Post new topic Reply to topic  [ 5 posts ]
PostPosted: Sat Dec 29, 2012 11:09 am
Hi everybody,
I used to make all repairs on my bike. This sometimes has bad consecuences... I had a creak noise on my crankset ( new Sram Red Gpx ). I tried to disassemble with first a 10mm allen key, Big mistake. This is the selfextractor mechanism. After this I used a8mm key for the internal bolt, and i could take off the crank arm and tightened the crankset. Now the problem is that the external 10mm part is broken ( its made from aluminium). Anybody nowks if exits a replacement or i need to buy a new left crank? In Sram site doesnt seems to exit. In this moment is an aesthetic problem...but all you now what is aesthetic for i biker...
Sorry my bad English.
Oscar. Valencia (Spain)
PostPosted: Sat Dec 29, 2012 2:18 pm
Online
Pretty sure the 10 mm part screws out and I have been able to get almost every part I have ever needed from SRAM (you have to ask the right bike shop-most will say no way.) I have bought a replacement bolt for an XX rear deraileur which is a part that has to be pressed in so you know Shitmano would never make that available. I have gotten a cover plate for a bottom bracket and other small parts that you know would not be available from others.
For certain parts stiffer is more important than lighter.
PostPosted: Sun Dec 30, 2012 11:12 pm
Save weight and leave the outer collar off until you need to remove the crank!
PostPosted: Sun Dec 30, 2012 11:50 pm
Thanks for your replies :welcome: , Maybe take off the collar is best option if it isnt necessary for normal use;
i will ask my mechanic for a replacement for this collar,
:beerchug:
PostPosted: Tue Jan 01, 2013 11:36 pm
I ordered the exact same part, from my LBS. They said any SRAM dealer could get small parts like that. They had a catalog, that broke down all the parts of the crankset, by number.
Users browsing this forum: Bing [Bot], iamalex, NealH and 75 guests
There are no new unread posts for this topic. LOOK 695 - Zed 2 crank chainring bolt replacement option?
supertight
12
1997
Tue Sep 04, 2012 11:51 am
brycerider View the latest post
There are no new unread posts for this topic. Attachment(s) replacement Ti bolt safe here?
Bianchi10
10
500
Sun Nov 04, 2012 6:21 am
OrPe View the latest post
There are no new unread posts for this topic. Replacement bolt for S-Works seat collar
Nismo4x4
Mon Aug 06, 2012 6:54 pm
crohnsy View the latest post
There are no new unread posts for this topic. 7900 Front caliper pivot bolt damaged. Replacement options?
racermech
Tue Sep 18, 2012 1:18 pm
oysters View the latest post
There are no new unread posts for this topic. Sram Red RD spring broken. Replacement available?
Mr.Gib
Mon Apr 22, 2013 5:59 am
bura View the latest post
It is currently Tue May 21, 2013 5:02 pm
