Post new topic Reply to topic  [ 16 posts ]
Go to page Previous  1, 2
PostPosted: Mon Dec 31, 2012 5:48 pm
Geoff wrote:
the factory uses a more accurate eddy current brake instead of a weight.
I presume you are referring to the actual factory in Germany because for those of us in the US, since most SRM dealers do not stock the powermeters, SRM USA typically calibrates a new powermeter using a test stand with a weighted length of chain run over the chainring which is quicker than hanging weights off the crank arm.
Post new topic Reply to topic  [ 16 posts ]  Go to page Previous  1, 2
Users browsing this forum: Bing [Bot], Google [Bot], Google Adsense [Bot], Kjetil, LionelB, Meatball, sanrensho and 54 guests
There are no new unread posts for this topic. SRM zero offset fluctuation after battery change
pcates
11
287
Thu Apr 18, 2013 12:04 am
Squint View the latest post
This topic is locked, you cannot edit posts or make further replies. cannondale si sl crank install
logy
Sat Mar 30, 2013 11:55 pm
There are no new unread posts for this topic. BB30 Loctite, cure before or after crank install?
mvz2
7
445
Tue Jan 08, 2013 3:04 am
mvz2 View the latest post
There are no new unread posts for this topic. To install or not to install: Fenders on winter/commuter
LouisN
28
982
Tue Mar 05, 2013 9:19 pm
motorthings View the latest post
There are no new unread posts for this topic. SRM zero offset value, off the scale.
coureur1
Wed Mar 06, 2013 3:45 am
It is currently Wed May 22, 2013 7:32 am
