Post new topic Reply to topic  [ 4 posts ]
 Post subject: Flite Gel Flow noise
PostPosted: Wed Dec 26, 2012 5:26 pm
I've been using this saddle for only a brief amount of time. This past weekend I had a squeaking noise while riding that I couldn't figure out. I've torn the bike apart looking for it. Thought it was the seat post but now I think it's actually the saddle.
Looks like the shell might be contacting the rails up by the nose. Happens mainly when I'm spinning more than hammering. So I'm guess a little bounce contributes to it. I know, hammer more and spin less.
Anyway, I did some searching on the interweb and saw a few items about it but no definitive solution.
Has anybody had an experience like this, and if so were you able to correct it?
 Post subject: Re: Flite Gel Flow noise
PostPosted: Wed Dec 26, 2012 5:34 pm
haven't got the saddle, but i'd try some spraying some silicone lube in there and see if it cures things
edit - before that, i'd check the clamp, clean the rails etc.
PostPosted: Wed Dec 26, 2012 8:37 pm
If it is definitely the saddle rail junction, then just apply some white lightning crystal grease (or whatever you use for headsets and pedals axles) to the area and it should be fine, It's worked for me before with Fizik saddles.
PostPosted: Mon Dec 31, 2012 4:31 pm
Lube the rail mount point with carbon paste. Also, I had this saddle, the nose does slip/move around at the mount points just a bit with force, assume by design. Put some lube up in the nose contact parts and see if that fixes it.
Besides those two points, not sure where else it could come from.
Users browsing this forum: Burgunder, Google [Bot], simnorm, slyboots and 39 guests
There are no new unread posts for this topic. Selle Italia Flite 2013
naylor343
Sun Mar 31, 2013 9:47 pm
naylor343 View the latest post
There are no new unread posts for this topic. Compatibility - Ritchey SL carbon post and SL Flite gel
glowder
Mon Jun 25, 2012 2:43 pm
glowder View the latest post
There are no new unread posts for this topic. SL4 NOISE HEADSET-BB ???
vagbouk
Wed Apr 03, 2013 11:04 pm
Marwin3000 View the latest post
This topic is locked, you cannot edit posts or make further replies. Super Record Noise
brt570
Mon Sep 10, 2012 10:20 pm
bikerjulio View the latest post
There are no new unread posts for this topic. Noise on the front wheel - HELP!!
cezinho
13
734
Fri Jul 27, 2012 7:49 pm
cezinho View the latest post
It is currently Thu Jun 20, 2013 12:54 pm
Selle Italia Flite Gel Flow
