Post new topic Reply to topic  [ 9 posts ]
PostPosted: Fri Dec 28, 2012 10:09 am
Location: somewere floating between here and the other side
I just bolted on a black stem and bar on my bike and the all black look works for it !(; now im chassing a black lightweight seatpost im contamplating getting a superlogic and scratch the name of,..
Is there anybody out there making a stealth or all black leightweight seatpost that has roughly 25 mm setback ?
Thanks mick
PostPosted: Fri Dec 28, 2012 10:38 am
As you have suggested, find the right carbon seatpost for you - ideally one with minimal graphics and the corresponding carbon weave pattern to your other black components then sand the whole post to get that 'stealth' matt black look. Take it to an auto body repair shop for a quick and easy solution for them to spray it with clear coat again if you would prefer it back to gloss once you have removed the graphics.
I have used similar processes (both sanding and using a blade) in my 'Stealth' thread:
viewtopic.php?f=3&t=110609" onclick="window.open(this.href);return false;
PostPosted: Fri Dec 28, 2012 10:43 am
Dorico Team Stealth.
Neo Cycles
PostPosted: Fri Dec 28, 2012 12:30 pm
But Dorico isn't by any means a light post. My ltd 27.2x350 187g!
Superlogic seems to be a good choice, especially if you are after black UD finish. The good thing about Ritchey is the graphics are painted on top of the coat and are very easy to remove.
At least the components I had in my hands.
Cervelo R5 VWD 5637g/12.43lb
Cannyon Ultimate slx 5592g/12.33lb
Pronghorn XC SW Race 8284g/18.26lb
PostPosted: Fri Dec 28, 2012 1:18 pm
What size post are you looking for? Unfortunately, a set back post isn't going to be as light as a zero offset. I recently picked up my Hylix carbon zero offset for $70 off ebay. It is a 27.2x400. After trimming it down in length and sanding off the graphics (sorry just did the graphic sanding last night and don't have a picture-but have included on prior to it) the weight came in at 131g. None the less, I know you need a setback but you can find quite a bit on the bay. Ritchey posts are pretty nice though.
09 Pinella w/ Record 10spd
http://1spd.blogspot.com/
PostPosted: Fri Dec 28, 2012 4:19 pm
viewtopic.php?f=3&t=110609" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
That's pretty much it. I had the graphics removed from an FSA K Force Light seat post and then painted gloss. Matte is hard to get right. Did the same for the stem and the bars.
Local guy did it all for 50 bucks. Guys in auto body repair shops are usually up for making some easy money on the side.
PostPosted: Fri Dec 28, 2012 4:40 pm
I was after the same thing, matte black post to go with the new Ritchey C260 superlogic stem. BUT the matte superlogic seatpost won't be available in the US until Feb 2013 per Ritchey.
I'm going with an Easton EC70 post with new black graphics and replacing the top clamp with yokes. It'll be lighter than the EC90 :mrgreen: The EC90 and EC70 share the same post.
S P L I T: 2010 Meivici: 14.4 lbs | 2003 Odile: 19 lbs | Hunter Cycles Cyclocross: 17 lbs | 2013 Dundee Cycles Jewell 29er: 17 lbs
PostPosted: Fri Dec 28, 2012 9:10 pm
155gms @ $90. Could easily sand off what little paint is on it.
PostPosted: Fri Dec 28, 2012 9:51 pm
You didn't mention a budget so assuming that doesn't matter the Mcfk would be my recommendation. It comes with just a single pair of stickers which peel off without a problem. As for weight there isn't much in it's class in terms of setback posts. There is also a consideration for the weight of the rider with the Mcfk.
Fair Wheel Bikes
Fair Wheel Blog
Friend me on Facebook for behind the scenes updates
Users browsing this forum: Bing [Bot], bman11, Exabot [Bot], Google [Bot], xis and 38 guests
There are no new unread posts for this topic. Attachment(s) Pro Stealth Evo Seatpost Weight
Dougan
Thu Dec 06, 2012 7:12 pm
civdic View the latest post
There are no new unread posts for this topic. Cateye Stealth 50?
brettmess24
Sun Mar 03, 2013 4:27 pm
brettmess24 View the latest post
There are no new unread posts for this topic. Attachment(s) Carbon Stealth Groupset
[ Go to page: 1 ... 4, 5, 6 ]
lo5707
87
6345
Sat Mar 30, 2013 12:11 am
MDH View the latest post
There are no new unread posts for this topic. Zipp Vuka Stealth
marcelflash
Mon Apr 29, 2013 10:56 am
marcelflash View the latest post
There are no new unread posts for this topic. Carbon seatpost flex (Seatpost sadlle mounting)
Burgunder
13
1725
Tue Oct 02, 2012 8:13 pm
Slowman View the latest post
It is currently Sat May 25, 2013 12:43 am
