Post new topic Reply to topic  [ 18 posts ]
Go to page Previous  1, 2
PostPosted: Wed Jan 02, 2013 3:53 pm
digitalnorbs wrote:
Tomma, did you ever think there where any issues in your ankle alignments, did you have any knee pain as result of your heel kicking out.........
For a time I thought to blame my shoes....that possibly the sole (in particular the heel area) of the left shoe was going soft as the issue grew a little at a time over a couple of years. New shoes ruled that out.
I've not had any issues with my ankles and no knee pain associated with this situation....just that bothersome left heel kicking out....and I forgot to mention earlier it also led to my left knee coming closer to the top tube and on a few occasions would brush against it. With the fixed cleats (carefully adjusted) my feet-ankle-knees all track nicely, no issues with joint pain, and as noted earlier I feel a better connection to the bike.
PostPosted: Fri Jan 04, 2013 2:57 pm
digitalnorbs wrote:
Im currently riding campy chorus and the q factor is pretty narrow on them, plus im all the way in on pedals, so that equation is out,
If the heel is pointing out that means the cleat is too far in which means the Q-factor if anything is too small, not large, correct?
I'm not sure what you mean by "all the way in on pedals"... cleat inbound (larger Q) or outbound (smaller Q).
If I run cleats too far out (small Q) I get knee pain.
http://djconnel.blogspot.com/
Fuji SL/1
 Post subject: Left heel pointing out
PostPosted: Sat Jan 05, 2013 4:09 pm
Two likely explanations:
1) your saddle is too high and your displaying right side bias... Ie favoring your dominant leg by shifting to the right to shorten the R stroke, and lengthening the L (hence left knee pain)
To fix lower your saddle 2mm at a time and see if this squares you up on your saddle
OR
2) you have a shorter right leg, therefore shimming will fix...
Therefore get someone experienced to measure both legs and compare, and shim appropriately...
Some articles well worth reading to help fix your fit issues are:
http://www.stevehoggbikefitting.com/blo ... side-bias/
http://www.stevehoggbikefitting.com/blo ... -shimming/
http://www.stevehoggbikefitting.com/blo ... of-a-shim/
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
Users browsing this forum: Exabot [Bot], Google [Bot], OrPe, tommasini and 48 guests
There are no new unread posts for this topic. Leaning my bike to the left
digitalnorbs
16
1567
Tue Apr 16, 2013 6:50 pm
kenleekenlee View the latest post
There are no new unread posts for this topic. Left Sram red crank bolt replacement
Omcannondale
Tue Jan 01, 2013 11:36 pm
kevhogaz View the latest post
There are no new unread posts for this topic. Clicking noise from left Keo Blade (cleat) only standing
ParisCarbon
9
535
Mon Dec 10, 2012 8:00 pm
Tricky1 View the latest post
It is currently Thu Jun 20, 2013 5:26 am
