Post new topic Reply to topic  [ 6 posts ]
PostPosted: Sat Dec 29, 2012 5:41 am
anyone have the stack and reach numbers for a 2011 tarmac. I'm currently on a 56 Litespeed Icon and was thinking if a 54 cm tarmac would fit me. Is the SL4 going to be too low? I am 179cm with a 33 inch inseam.
PostPosted: Sat Dec 29, 2012 6:51 am
SL4 geo according to:
http://www.pacosbike.com/product_info.p ... s_id=36066" onclick="window.open(this.href);return false;
stack and reach 543 and 387 for 54
r o y g b i v
PostPosted: Sat Dec 29, 2012 7:55 am
I think the 2011 tarmac has a taller HT.
PostPosted: Tue Jan 01, 2013 3:25 am
is stack/reach more important or top tube length. the difference between TT lengths is 17mm between the 54 and 56 but the reach difference is only 8mm. The shops says its a difference of a 2 cm stem between the 2 bikes. I'm currently riding a 56cm Litespeed Icon with a stack of 551 and reach of 391. After adding the Chris King headset it seems the 56 cm Tarmac is still lower than my bike. Which bike would fit most closely?
PostPosted: Tue Jan 01, 2013 4:46 am
Stack/reach tells you more than just top tube length. Add seat tube angle to top tube lengths and you have similar tools. as with any tool, you have to know how to use it.
I haven't checked the sizes of the sl4, but I assume the seat tube angles are close or equal. Then, as with any bike, when the head tube gets taller, the reach measurement is naturally shorter. If the head tube angle was 90degrees, then stack would not affect reach. so you are looking for a certain reach measurement, at a certain stack measurement. Having the right reach at the wrong stack is NOT the same.
With top tube length, a frame can change seat tube angle, affecting overall reach of the bike without one realising it. And it does not tell you how high/low the bars can be.
PostPosted: Tue Jan 01, 2013 12:57 pm
Seat position is a different measurement from stack and reach.
You always set your seat to the same position in relation to the BB, or you should. You have to select a seat post with appropriate setback to allow your preferred position so assuming you will be able to achieve that position (highly unlikely that you wont be able to), that leaves stack and reach as the appropriate variables to consider for frame fit regardless of seat tube angle.
r o y g b i v
Users browsing this forum: G6612, Google [Bot], lasrever, StefanG, woz9683 and 61 guests
There are no new unread posts for this topic. Attachment(s) Help me to calc stack and reach for a Scott Cr1 -08 frame
tri
Sun Jan 20, 2013 11:58 am
cyclenutnz View the latest post
There are no new unread posts for this topic. 2005 Scott Cr1 team issue reach and stack for 54 frame
digitalnorbs
Thu Jul 26, 2012 8:56 pm
There are no new unread posts for this topic. Specialized Tarmac Sizing (reach?)
baldkingpin
Tue Sep 04, 2012 4:24 pm
baldkingpin View the latest post
There are no new unread posts for this topic. stack height on pedals
chippan
Thu Jul 19, 2012 5:51 am
Brandonnie View the latest post
There are no new unread posts for this topic. FSA headset zero stack cone spacer
Fri Feb 08, 2013 11:02 pm
113245 View the latest post
It is currently Fri May 24, 2013 2:38 pm
