Post new topic Reply to topic  [ 9 posts ]
PostPosted: Thu Dec 27, 2012 7:44 pm
I made the mistake of lubricating the barrel adjuster for the front mech and now it keeps slipping mid ride which is a real pain and I can find no way of getting it apart to clean it. Any help would be very much appreciated!
PostPosted: Thu Dec 27, 2012 10:40 pm
I take it you used spray lube then, as otherwise you would know how to take it apart if you had done so to lube it in the first place?
Without seeing your setup these would be the basic steps required i would imagine.....
1. Release the cable from the FR (make sure you have shifted down to the lower chain ring first to release the tension on the cable). Note the direction of travel (path) of how the cable was installed on your mech (for when you re-install it in step 4).
2. Unistall the cable to the mentioned barrel adjuster remove and clean.
3. Reinstall cable
4. Pulling on the cable firmly to take up all of the cable tension, re-install it to the FD using the same path as mentioned in step 1.
5. Trim if necessary if you have chain rub.
PostPosted: Thu Dec 27, 2012 10:51 pm
Hi and thanks for the reply. its step 2 that has me pulling my hair out - the adjuster unscrews then hits a stop and it wont go any further - does it unscrew to 2 parts? Big mistake lubricating the adjuster - it is now held in place with tape to stop it unscrewing and it looks terrible.
PostPosted: Fri Dec 28, 2012 5:22 pm
Post a pic and then it should be easier giving advice
PostPosted: Sun Dec 30, 2012 7:21 pm
Problem now resolved but look what I found on one of my other bikes!
Presumably I cant name and shame the manufacturer?
ok, cant upload a picture from my pc, only from a website, is this correct?
PostPosted: Thu Jan 03, 2013 11:55 am
Shock horror! please note - this is NOT from my Scott bike, but one of my other road bikes - Am I allowed to name and shame the brand name?
PostPosted: Thu Jan 03, 2013 5:42 pm
No. You can name and shame that particular housing end cap. Let's call him Jim.
Bad Jim! Shame on you, you didn't do your job. You're fired.
It happens on occasion. If you replace it with another open plastic end cap, it is unlikely to happen again. If you use a metal (still 4mm) end cap, it is less likely to happen again, but some of those barrel adjusters prefer a plastic one at least on the top side.
PostPosted: Thu Jan 03, 2013 5:48 pm
thats the outer cable showing the strands which has obviously not been cut correctly! very poor quality indeed...
PostPosted: Thu Jan 03, 2013 5:57 pm
There are instances where a correctly cut housing will push through an end cap. sometimes sh## happens.
Users browsing this forum: Bing [Bot], CSKeller, Exabot [Bot], go4custom, Google [Bot], Google Adsense [Bot], hornedfrog and 53 guests
There are no new unread posts for this topic. Stuck barrel adjuster
cloudnine
29
1188
Thu Sep 27, 2012 3:38 am
timzcat View the latest post
There are no new unread posts for this topic. Shimano 5600 Brake cable barrel adjuster - which one?
Leviathan
Sun May 12, 2013 6:04 pm
Leviathan View the latest post
There are no new unread posts for this topic. Attachment(s) Anyone opened up a Di2 Front mech for servicing?
WeightySteve
16
3177
Sat Sep 29, 2012 7:29 am
ttts2 View the latest post
There are no new unread posts for this topic. Attachment(s) SRAM Red Front Mech - missing bolt
Miller76
Sat Dec 29, 2012 7:41 am
theremery View the latest post
There are no new unread posts for this topic. Front Mech, compact/double specific?
alexh
Tue Apr 16, 2013 1:38 pm
alexh View the latest post
It is currently Thu May 23, 2013 5:27 am
