Post new topic Reply to topic  [ 88 posts ]
Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Thu Dec 27, 2012 3:21 pm
Very nice,I love the look of carbon :thumbup:
http://www.motomatt.com/?p=3831
http://gallery.motomatt.com/v/My+Mountain+Bikes/Trigon+MQC05+Full+Carbon+Bike+15lb+89oz/IMG_1893.JPG.html
http://www.strava.com/athletes/motomatt
PostPosted: Thu Dec 27, 2012 4:45 pm
Great work on the parts. I picked up a Hylix carbon seat post off the bay for $70 and after cutting it down to length got it down to 131g. But it has some nasty white/red graphics on it that I will need to sand down. Fortunately, they are on top of all coating so simple sanding should get them off pretty quick. I wish I would have seen this thread before installing my new bars last week as they too have frickn logos all over the flat portion (ITM Pathom 2) and are glossy. I guess that will just have to wait until it is time to redo the bar tape since I hate to waste some brand new Lizard Skin dimpled tape.
Was debating on swapping out my rings (Chorus Compact 10spd) for some TA's or something but it doesn't look like it will be that large of a weight reduction going that route. I don't race and would want some longevity out of whatever rings I get which concerns me with the Fiber Lites. Love to know if anyone else is running those and how they are holding up (as well as that nifty cassette you got!)
Looks like I'll also be swapping out my der's as well to SR (currently on 10 spd rec) in an effort to shave some weight and eventually move to 11 spd. Runing Centaur V3 levers now and while they have the carbon blades (which thanks to you, I now need to pull and strip :D ) they are still heavier than the records or SR but since I'm on 10 spd they will have to do for now.
None the less, great work and keep us posted on the rings and cassette.
09 Pinella w/ Record 10spd
http://1spd.blogspot.com/
PostPosted: Thu Dec 27, 2012 5:23 pm
Ok, I know this has been covered before but I just want to make sure I am on the same page. You basically just used a razor blade to scrape the clear coat off the lever blades? Does it just start to chip away once you get it started? The last thing I want to do is gouge the carbon itself. I guess I am going to try this out on my lever blades before I take a blade to my bars down the road (just the bar tops of course-no sense in scraping what it going to be covered up by tape)
 Post subject: Carbon Stealth Groupset
PostPosted: Thu Dec 27, 2012 9:08 pm
@1spd,
Some 1200-1500 dry and wet will do the trick fairly quickly and leave a great smooth matt finish without taking off all of the clear coat. Doing it this way means you can blend areas where more clear coat has been removed to get rid of graphics and the rest of the clear coat which you sand to achieve the same effect very easily.
Taking off the bar tape, sanding the bars and re-installing the tape (particularly if you are only interested in sanding the exposed areas) should be a relative quick job and most bar tape can be re-installed no problem without damaging it.
The fibre-lytes are pretty rubust from what i have read from others that have used them. Do an image search for the on google and read the reviews. Some quote 3000-5000km if looked after properly which is outstanding for what they are. Or speak to stephen@fibre-lyte for some honest feedback on his rings.
You should be able to box cleaver and upgrade gradually to 11Sp from 10 Sp - like i and many others have experienced - start with the RD and 2012 FD, then chain. Make sure to change the cassette and shifters last and at the same time - that should work fine.
Cheers :beerchug:
The clear coat on campy levers from what i have found is quite thick and brittle and chips off like a dream. It is quite hard to gouge the carbon, you will notice when you have hit it as the blade will stop as it easily goes through the clear coat. I would start somewhere subtle them progress from there stripping/chipping away by sliding/pushing against the surface of the carbon under the clear coat (think of it as lifting the clear coat off with the tip/edge of the blade). If this fails for any reason use the scraping method which takes longer, holding the blade at 90 degrees to the lever surface and dragging back and forth. You will know when you hit carbon and it is difficult to damage the carbon this way too which is also good to know. Good luck
PS. Sanding the bars with 1200-1500 dry & wet would be better than a blade if the graphics are near the surface and you want to go Matt. It is easier, quicker and blends better.
PostPosted: Thu Dec 27, 2012 9:54 pm
shoemakerpom2010 wrote:
What frame are you using as these parts would look at home on a Canyon!
Agreed, the Canyon Ultimate CF SLX 2013 looks sexy and is nice and light too. I am building this up initially on a cheap 3k Carbon Chinese frame while i continue to save for a super light frame for next year.
Thanks :thumbup:
PostPosted: Fri Dec 28, 2012 1:02 am
What handlebar is that?
Did you sand it down as well? Thanks
Sent from my iPad using Tapatalk HD
PostPosted: Fri Dec 28, 2012 10:07 am
Sisbud wrote:
What handlebar is that? Did you sand it down as well? Thanks
It is from the bay from China (seller Carbonwheels2011). Internal cable routing and obviously integrated stem. It is surprisingly very well made from what i can tell. It is only 360g in size 420mm bars x 110mm stem (claimed 400g so very happy). Swapped out the stock stem bolts for black Ti bolts too :D
And yes, sanded lightly with 1500 Dry & Wet although you can buy them matt to start with to save you doing this (which i should have done really :oops: )
Before sanding
After sanding
PostPosted: Fri Dec 28, 2012 12:14 pm
Taking off all clear coat would save you extra few grams.
Recently I cleared Token bar 190g to bare carbon 179g.
Cervelo R5 VWD 5637g/12.43lb
Cannyon Ultimate slx 5592g/12.33lb
Pronghorn XC SW Race 8284g/18.26lb
PostPosted: Fri Dec 28, 2012 12:47 pm
Normally, I would agree that pulling the bars, tape, and levers is a quick ordeal as well as replacing it all. However, on this particular set up it is a bit of a PITA! My bars don't have a true internal routing system like yours do but it is internal none the less as you can see in the picture.
To do the sanding on these bars, I basically have to disconnect all cables, remove them, remove the bar tape, and levers. I'm sure I can get the tape off pretty easily but since this tape doesn't stretch, I'm sure it will have some memory and perhaps not go back on as cleanly. None the less, I'll need to pull the levers anyway if I want to attack the blades so perhaps if it does snow this weekend like they are talking about it might be the perfect time to work on this part of the project.
The graphics appear to be under the clear coat or between it but definitely not on top of it (hard to see from this picture I know but you can see what I'm working with here) Bars are the ITM Pathom 2 and weigh in at 207g. Not the lightest thing out there but it met all my criteria of being a flat top bar with internal cable routing, and a compact bend. Most importantly, they are about 30g lighter than what I took off!
I sanded the graphics off my seat post last night (they were on the surface on each side) using 600 gritt wet and was done in less than 10 min. The post had a matte finish to start with so I then hit it with 1500 to blend it all. Looks like it came that way now! With that said, I am thinking that I will start with 1000 and see if that puts a dent in the bars. If not then I'll drop down to 600 and go at it and work my way back up.
Thanks for the info on the lever blade techniques, I'll be giving that a shot here soon enough.
PostPosted: Fri Dec 28, 2012 3:33 pm
Before sanding
After sanding
Thank you for the information. Last question, is that compact handlebar or ergo?
PostPosted: Fri Dec 28, 2012 3:52 pm
Dang, that is light. To compare, my Pro stealth EVO is 400g 120/42. Well done!
S P L I T: 2010 Meivici: 14.4 lbs | 2003 Odile: 19 lbs | Hunter Cycles Cyclocross: 17 lbs | 2013 Dundee Cycles Jewell 29er: 17 lbs
PostPosted: Fri Dec 28, 2012 4:58 pm
split wrote:
Thanks, glad you think so. I know it is heavier than a load of 2 piece up-front setups but I love the combo look - much 'stealthier'.
Thanks for the comparison.
PostPosted: Fri Dec 28, 2012 5:01 pm
It is an ergo shape (ie the bar tops are ergo blades rather than round) if that's what you mean.
PostPosted: Fri Dec 28, 2012 10:43 pm
stephen@fibre-lyte wrote:
Juggler wrote:
I use the Stronglight CT2 on my road bike... and since I use the small ring from time to time (and use Di2) it might not be the best idea
Won't be a problem :wink:
For everyday riding we do recommend the Lightweight 2 version, which is only slightly heavier but also stiffer and we have a number of customers who have run or are running these chainrings with Di2 with no problems at all. The Lightweight versions that the OP has are slightly lighter and hence slightly (and I mean slightly) more flexible but there are still lots of customers riding them. How many are using Di2, I have no idea.
storck 019 by storck4, on Flickr
I'm one of them. I've been very happy with my Fibrelyte lightweight 2 rings as an everyday componant with Di2.
PostPosted: Sat Dec 29, 2012 5:14 pm
Here is a quick pic of the work I pulled off last night. Took me a total of about 5 frickn hours! I had to scrape my levers rather than chip/cut at them with the blade because as I found out the cheap @$$ Centaur lever blades are wrapped aluminum w/ a very think/single layer of carbon! What BS!
Didn't get a pic of the bars on the scale as my battery died in the camera but they started out at 207g and came in t 199g after the stripping so I'm pretty happy with that.
Also, here is a picture of the seat post after removing the logos from it.
Post new topic Reply to topic  [ 88 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
Users browsing this forum: dvincere, Google [Bot], Majestic-12 [Bot] and 85 guests
There are no new unread posts for this topic. Cateye Stealth 50?
brettmess24
Sun Mar 03, 2013 4:27 pm
brettmess24 View the latest post
There are no new unread posts for this topic. Zipp Vuka Stealth
marcelflash
Mon Apr 29, 2013 10:56 am
marcelflash View the latest post
There are no new unread posts for this topic. Attachment(s) Pro Stealth Evo Seatpost Weight
Dougan
Thu Dec 06, 2012 7:12 pm
civdic View the latest post
There are no new unread posts for this topic. Help me choose a groupset!
Northoceanbeach
42
1849
Wed Feb 20, 2013 5:50 am
Northoceanbeach View the latest post
There are no new unread posts for this topic. How to lighten Ultegra Di2 groupset ?
quiglet13
Sun Dec 09, 2012 2:58 pm
drhule23 View the latest post
It is currently Mon May 20, 2013 9:51 pm
