Post new topic Reply to topic  [ 88 posts ]
Go to page 1, 2, 3, 4, 5, 6  Next
 Post subject: Carbon Stealth Groupset
PostPosted: Tue Dec 25, 2012 7:03 pm
My first 'proper' post on WW - hope you like it.........
This is my mix and match groupset for my first WW project - A carbon stealth build - Tuning almost complete but some hopefully respectable weights nevertheless. Sourced all the bits from the bay pretty cheaply then tuned and sanded where my currently limited skills allowed.
My main aim was to achieve a stealthy matt carbon 3k finish rather than uber lightweight - but it comes in naturally light anyway:
Crankset - Tuned Stronglight Helion with Fibre-Lyte Chainrings - 450g (573g with BB)
Shifters - Tuned Campy Record 10 Speed - 305g (without hoods) - Awaiting BTP Hoods (20g claimed)
FD - Tuned Campy SR (2011) - 70g
RD - Tuned Campy SR (2011) - 146g
Brakes - Tuned TRP R950's - 227g (Without pads)
Cassette - Black Ceradure 10 Speed 12-25 - 88g (with locking!) - Lightest in the world, apparently :D .
Chain - KMC X10SL DLC All Black - 252g (Full length)
Would love to hear your comments, feedback, questions, advice etc..............
PostPosted: Tue Dec 25, 2012 7:25 pm
Mmm, carbon.
What tuning did you do? Let us know how the cassette shifts and lasts.
PostPosted: Tue Dec 25, 2012 7:31 pm
Wowza
PostPosted: Tue Dec 25, 2012 7:33 pm
Mainly removed the clear coat and upgraded bolts, jockey wheels and easy stuff like that - will post each individual component and details shortly.
PostPosted: Tue Dec 25, 2012 7:35 pm
Tremendous work, I love it. More pics of the build as soon as possible please.
Parlee EU
Lightweight UK
www.amontour.cc
PostPosted: Tue Dec 25, 2012 7:56 pm
Like the look.
Confused by the SR stuff. It's 11 speed and not compatible with those shifters, & chain. Sorry. Suggest you look for 10-speed front and rear derailleurs and do your magic on them instead.
Or a cheaper alternative would be to get an 11-spd KMC chain, and play with the RD cable attachment, as it's only a small difference in ratios.
dangerous curves ahead
PostPosted: Tue Dec 25, 2012 8:10 pm
This set-up should be compatible - I have lots of mates riding similar set-ups (mix & matching 10 & 11 Sp) with no issues and there are loads of threads out there confirming this set-up will work:
viewtopic.php?f=3&t=81901" onclick="window.open(this.href);return false;
viewtopic.php?f=3&t=108692" onclick="window.open(this.href);return false;
viewtopic.php?f=3&t=90420" onclick="window.open(this.href);return false;
Most importantly, i have matched the shifters, cassette, chain and chainrings. The SR 11Sp derailleur cages can both accommodate a 10 Sp chain and are therefore governed by the 10 Sp shifters. In addition though just to make sure, i installed the 10 Sp 11T (and wider) Fibre-lyte Jockey wheels in the SR RD widening the cage and the SR FD cage was also widened slightly in the 2011 update to prevent chain rub thus improving the use of a 10 Sp chain, hence why i went with the 2011 SR FD and not 2010.
However, i do need to test out the Ceradure Cassette as not much feedback out there on these, but that should work as it is 10 Sp just like any other 10 Sp cassette working with SR RD.
I know loads of people will want to confirm/debate this but id rather not let this thread get into a discussion over compatibility as they get very long-winded and i have already confirmed with multiple other sources that this set-up will work.
PostPosted: Tue Dec 25, 2012 8:21 pm
Stronglight Helion (Time Branded) Carbon/Ti Crankset.
Original weight 537g (640g with BB)
Saved 66g with the fibre-lytes (50/38T) over stock (53/39T) chainrings (119g to 53g)
Saved 16g with a lighter BB spindle sleeve (22g to 6g)
Saved 12g by changing the stock crank bolt to Ti (16g to 4g)
Saved 2g in lighter chainring bolts (10g to 8g)
Saved 7g by removing clear coat (387g to 380g)
New weight 450g (537g with BB) - Total weight saved 103g :D
Half way through sanding
Sanding complete
Sanded Fibre-Lytes installed (without 4g Ti Crank Bolt) taking it to 450g
PostPosted: Tue Dec 25, 2012 8:38 pm
53 grams in total for both 50T and 38T? Sounds pretty light...
2012 Canyon Aeroad CF 8.0 Di2 (6.250 grams)
2010 Canyon Grand Canyon F6
2012 (2013?) Canyon Speedmax Evo (is ordered)
PostPosted: Tue Dec 25, 2012 8:54 pm
I know.....Worth every penny
Funny thing is you can get these in the same size rings but even lighter from Steve at Fibre-Lyte in their ultralight versions - these are their lightweight versions - they also have a stiffer version and an aero version too.
PostPosted: Tue Dec 25, 2012 8:59 pm
What do you do to get that finish? Do you just sand? If so, may I ask what you sanded with?
PostPosted: Tue Dec 25, 2012 9:00 pm
That is CRAZY light...
I use the Stronglight CT2 on my road bike... and since I use the small ring from time to time (and use Di2) it might not be the best idea.
But it is definitely tempting with that weight... :)
How much did you bleed for those?
PostPosted: Tue Dec 25, 2012 9:03 pm
PS. Love the look of the "gruppo"... stealth is awesome
PostPosted: Tue Dec 25, 2012 9:07 pm
The crankset and chainrings are sanded by hand back to raw carbon using 200 grade sandpaper and finished with 600 then 1500 dry then wet.
The brakes are lightly sanded to matt finish using 1500 dry and wet.
The dérailleurs and shifter lever clear coat was removed with razor blade and simply chipped away which left a completely smooth finish too.
PostPosted: Tue Dec 25, 2012 9:14 pm
Fibre-Lyte chainrings are in the region of £80-90/€97-110/$130-145
Check out their site: http://www.fibre-lyte.co.uk" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Post new topic Reply to topic  [ 88 posts ]  Go to page 1, 2, 3, 4, 5, 6  Next
Users browsing this forum: BeeSeeBee, curtisfong, Google [Bot], HakeemT, ipaul, veganeric and 47 guests
There are no new unread posts for this topic. Cateye Stealth 50?
brettmess24
Sun Mar 03, 2013 4:27 pm
brettmess24 View the latest post
There are no new unread posts for this topic. Zipp Vuka Stealth
marcelflash
Mon Apr 29, 2013 10:56 am
marcelflash View the latest post
There are no new unread posts for this topic. Attachment(s) Pro Stealth Evo Seatpost Weight
Dougan
Thu Dec 06, 2012 7:12 pm
civdic View the latest post
There are no new unread posts for this topic. Help me choose a groupset!
Northoceanbeach
42
1872
Wed Feb 20, 2013 5:50 am
Northoceanbeach View the latest post
There are no new unread posts for this topic. Groupset advice for new build.
n1klass
Sun Dec 23, 2012 5:47 am
Tinea Pedis View the latest post
It is currently Thu May 23, 2013 11:58 pm
