Post new topic Reply to topic  [ 23 posts ]
Go to page 1, 2  Next
PostPosted: Sun Dec 30, 2012 8:56 am
Just noticed my drive side SRM crank pedal thread has, for some unknown reason, come 'loose' (my Speedplay is able to be jiggled, in spite of being securely tightened).
Would a helicoil be a safe and reasonable solution to fix it?
Especially as my odds of being able to find a new drive side SRAM SRM crank arm is looking slim (to say the least!).
PostPosted: Sun Dec 30, 2012 9:28 am
Either that, or weld in some new material and redo the threads.
PostPosted: Sun Dec 30, 2012 10:11 am
Helicoils are used in the F15's radar antennas and other military airborne applications, which i presume are exposed to much more stress than your crank arm :wink:
Done correctly, it should be more than enough.
Oren
PostPosted: Sun Dec 30, 2012 10:58 am
If you don't have any joy, another option is to pick up a SRAM S900/S950 crank, as they are exactly the same arms as the SRM. should be a bit cheaper than buying direct from SRM
PostPosted: Sun Dec 30, 2012 11:24 am
Excellent.
And 'then...' it was drive side, I doubt the regular S900 has a mount for the SRM spider.
PostPosted: Sun Dec 30, 2012 12:21 pm
Hey nick, it said done correctly ......
You're screwed:)
Happy new year mate....
PostPosted: Sun Dec 30, 2012 12:59 pm
Location: somewere floating between here and the other side
In theory it is stronger because you go a size up.
I use a fair few hellicoils were i work i would not hessitate to use them.
Take your time and she'l be right (;
PostPosted: Sun Dec 30, 2012 1:02 pm
Pedal threads are unusual. No Helicoil made. I read somewhere of a company in France I think making a specific crank thread "helicoil like" repair kit.
dangerous curves ahead
PostPosted: Sun Dec 30, 2012 1:24 pm
Too. Many. Wattz.
PostPosted: Sun Dec 30, 2012 1:26 pm
Cyclus has a repair kit, can't think of who brings um in the country?.
PostPosted: Sun Dec 30, 2012 2:02 pm
here you go http://www.amazon.com/Var-Crank-Repair-Pedal-Thread/dp/B004YJ2XNA
now you can set up a crank thread repair business
PostPosted: Sun Dec 30, 2012 2:18 pm
Administrator
I was going to say VAR indeed. You beat me to it! :beerchug:
Follow me on twitter. I try to be interesting ;)
On Facebook!
PostPosted: Sun Dec 30, 2012 11:18 pm
I also feel that assuming you can get a helicoil in the correct fit, that it will be fine. We use them in our trucks from time to time with success, in load bearing applications.
We also still use the correct Locktite, that we would have used, had we done the job with out the helicoil?
Lastly, yes you could fill the crank arm and retap the hole, as a last resort.
Plumbers tape to get a tighter fit may work, but not as confidence inspiring as the first option for me.
Hope this help
Austke
P.S. Happy New Year!!! :beerchug:
2013 Giant TCR Advanced SL 0, 6.92kg
2013 Giant Defy Composite 2 M, 8.5kg - Wife's
Azzurro Torino 8.55g
Fuji 650 10.8kg
Miele Lupa Triple Tandem 38,89kg
PostPosted: Sun Dec 30, 2012 11:25 pm
Helicoil threads in an aluminum part are stronger than plain aluminum threads. Many, many parts that are screwed/unscrewed on a bike often will have a helicoil from the factory. Cable pinch bolts, front derailleur mount, some mountain shifter and brake clamps...
Yes, pedal thread helicoils are generally available, for both sides.
all that said, I don't think it will help you. To be clear, your crank is a Sram crank with an SRM, right? carbon arms? S975-type? If so, it is the aluminum threaded part that is loose in the carbon arm, no (simple, convenient, cost effective) fix for that.
PostPosted: Sun Dec 30, 2012 11:36 pm
This is my concern, as I think this is what is going to be found.
I think it's the whole structure within the carbon that is loose...
Post new topic Reply to topic  [ 23 posts ]  Go to page 1, 2  Next
Users browsing this forum: allenpg, Bing [Bot], Exabot [Bot], Google [Bot], iswmhamc891, rijndael and 45 guests
There are no new unread posts for this topic. Any way to repair campy 11 speed chain>
reemo
9
719
Thu Dec 27, 2012 2:26 pm
Wcl4 View the latest post
There are no new unread posts for this topic. Another which frame for me thread..
Colin
Sat Jan 05, 2013 10:30 pm
Colin View the latest post
This topic is locked, you cannot edit posts or make further replies. ANOTHER light tire thread. Sell to me
Bianchi10
7
572
Tue Jan 01, 2013 11:23 pm
fdegrove View the latest post
There are no new unread posts for this topic. aluminum or aluminium bike thread???
tigoose
Tue Aug 14, 2012 4:58 am
tigoose View the latest post
There are no new unread posts for this topic. Kinlin - Halo - IRD the definitive thread....
TimF
Sun May 27, 2012 1:34 pm
TimF View the latest post
It is currently Sat May 25, 2013 5:16 pm
