Post new topic Reply to topic  [ 12 posts ]
PostPosted: Mon Dec 31, 2012 3:26 pm
I'm thinking of keeping my Major Tom wheels and putting some wider tubulars for spring riding.
But all I can seem to find is either Cyclocross 32-34mm tires, or bigger road (25-27mm) tires.
Is there something like "in between" ?
Big tire, stable on slush, occasional icy slush, sand over asphalt, dirt from winter accumulation.
Low rolling resistance. Not a full threaded cyclocross tire. I'm only riding on the asphalt.
Thanks,
Louis :)
http://www.ccsalma.com
PostPosted: Mon Dec 31, 2012 4:23 pm
Are you looking for something like a tubular version of the Michelin Jet? Maybe Vittoria XN would be fairly close.
The only question I'd have about tubulars in those conditions is the frequency of flats. I find that's the time of year I'm most susceptible to flats because little chips make their way through the casing.
Oh, and with ice, when I used to commute, I found that studs were the only safe thing then. Of course, they make any nice bike into a brick with an extra pound or so of rolling weight.
PostPosted: Tue Jan 01, 2013 3:15 am
What about a file tread cross tire? Might be hard to find narrower than a 30 or so
PostPosted: Tue Jan 01, 2013 3:30 pm
Yes, in a perfect world, I'd like to find a (hard to puncture) 28-30mm Challenge Grifo XS, or the like (Vittoria XN maybe)... :( . I also checked for Michelin Jet.
Not shure a 28mm road tire like the Paris-Roubaix would hold on these conditions.
Louis :)
PostPosted: Tue Jan 01, 2013 5:20 pm
I have been riding the classic herringbone tire for 20+ years in our Canadian spring weather. Never had a problem. If there is too much ice down to ride that tire, it is too dangerous to ride road anyway.
PostPosted: Wed Jan 02, 2013 3:39 pm
23mm ?
Tire pressure ?
Louis :)
PostPosted: Wed Jan 02, 2013 6:22 pm
Challenge has a 30mm tubular that's fairly "in between". Not sure if it's any good, but would certainly like to find out :-)
Bikes: Raceur, Beateur
PostPosted: Wed Jan 02, 2013 7:27 pm
There are a few 30mm clincher options, but I only see 32mm for tubulars.
Louis :)
PostPosted: Wed Jan 02, 2013 7:54 pm
Vittoria Pave CG comes in 27mm - have not tried it but have heard great comments
Challenge Paris-Roubaix comes in 27mm - this is my tire for the kermesse races and has done superbly
The only other I can think so and it might be a bit tougher but not as wide is Conti Sprinter Gatorskin 25mm - the least expensive of the 3 at below $100/pair
Racing and Training Cycling Tires
www.tiremaniacs.com
PostPosted: Wed Jan 02, 2013 8:20 pm
Louis: http://www.challengetech.it/products/road/eroica-027/en
PostPosted: Wed Jan 02, 2013 8:33 pm
Ok ! I missed that one, though it was only a clincher version.
I'll be looking at this one or the Parigi Roubaix.
Thanks,
The Vittoria Pave CG 27 might be a nice option too.
Louis :)
PostPosted: Wed Jan 02, 2013 8:37 pm
Louis wrote:
23mm ?
Tire pressure ?
Various tires and pressures. With respect to tires, I find that any of the classic herringbone tubulars work fine. I still like the Vittoria All-Weather's (but I am running out now) in 23mm (they seem a bit wider). As for pressure, it depends on the day. I will run them down to 85/95 front/rear, if it is really messy. If you rode higher volume (25mm or 27mm) Vittoria Pave tires, you could run them lower still...
Users browsing this forum: CarlosFerreiro, lechat, thprice and 41 guests
There are no new unread posts for this topic. Best tubular wheel for riding in wind and shock absorption
mariopoli
13
806
Fri Aug 10, 2012 10:28 pm
HammerTime2 View the latest post
There are no new unread posts for this topic. Help to sand Easton carbon components - Logos take off
Naturel
Sat Nov 03, 2012 4:47 pm
Rick View the latest post
There are no new unread posts for this topic. Frustrated Canadian - CAAD 10's in Vancouver??
[ Go to page: 1, 2, 3, 4 ]
604Yarks
50
2127
Thu Apr 04, 2013 7:37 pm
Y26 View the latest post
There are no new unread posts for this topic. Sram Red RD spring broken. Replacement available?
Mr.Gib
Mon Apr 22, 2013 5:59 am
bura View the latest post
There are no new unread posts for this topic. Campagnolo Index Spring Carrier
micropox
9
561
Mon Oct 08, 2012 11:44 am
micropox View the latest post
It is currently Wed Jun 19, 2013 1:02 am
