Post new topic Reply to topic  [ 5 posts ]
PostPosted: Fri Dec 28, 2012 7:36 pm
I just puchased a used pair of 20/24 DT Swiss 240S hubs from a guy on the German Tour forum. Milage is unknown. Bearings and freehub spins like new but it is clear to see that they have been build. On closer inspection of the front hub I have noticed some lines starting from the spoke holes. They all go in the same direction and are only visible on the inside surface of the flanges. On one flange they are present at 8 of 10 holes but on the other one it's only 2 of 10. They vary in lenght and at some holes there are more than one line. Have any of you see something like this before? It look very much steactual as they all go in the same direction, so my thoughts are to return them. I just never heard of this happening on a DT Swiss 240S hub, but only on the old machined DT Hügi 240. For information the hub has been laced radial. Here are a few pictures.
It's online again:The Machinist
PostPosted: Fri Dec 28, 2012 7:40 pm
That's so funny. I was just putting some new tires on a set of wheels with DT 240's on them and noticed the same thing...only these cracks go all the way across the flange. I can see daylight through 'em. I was just logging-in to see if you guys have had luck with DT returning 240's to DT. I have heard that they replace them if the flanges fail...
PostPosted: Fri Dec 28, 2012 8:58 pm
The flange of the 240 can break if you use radial patern on a non radial front-hub. The earlier 240's came in two flavors, radial and non-radial.
I know because it happened to both me and my brother. A misunderstanding between the LBS and DT. He had ordered Radial hubs, they sent him the regular and he thought they were for Radial (They were new, so he hadn't seen them before). DT replaced them of course. Since then no issues in 8 years.
PostPosted: Fri Dec 28, 2012 9:19 pm
Yes I have seen that and that was also my first thought. But wouldn't a 20H hub always be laced radial and therefore DT only offer this is a radial version?
PostPosted: Sat Dec 29, 2012 7:43 am
Indeed, that would make sense. Does it still have the sticker in the middle? Mine says "radial".
Then the other option could be overtightened spokes?
Users browsing this forum: oreoboreo, woz9683 and 45 guests
This topic is locked, you cannot edit posts or make further replies. dt swiss 240s freehub
ColnagoJohn
Tue Mar 05, 2013 1:59 pm
maverick_1 View the latest post
There are no new unread posts for this topic. DT Swiss LF 07 hub dimensions (Specialized roval 240S) ?
Anders
Wed Apr 17, 2013 8:00 pm
Anders View the latest post
There are no new unread posts for this topic. Attachment(s) Cracked a Zipp 303 Yesterday
sethjs
16
1397
Mon Jun 04, 2012 5:03 am
CharlesM View the latest post
There are no new unread posts for this topic. Need help with cracked carbon frame
WasFab
Mon Jul 02, 2012 10:49 pm
Zakalwe View the latest post
There are no new unread posts for this topic. 2 Cracked stems? Deda and ITM
xcnick
Mon May 28, 2012 9:44 pm
xcnick View the latest post
It is currently Sat May 25, 2013 3:48 pm
