
cloudnine
29
1190
Thu Sep 27, 2012 3:38 am
timzcat View the latest post
There are no new unread posts for this topic. Attachment(s) Front mech barrel adjuster scott s40 help please
blakemulder
Thu Jan 03, 2013 5:57 pm
It is currently Sun May 26, 2013 12:20 am
