Post new topic Reply to topic  [ 4 posts ]
PostPosted: Wed Dec 19, 2012 3:33 pm
Here's the deal. The right hand shifter (rear derailleur) on my winter bike plays tricks on me when it's cold outside (below 5 degrees celcius). It won't shift down the cassette. It's like the paddle won't properly "grip". When the bike is in my flat (warm), it's no problem.
I'm thinking it might have to do with some old grease inside the shifter. Something inside the shifter that thickens when it's cold. I have been looking for information on how to service (or just take apart) the shifter, but so far I haven't found anything.
Does anyone have an idea?
PostPosted: Wed Dec 19, 2012 5:52 pm
I offer no guarantees, and I've never worked on that specific shifter, but in some cases you can blast a shifter out with GT85 to unstick it. You may then want to add a little fresh grease so it's not too dry, but that's a matter of judgement.
PostPosted: Wed Dec 19, 2012 7:31 pm
Flush with a lube/solvent solution. I use CRC Powerlube. I had the exact same shifter and similar symptoms. Flushed with Powerlube and the shifters worked perfectly for years, before I passed them on to someone else.
Don't take it apart. Just remove the hoods, flush every cranny of the internals liberally with Powerlube (while working the shifter) until it drips out relatively clean. You could also try swinging the shifters to work the solution into the internals.
Keep working the shifting and you should see an instant improvement. Clean off and you should be good to go.
PostPosted: Wed Dec 19, 2012 8:32 pm
Thanks a lot for the suggestions, it's greatly appreciated :)
Users browsing this forum: Exabot [Bot], stax and 44 guests
There are no new unread posts for this topic. 10 speed Shimano crank/rings on 11 speed group Shimano
bigcalves
11
1411
Wed Oct 10, 2012 10:06 am
BdaGhisallo View the latest post
There are no new unread posts for this topic. 10 speed shifter on 9 speed front only
jamr1
Fri Oct 19, 2012 9:02 am
mrfish View the latest post
There are no new unread posts for this topic. 11 speed Shimano free hub body with 10 speed DA cassette
WasFab
10
840
Fri Apr 12, 2013 9:31 am
dha View the latest post
There are no new unread posts for this topic. Shimano 10 speed + Campagnolo 10 speed cassette
rhyslewisdavies
Tue Jan 15, 2013 12:10 am
bm0p700f View the latest post
There are no new unread posts for this topic. Shimano Di2 R671 TT Shifter
alannmcl
7
574
Fri Feb 15, 2013 7:03 am
footwerx View the latest post
It is currently Sun May 26, 2013 6:19 am
